Question about Clymer Shop Manual - 96-99 Suzuki GSX-R750
My Suzuki mower seems low on power and is hard to start once hot
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Well if you have a Suzuki engine on your push mower ( and yes, they do make them and they're expensive ) I would the valve adjustment.
if it's a motorcycle i would check the same thing
Posted on Oct 20, 2013
Why does it start very hard but once running runs perfect. Shut off very hard starting again.
This can have diggerennt possibles
1) Weak spark. Once running, higher rpm gives better spark. Check plug for condition and HOT blue spark.
2) Poor initial prime. Check for choke function and fuel delivery.
Jul 01, 2015 | Garden
Suzuku SX4 starting problems - fuel pressure
intermittent are hard to find.
as they say" if it ain't broke, you can't fix it" applies
but in truth, we lay in traps to find this.
this is true with all machines, not just sx4
facts: (random no starts) but always cranks fast.
only fails cold engine. never hot. (does restarts hot work?)
seems yes.
seems you have full 12vdc power at all times.
seems the engine is ok. as it is not heat rlelated or the classic hot soak fails.
so what is it.
well, its 1 of these.
1: lost spark, simple tests, do so when failed.
2: bad fueling. (too much or too little)
the tests for each failure are dead simple and work on any engine.
ask.
Jun 29, 2013 | 2009 Suzuki SX4 2.0
1996 SUZUKI X90 WONT START AND THE SPARK IS LOW
can only be 3 things, bad motor, bad spark and bad fueling, in that order.
and 3 tools to check each, in that order.
ever do the 60k tuneup, (I have 4 of these cars restored and 3 sold)
http://www.fixkick.com/nostart.html
my guess is fuel pressure good means it passes the squirt test
right? this is no carb, EFI needs 30psi, and squirt tests tell you near nothing.
Ponder this. if the motor had 170psi compression
and the spark was good, (it will be tuned up)
and is timed, right. is it?
then it will run perfect on test fuel. does it.?
if yes , then you have fueling problem , once this is proven, we work fueling hard.
Feb 13, 2013 | 1996 Suzuki X-90
Hard steering
It is normal for a car without power steering to be difficult to turn the wheels when the car is stationary or at very low speeds. Once you are moving above say 10 mph the steering should be fairly easy.
Nov 08, 2012 | 1995 Suzuki Swift
1994 Suzuki Sidekick no power
Hard to say. Could be anything from a cylinder miss-fire to dirty injectors to transmission problems.
Is the check engine light on ?
Does it feel like it is starting out in low gear ?
Have you had the truck serviced lately ?
Jun 26, 2012 | 1994 Suzuki Sidekick
88 suzuki quadrunner 300 idle problems
You could try using petrol rather than gas to start it.
Also run it off petrol rather than gas.
May 07, 2017 | Cars & Trucks
Husqvarna 2009 Tractor Run 30 minutes, sputter, loses power, dies
hi it seems to me either a lack of compression when she is warm /hot /check tappets or a weak mixture /air leak on the inlet someware hope this is of some help merlinv12
Aug 20, 2009 | Parks Optical 13.5hp Briggs And Stratton...
Mower motor hard to start
Make sure the choke is completely closed when trying to start. Many times this is the problem with hard starting.
Mar 31, 2009 | Garden
Clymer Shop Manual - 96-99 Suzuki GSX-R750 Logo
46 people viewed this question
Top Clymer Garden Experts
Dennis Key
Dennis Key
john h
Are you a Clymer Garden Expert? Answer questions, earn points and help others
