Question about Gateway Computers & Internet
Product specs Gateway GT5465E Desktop Computer. Im in need of the wiring diagram to connect sata, blue/white, red/white, 24Awg/2,...
    Master:
  • 680 Answers
The cable ends can only go in one way. It won't go in backwards.
Terry
Posted on Oct 17, 2013
mbase213
  • 728 Answers
SOURCE: can u possibly tell me
Hi dallasblue08,
Here's a diagram of what your looking for:
The following eMachine models share the same motherboard (and thus the same front panel layout):
T2742 T2796 T2798 T2824 T2885 D2823 T2862 T2896 T2898 T2958
Hope this helps!
Mark
Posted on Jan 04, 2009
frankzjm
  • 191 Answers
SOURCE: specs and pictures for a t2865 emachine computer
ok, you may look the motherboard manual:
1) set USB from page 14
2) set the front panel four connectors look from page 12
the manual reference :
http://www.lurkhere.com/~nicefiles/AU31_manual.pdf
hope help you fix it.
Posted on May 18, 2009
  • 191 Answers
SOURCE: Blue LED light connection from Bezel to Motherboard
red white is the pair that supplies power it should be 2pin socket on motherboard
Posted on Sep 19, 2009
  • 31 Answers
SOURCE: HP a6412p added 2nd hard drive but wont work get blue screen
you should try switching the sata port you plug your new drive into. also, you should go into your BIOS setup f2 and save setting then exit.
Posted on Jan 25, 2010
Testimonial: "thank you!!!"
angel153
  • 10 Answers
SOURCE: power switch hook up on
This is not a photo of your motherboard. Please use it as a general guide on what to look for on your motherboard. Most brand name systems will have the connector pins placef on the edge of the motherboard that is closest to where the wires coming from the power button are being routed. Pay attention to a set of pins that equal the amount of connection wires you have. When you see it, look around the pins and you will see etchings that describe which wire goes on what pin.
NOTE: Please remove the AC cord from the computer and that all keyboard, mouse, video, network cable and usb slots are disconnected and empty. Do not power the pc until you are certain you have matched the connectors to the right pins.
Posted on Jun 01, 2011
Product specs
Go here to download your manual:
Oct 17, 2013 | Gateway Computers & Internet
I need some type of wiring diagram or instructions on where an which terminals go where in my desktop,
You may find Docs here: https://support.gateway.com/us/en/emac/product/default.aspx?modelId=1585 For future reference , take lots of pictures with a digital camera when doing a disassemble for the first time, in the future. Most of the time, NO ALL, the connectors will only fit in one connection. OR, take it to the "friend" for re-assemble.
May 17, 2013 | eMachines T3642 Refurbished AMD Desktop...
I cant seem to add more than one extra hdd
Check BIOS and make sure the other 2 SATA ports are enabled,
Dec 28, 2012 | Gateway GT5465E Refurbished Intel Desktop...
Wiring diagram emachine T5246
OKAY!
There's what I'm talkin' about!
The model number.
The eMachines T5246 Desktop PC uses a
Foxconn/Winfast MCP61PM2MA motherboard.
[You stated Foxconn/Winfast. I got that. Just letting you know ]
Guess what?
So does the Gateway GT5476E Desktop PC,
http://support.gateway.com/s/MOTHERBD/Shared/4006200R/4006200Rnv.shtml
Click on - Product Views - in the list.
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to, is the Front Panel header.
If you need a pinout for the Front Panel header, click on -
S - Front Panel connector
The Top row is numbered EVEN. Starting from the Left side going to the Right;
Pins 2, 4, 6, and 8. There is NO pin 10.
[Colors going from Left to Right;
Orange/Yellow, Orange, Green, Green ]
The Bottom row is numbered ODD.
Pins 1, 3, 5, 7, and 9.
Red/Yellow, Red, Blue, Blue, Yellow ]
A) Pins 1 and 3 are for the HarDDrive activity LED (Light)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are a Reset switch, IF a Reset switch is used.
C) Pin 9 is for 5 Volt power. This was used by the factory. It is N/C.
Not Connected.
D) Pins 2 and 4 are for the Power On LED.
Pin 2 is for the Positive ( + ) wire.
If the PWR ON LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
Any other connector info you need? Post in a Comment.
Specifications,
http://support.gateway.com/s/PC/R/1009603/1009603sp2.shtml
1) Ram Memory:
Uses DDR2 Sdram at 667Megahertz. (667MHz)
Maximum TOTAL amount for the motherboard is 2GB. (2 GigaByte)
Maximum Amount for each Ram Memory slot is 1GB.
IF, you just have one ram memory module, make SURE it goes in ram memory slot 1. (DIMM 1)
That is the ram memory slot closest to the Processor.
Uses a SATA harddrive, and IDE (PATA) optical drive/s.
Does have two SATA connectors on the motherboard, so it can use ONE SATA optical drive.
On those SATA connectors on the motherboard,
http://support.gateway.com/s/MOTHERBD/Shared/4006200R/4006200Rmvr12.shtml
See the bottom SATA connector has SATA 1 next to it?
The SATA harddrive is supposed to be plugged into it.
However, the beauty of SATA is, NO MATTER WHAT SATA connector you plug into, BIOS will find that device.
Want to plug the SATA harddrive into SATA 1? No problem.
Want to plug the SATA optical drive(CD/DVD drive) into SATA 1?
No problem.
Want to plug the SATA harddrive into SATA 2? No problem.
Want to plug the SATA optical drive into SATA 2? No problem.
BIOS will find the device.
For additional questions please post in a Comment.\
Regards,
joecoolvette
Aug 02, 2012 | E-Machines Computers & Internet
I need a wiring diagram for a GM5664
Gateway Support > Gateway GM5664 Desktop PC > Downloads and Support Documents,
http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=2734
Click on the Support Documents tab
(Drivers, BIOS, Applications, Patches, Support Documents, etc)
Click on the blue - 1015004R - Support Documents
Click on Product Views in the list.
Click on Inside View
Go back to the main page
Click on Components
Go to the heading - Motherboards
4006254R - ECS MCP61PM-GM
(AM2 processor socket, MicroATX form factor motherboard)
Gateway Support is of no further help to us. Product Views for the motherboard does not work.
ECS motherboards use a 10-pin Front Panel header, if memory serves.
One pin is not used. (Not there. Number 10 pin)
http://www.ebay.com/itm/GATEWAY-GM5664-MCP61PM-GM-MOTHERBOARD-4GB-Ram-AMD-Athlon-II-Dual-Core-3-0GHz-/360423046239?pt=Motherboards&hash=item53eae33c5f
On the above link scroll the page down, until you come to the enlarged photo of the motherboard, with - Click an Image to Enlarge - under it.
Click on the photo view all the way to the right, on the top photos.
The view shows the 4 orange SATA headers on the motherboard.
(The whitish 24-pin ATX main power cable connector, is shown at the front, with the blue IDE 40-pin header behind it)
To the left of the orange SATA headers (4) is the Front Panel header.
Black rectangular connector with 2 rows of pins.
One row has 4 pins, the other row has 5 pins.
[ The plastic front of your computer is the Front Panel.
The area of pins on the motherboard, that the wires from the Front Panel go to, is the Front Panel header ]
Finding where number 1 pin is, is the problem.
Next to the number 1 pin, and silk-screened on the motherboard, is the number 1.
Looking at the rectangular connector (Front Panel header) you will note one pin is missing. This is where number 10 pin would be.
On the opposite side, and opposite end, is number 1 pin.
The pins are numbered Odd, 1, 3, 5, 7, and 9, on the same side.
(Or row)
The pins are numbered Even, 2, 4, 6, and 8, on the other side.
(Or row)
A) Pins 1 and 3 are for the HarDDrive activity LED light.
(HDD LED light)
If the Harddrive activity LED light is dim when operating, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is Not Connected. N/C. Reserved for the factory
D) Pins 2 and 4 are for the Power On LED light
If the Power On LED light is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch. (Located inside the plastic Power On button assembly. It is an ATX power on switch)
http://www.fixya.com/support/t614458-hp_mcp61pm_hm_motherboard_diagram
As for the orange SATA headers on the motherboard. The SATA harddrive should plug into the lowest number of SATA header.
It may be labled SATA 0, or SATA 1.
The beauty of SATA however, is that you can plug the harddrive into anyone of those SATA headers. BIOS will find the device. (Harddrive)
If you need guidance in connecting any other cables, such as power cables, or optical drives, etc, post back in a Comment.
Regards,
joecoolvette
Jan 09, 2012 | Gateway Computers & Internet
Hello. I was cleaning the dust out of my computer fans and somehow the little blue & white, and red & white cables came out of where the attach to the motherboard. I am looking for a diagram so...
Looking at the board with the SATA connectors to the right and the backplate to the left. Look to the lower right corner of the board. You will see a group of two rows of pins(9pins with one missing) The pin that is missing is pin#10. The pins are numbered even on the pin#10 side, odd on the other. The Power Switch - Pin 2 is the Red wire/white is Pin 4. The Power Led - Pin 6 is blue pin 8 is white.
Shhhh! Must be a Gateway Secret.
Jun 13, 2011 | Gateway GM5664 Desktop PC
When i connect my desktop to my monitor i don't get any visual picture, but when i connect my laptop to my monitor i do. My desktop is gateway gt5465e
So it sounds like your video card on your desktop. The best solution here if you are not looking to spend much money is to buy an off board video card. It looks like from the specs on this model you should have a spot for a pcie x16 card.
This link is a cheap one from newegg. http://www.newegg.com/Product/Product.aspx?Item=N82E16814500118
Feb 13, 2011 | Gateway GT5465E Refurbished Intel Desktop...
Im trying to install a sony xplod radio in my 1995 Nissan Maxima. im using scorsche wiring harness A/B. i did all necessary installation procedures and the radio works but im not getting any sound out of...
Maxima Wiring Diagram
1995-97 Nissan Maxima Stereo Wiring Constant 12V+ Pink/Blue Switched 12V+ Blue/Black Ground Vehicle Chassis Illumination Red/Blue Dimmer Red/Orange Antenna Trigger Black/Red Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Blue/White Left Front (-) Blue/Yellow Right Front (+) Brown Right Front (-) Brown/White Rear Speakers 6 1/2" Rear Deck Left Rear (+) Red Left Rear (-) Green Right Rear (+) Blue Right Rear (-) Pink
Diagram for any aftermarket head unit
Black: ground
Red: switched 12volt (accessory)
Yellow: 12v Constant
Orange: Illumination (Dimmer)
Blue: Remote
White & White/Black: +/- Front Left
Gray & Gray/Black: +/- Front Right
Green & Green/Black: +/- Rear Left
Purple & Purple/Black: +/- Rear Right
Dec 23, 2010 | Car Audio & Video
Japanese import integra type r stereo wiring diagram
Try the following, this is an 1997 USA Integra
Radio Constant Wire 12V+: Blue/White
Radio Switched Wire 12V+: Yellow/Red
Radio Ground Wire: Black
Radio Illumination Wire: Red/Black
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: n/a
Radio Antenna Location: Left Rear
Front Speakers Size and Location: 5 1/4′ Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Front Speakers Size and Location: 6 1/2′ Side Panels
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
Oct 06, 2008 | 1997 Honda Accord
Computers & Internet Logo
137 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
