Question about Easy Heat 10802 Freeze Free Connection Kit
Indicator light flickers on & off - Easy Heat 10802 Freeze Free Connection Kit
2011 Dodge Dakota Lonestar.Battery drains dead in 6-7 hours.
Sounds like a [i]possible[/i] short in your wiring loom / harness.
Get an auto electrician to go through your wiring system.
From a first-hand incident, an unattended short [i]could[/i] result in burning wires / fire.
Apr 08, 2018 | Dodge Cars & Trucks
2006 corolla se dashboard lights flickering
If all the lights are flickering. I would suggest that you only go as far as locating the fuse. Clean it and put back. Alternatively replace with new fuse. It's unusual for all lights to flicker. 1 might flicker, indicating a faulty bulb. On Toyotas, the dash lights are usually on the same fuse as the park lamps.
Jan 31, 2017 | Cars & Trucks
Is there a fix for my lights flickering on my 07 dodge 3500 6.7 I have try just about every thing I can with out taking it in to be looked at
Flickering is an indication of a loose connection. Check the wires to the lights. While in park and the lights on, wiggle the wires and connections to see if the lights flicker. Also check that the bulbs are installed securely.
Feb 10, 2016 | Dodge Cars & Trucks
Why are the red lights indicator flickering?
Depends on the speaker/subwoofer. Some red lights indicate the point of 'clipping', which would be the maximum volume without distortion. That would be likely if the light is flickering and not continuous.
Aug 18, 2014 | Audio Players & Recorders
Opel Corsa 1.6 Sport - Left side indicators stay on even if the car is not started. Fuses are fine as well as bulbs, the dashboard will sometimes flash rapidly or at other times the indicator on the dash...
The most likely cause is either a shorted out flicker-relay or a faulty stalk switch. If the lights do not "flicker" I would check the flicker relay. o the lights go out when you pull the relay? It can usually be found in the fusebox (usually the fusebox in the dashboard)
Feb 05, 2018 | Cars & Trucks
Left indicator light flicker too fast
If the right side works properly, switch all indicator bulbs one at a time. test with each bulb change. Untill you find the one that makes it flash at the rite timing. I had a bad rear bulb. The brake filiment was laying on the tail light filiment. This made the blinker timing bad.
Jan 26, 2014 | Hyundai Tucson Cars & Trucks
Jacuzzi J315 spa waterfall lights flickering.
A flickering light would indicate a short in a wire some where along the way.
You will have to look at each wire until you find the short.
Rod
US Parts Center
888-521-6183
Feb 11, 2013 | Pool & Spa
Rear indicators work until headlights are switched on then they go dim
sounds like you have a sort in the electrics, check the connections and the bulb holder on the back lighting, and the wiring under the seat.
Dec 19, 2017 | 1997 kawasaki ZX-6R Ninja
The light on my chest freezer will flicker on and off when I open the door. It will only remain on when the door is in a certain position. How do I fix this? Secondly, the red "on" light on...
Both light flickering probably indicates a problem with the plug or the cord. If it was just the inside light I would suspect the door switch, but both light would indicates an open short in the wires or plug.
Check the plug connection at the wall and see if it is loose. While unplugged check the cord for any nicks or cuts. Plug something else into the same wall receptacle , like a light and see if the power to the receptacle is ok.
If none of the above work then it is time for a qualified repair person.
J
Feb 20, 2018 | Woods Chest Freezer C1501W3
The light that is supposed to indicate on/off is flickering. However the freezer still works fine. How can I fix this?
The flickering light is nothing to worry about... as long as it is flickering it is considered to be "on"
If there is no light then you need to worry...
The light flickering is not something that you need to fix...
heatman101
Jan 12, 2011 | Frigidaire 7.20 cu. ft. / 204 liter Chest...
Easy Heat 10802 Freeze Free Connection Kit Logo
136 people viewed this question
Top Easy Heat Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you an Easy Heat Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
