Question about KitchenAid KGST300 Gas Kitchen Range
Gas oven igniter comes on when the main burner ignites the flame goes inside of the burner and burns by the orifice
    Top Expert:
  • KitchenAid Master
  • 9,472 Answers
You will need to replace the "spark module". Here is the part to order.
There is also a video on that same page that shows you how to make the repair.
Posted on Oct 20, 2013
Tech007
  • 63 Answers
SOURCE: Oven "bake" doesn't work...
sounds like the bake glow bar needs to be replaced it is under the bottom cover inside the oven good luck
Posted on Aug 29, 2007
SOURCE: 8 year old kitchenaid gas range nom fire in the oven
I went to the kitchenaid web site for parts and found a trouble shooting section. I read about how a electronic glow coil works and discovered that mine was just old and did not reach the right voltage to open the gas flow valve.
Posted on Feb 21, 2008
SOURCE: Broiler not lighting on gas Kitchen Aid SuperBa
I had the same problem with the igniter glowing and I could smell gas no flame. I took the broiler out.
Not as hard as it sounds. Took out 6 screws I did not have to disconnect the igniter, because there is
enough slack in wire to just drop it down a bit. Looking where the burner tube came out I could see
the orifice. I connected a safety pin tin long twisses and stuck the pin into orifice rubbed it a bit. Put it all back together. Just make sure the burner tube gets set in all the way don't force it.
Good Luck Joe C.
Posted on May 06, 2009
zazonker
  • 68 Answers
SOURCE: Dual fuel kitchenaid; burners work, oven does not
I had a similar problem. There's a thermostat before the control panel. You need to remove the knobs and the front panel to get to it. You'll also need to remove a couple of trim pieces to keep from bending the panel. The part number is Whirlpool W10017820, sells for about $40.
Posted on Jun 03, 2009
SOURCE: kitchenaid gas stove left back burner won't light. hear clicking
I have a Kitchen Aid gas stove. All the burners will not light. No clicking, NOTHING. Is there a lighting switch or something that needs to be replaced ?? Or do I replace all 4 lighters ??
Posted on Jun 26, 2009
Why does my westinghouse gas oven ignite, go off, ignite again, off,on, off, on, before temp is reached?
dirty gas orifice in the oven near the burner clean it and try again
Jul 22, 2017 | Ovens
PILOT LIGHT COMES ON BUT WHEN YOU TURN THE KNOB TO ON IT DOES NOT LIGHT UP THE CIRCLE PLATE IN THE HEATER. IT JUMPS AND THE FIRE COMES OUT THEN IT GOES OUT.
I'm not sure what unit you are troubleshooting but if the main burner is igniting and that main burner flame is blowing out the pilot flame, it's possible the pilot flame orifice needs to be cleaned. The orifice can get stopped up and produce a weak pilot. And I've seen a pilot lite, but be blown out by the combustion of the main burner igniting. Now you stated IT JUMPS. If you mean the pilot flame jumps, as if it gets large then weak and goes out, then the gas valve is giving you trouble and may need to be replaced.
Mar 09, 2017 | Heating & Cooling
My oven does not work, range is ok
The thermocouple or thermal capillary is not the only cause of failure; a burned-out or broken heating element is more likely the problem in an electric range. You can check the element by unplugging the range, disconnecting one of the wires to the element, then testing the element for continuity using an ohmmeter. Access to the burner connections varies by model. If you see a couple of screw heads inside the oven where the ends of the element meet the back wall of the oven, you may be able to get at the connections by removing those screws, then gently pulling on the element to bring the connecting wires inside the oven, then undoing one of the screws attaching the wires to the element (avoid excess force on the element; you don't want to crack the ceramic inside it). If you can't get at the connections this way, you'll have to remove the back of the oven. This may actually be easier than crawling around inside the oven anyway.
In a gas range with a gas pilot or an electronically fired gas pilot ignitor, a common problem is clogging in the flame orifice(s); this is visible as a white buildup in the orifice hole(s). Low gas pressure in the pilot can also cause ignition failure if it can't sustain the pilot flame long enough for the flame sensor to enable the main gas valve.
I'm sorry I can't give you more than a generic answer; the model number or part number you provided doesn't come up on any searches. Perhaps it is actually the stock number from one particular supplier, or there is a typo in it.
Jun 14, 2015 | Magic Chef Kitchen Ranges
Igniter switch on top burner will not shut off
try thoroughly cleaning the burners, particularly the holes in the ring that the gas come through. The gas come through to heat the ignitor so that the ignitor knows to stop trying to light the burner ; if the holes are clogged the ignitor doesn't heat.
The burner is easily disassembled from the top by removing a thin bolt, and you can clear the holes with a paper clip.
Sep 21, 2013 | DCS RGS-305 Professional Gas Kitchen Range
Oven will not heat up
When the bake igniter becomes weak or burns out, your oven will not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat(located inside the top area of the units body structure)
-- defective selector switch(located on the control panel, or part of the integrated control board key pad.)
-- defective gas safety valve(located on the gas valve assembly)
-- defective gas valve coils(located on the gas valve assembly)
-- defective flame sensor(located on the gas valve assembly)
NOTE(If everything checks out ok with the ignitior, and burner/valve assembly, this will lead to a failing control board)
Nov 03, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I hope that I can get this problem resolved. Can there be a thread started to help me through this? I will try to keep this as short as possible, I have a Ducane Mod. CMPB050C3A Nat. gas furnace. The...
say that you have the glow bar (Hot surface igniter) working
if the flame starts make sure you don't trash on the orifice of the burner, you can try to use a piece of wire or someting small to pick on the orifice of the burner, also make sure is not rust bewteen the burners gap where the flame spread to all the burners because if the flame sensor don't feel flame don't stay light up
hopes this help
Oct 09, 2009 | Heating & Cooling
Whirlpool stove top- two problems. 1) burner is not burning hot, low flame 2) igniter on different burner doesnt work, no spark at that burner.
Hi
If the burner is not burning hot, and there is a low flame then this is often a pressure regulator problem. Most often the regulator is found where the gas line enters the gas range. I have a picture of what the flame characteristics should look like. If the igniter on different burner doesn’t work, and there is no spark at that burner then you will have to check the same items as mentioned above. This is a typical spark module wire diagram.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 08, 2009 | Whirlpool GLT3615 Gas Cooktop
Replaced gas safety valve, burner flame now too hot
Take a 1/2 inch open end wrench and tighten the orifice on top of the safety valve.Probably about 2 turns. Then adjust the air shutter to mostly open.
Mar 26, 2009 | GE Ovens
No flame on left side/main valve. Right side lights, flames up
Try taking out the orifice on the burner that is not lighting and make sure it isn't blocked.
Mar 12, 2009 | Heating & Cooling
Gas oven igniting but not heating up
Is orifice that gas flows thru into burner clogged/restricted? IF not, then Ignitor may be bad; I would replace it. If still same issue then gas valve is bad. Thanks, please leave feedback or contact me again for more info if you need it. Flame height does not change regardless of your setting- it's either on or off; thermostat is not like an accelerator. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 29, 2008 | Ovens
KitchenAid KGST300 Gas Kitchen Range Logo
48 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
