https://s14.postimg.org/6r7zxgtox/power_windows.jpg
Click on the link.
I can only help by telling you to check voltage and ground circuits. You check voltage by using a test lite, see the fuse in diagram, not only check the fuse, check the fuse circuit for voltage.
To check ground, you can still use the test lite, one end comes from voltage, the other end you touch to ground wire, the actual wire not the insulation, if the lite comes on, at least you know the ground is good enough to turn on the lite.
You can see voltage wire color coming from fuse. The ground wire not in the picture, black with yellow tracer.
on the hinge side of driver door is usually a wiring harness going into the driver door, probably has a protective covering, move cover back far enough to find the wire colors you want to check.
You open/shut driver door so much, sometimes those wires may break?
