Question about 2wire Computers & Internet
My net gear WNCE4004 wireless adapter won't connect to me 2wire420. Netgear says maybe I need to alter the access control settings on the 2wire, but I don't know how to do that and is it really necessary? the iMac I am using to install the adapter does access the 2wire router, so why wouldn't the adapter?
  • 22 Answers
Why are you trying to use a net gear router if the 2wire router is working. Is the 2wire under att service?
I’m happy to help further over the phone at https://www.6ya.com/expert/tarik_f88885a87e319a0d
Posted on Oct 17, 2013
4 Suggested Answers
One Piece
  • 53 Answers
SOURCE: Connecting a netgear wireless router to a 2wire
before you connect the netgear router to your 2wire modem, you have to get the modem configured first. you did not include the firmware version of your modem (firmware version is found at the UI, go to gateway.2wire.net, click on the system icon.) for firmware version less than 3.7, go to homeportal/management, click on configure services, uncheck enable routing, then click on submit. for version 3.7 or higher, go to homeportal/management, click on configure under broadband link, put a dot in disable pvc search, set VPI to 0 & VCI to 35, the connection type box should be direct IP, then click on submit. then go to configure services, uncheck enable routing box, then click submit. you will notice the broadband link on the 2wire modem turn orange/amber, then you have successfully set the modem to bridged mode. that way you can now connect the router according to manufacturer's instructions (or just read the manual for the netgear router....)
Posted on Apr 03, 2008
SOURCE: 2wire Router cannot connect to K Corp KLS-611 adapter 802.11g
if you wantd to change the type of encryption from WEP to WPA...aside from accessing the modem through 192.168.1.254....this ip is used on 2wire1000hg series, 2wire1800hg, 1701hg, 2701hg-b and 2700hg-b
*then you might need to indicate the modem password
*if you know it...indicate so, if not, click on the link that says "I forgot password", it would give you a hint...if you still forgot it, click on "I still forgot password"
*after that you need to click on "home network" which is the icon on the top portion of the page
*then you need to click on "wireless settings"
*under "wireless security" you would be able to change the "authentication", whether it is WEP-OPEN, or WPA-PSK"
- you could also go to: 2wire.com for help, just go to the support section
- or you could also see some simulators if you need one on shasta.2wire.com
Posted on Apr 26, 2008
kakee
  • 1269 Answers
SOURCE: Setting Up the Netgear WGT624 as a bridge
Just disable the DHCP function of the Netgear router. Connect them from LAN port of 2wire to LAN port of Netgear.
Posted on Nov 25, 2008
Netgear adaptor won't recognize 2wire 420
If you wish to unlock this Huawei E960 password.... Call +2347035041294... Skype: mickyhandsome2010
Oct 17, 2013 | NetGear WNCE4004 IEEE 802.11n 450 Mbps...
I bridged an either-net cable from 2wire modem to Net Gear Wireless router. I need to turn off wireless (DHCP?) on the 2Wire modem, since it is unecessary. I am prompted at login for admin password at...
If you want to turn off dhcp for 2wire then connect the two wire to a computer and use :192.168.1.254 .But if you are doing in for netgear then yes you can use :192.168.0.1 with the user name as admin
password as password
*** it will work only if you have never customized the router admin password . else do a hard reset of router (pin hole in the back - press and hold 20 secs )and the router will be in factory default mode ..
Aug 17, 2011 | 2wire (2701HG-B) Wireless Router
I have a Netgear Wireless router n- wnr2000, how can i disable the macfiltering
You have to login to the routers homepage. To do this you need to go to you computer and open your internet browser. At the top in the address bar type 192.168.1.1 and hit enter. Then a login screen should appear. The username is admin and the password is either blank as in no password at all or it is admin or password. Once you login to the homepage go to advanced > wireless settings > click setup access list. Under access list you should see an option Turn Access Control On. Uncheck that option and save.
Feb 04, 2011 | 2wire (1000-100052-000) 802.11g/b Wireless...
Can't access 2wire network using netgear adapter
I was also having trouble with my Netgear wireless n USB adapter connecting to my new at@t 2WIRE gateway. The problem was that the netgear software wouldn't allow my computer to stay connected to my 2WIRE gateway and the software wouldn't allow Windows when restarting my computer. I have Windows XP and after hours with at@t support there was no resolution and they gave me Netgear's suport number to call 1-888-638-4327. After 10 min. the problem was fixed. They had me click start icon at bottom left corner then all programs, then highlight "start up" and if you see anything like netgear adapter or netgear start up wizard right click on it and click delete. That was it! rebooted my computer and it connected automatically!!! I'm not very computer knowledgable but I hope this helped
Feb 02, 2009 | 2wire (1000-100016-002) Wireless Adapter
2Wire Wireless Modem 2700HG-G
access gateway.2wire.net
home network icon
wireless setting tab
channel dropdown box=11
save
P.S u should know ur PW to do this
Oct 14, 2008 | 2wire (1000-000057-000) Modem
Linksys Adapter and 2wire router
  1. ensure that a wireless connection is created in control panel on the pc, it may not even be attempting to connect
  2. ensure that the router wireless is turned ON, it may have been turned off as a security measure when no wireless pcs were used
  3. The security settings on the adaptor may be set to the office network and locked
    wep password at home is different or not enabled, so the secured adaptor will not connect.
make any changes from a cable connected pc (no chance of data loss)
access the routers settings page and check the settings,
then ensure the adaptor rom if present is set to the same settings
Jul 16, 2008 | 2wire 2700HG-B Router (2700HGB)
Wireless connection
re-installed the netgear driver properly you get it
Jun 19, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Connecting 2wire router with desktop pc and laptop
hi! try to check the settings on your 2wire modem, you can do this by going to gateway.2wire.net, run the system setup wizard, when you get to the ppp authentication page, check the username & password on it, it should be the one that you setup for your ISP account. as for the wireless on the desktop, it depends on the brand of the wireless adapter, be sure you have installed the drivers for this adapter. you may need to go to the client utility manager or the wireless adapter shortcut/icon on your computer screen then configure it to "see" the 2wire network. make sure wireless encryption is turned on in the 2wire modem's MDC, you can do this by going to homeportal/management, or go to gateway.2wire.net/mdc.
Apr 11, 2008 | 2wire (1000-400108-001) Router
Hooking up my gaming router
There is a 90 % possibility that the wireless settings on the gaming adapter and the router are not the same. Try to reconfigure this again. Remember that the gaming adapter's wireless settings needs to synchronize with that of the router to make the gaming adpater works. Call netgear and verify the settings on your wireless connection and reverify the settings you have on the adapter. For manual instructions, see user guide at www.linksys.com/download
Oct 15, 2007 | Linksys Wireless-G WGA54G 802.11g/b...
2wire router and usb adapter
first u need to connect a pc through wired on the w/l router and go to w/l part and configuge it
Oct 05, 2007 | 2wire (1000-400108-001) Router
Computers & Internet Logo
281 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
