Akai aa 1020
Where are the fuses located?
I need the user manual for akai aa-940 that's what i need
click link and download http://vintage-audio-laser.com/Akai-Service-manuals-Schematics
Dec 01, 2010 | Audio Players & Recorders
I have an Akai AA-A45 receiver. The display panel lighting is not working otherwise the unit works fine. Any ideas?
in that receiver ther is a fuse that controls the display, I have the same unit, there are 4 fuses by the power supply, it would be one of those, I cant remeber which one but if the fuse is blown it will turn of the entire display. Check that out and if thats not the problem, then there is a short in the unit.
Nov 14, 2009 | Audio Players & Recorders
I have an akai aa-a25 reciver and right side speakers only work
I had this problem when I first got this receiver back out of years in a box, but it was fixed by pressing the reset button on the back. Hope that works for you!
Jul 10, 2009 | Audio Players & Recorders
AKAI PT5598HDI 55 Where is fuse located
This problem is beyond a blown fuse most likely. The fuses for the unit are located on the circuit boards and the back will need to be removed to access them. This problem could be due to a missing voltage that is used to turn on the picture section of the electronics. I would search for a used unit on ebay or parts on ebay and swap out the boards. The board swap is not too complex but voltages are dangerous within the set and service by a qualified electronics technician is recommended on this unit. Thanks and good luck. Dan
May 31, 2009 | Akai PT5598HD 55" Rear Projection...
I have a 55 inch Akai rear projection tv.When I turnit on,the red timer light blink,and that is all.I've heard about this problem on here before.No pic and no sound
on the main board of the tv there is a fuse located if that is faulty this can happen,there are also many other possibilities but check out the fuse first many a times replacing the fuse solves the problem as its very negligible to replace the fuse the cost of fuse is under $1.
Mar 03, 2009 | Akai PT5598HD 55" Rear Projection...
Akai replacement parts
You are not likely to find the board easily, but you should be able to replace the convergence ICs relatively easily. Look at the board. Try resoldering the pins on the STK ICs. If that fails to resolve your problem, replace the ICs. There may be some pico fuses located close by or low valued resistors that may be open. Check for those as well.
Keep us posted.
Dan
Jul 23, 2008 | Akai PT5598HD 55" Rear Projection...
Have a nearly 30-year old Akai stereo receiver AA-R30. Power light just stopped turning on. Opened up case and found main fuse between AC power cord and power transformer blown. When I replace the fuse,...
Look for shorted output transistors or possibly shorted rectifier diodes. An immediate fuse blowing up usually means that the power supply is the problem. Keep us posted.
Dan
Apr 08, 2008 | Audio Players & Recorders
AKAI PT5492S
Replace convergence IC's and locate & replace open fuse
device (probably a pico fuse soldered in underneath IC heatsink).
re-align convergence.
Oct 12, 2007 | Akai PT5492S 54" Rear Projection...
 Grubhead
Grubhead
