Question about Antari Ice Low Lying Fog Machine +
Our Antari Ice low lying fog machine is warming up (light goes green), however when you press the controller to produce the fog, nothing comes out. The fan is working, but no fog coming out. Any urgent assistance would be appreciated. Thanks Gill
    Problem Solver:
  • 11 Answers
Check the fluid pump's output. you may have have a clogged or kinked supply hose to the pump or in the copper tubing from the pump to the heater. Also, check the power to the pump. if it's not the pump, then you have to consider a clogged heater block. This is common if the machine is not cleaned before storage. That's about all that can go wrong on a fog machine other than the switches on the controller. Good luck!
Posted on Oct 17, 2013
2 Suggested Answers
  • 5603 Answers
SOURCE: My Antari Fazer model#Z-300 II
Most fog machines require cleaning maintenance periodically. I would check the fluid lines are free flowing and unclog if necessary.
Posted on Jun 29, 2011
I bought your fog machine ,there was no remote control in the box,how do I get one
what brand and model did you buy...Some come with a remote...some are DMX and are meant to be controlled by a light system board or controller or some type. These typically dont come with a remote....You can always buy a controller or a wireless dmx remote as well.
Oct 10, 2015 | Mbt The Fazer Pro Fog Machine Dj / Stage...
Is the flash sequence of the green fluid level indicator significant? Antari Z-300ii .
I have this one and i know also its features like 700 watt capacity and it is also provides fog fluid separately.
froggys fog
Mar 23, 2013 | Antari Z-300ii Fazer Fog / Haze Machine...
Hallo I have problem with my fazer/ foger after turn ON it starts warming UP normaly and after when its ready works abaut 10 min.than stop working remote control shows WORMING UP but never starts...
It MIGHT be overheating due to buildup. Read in users manual how to clean the machine of deposits. The deposits allow the temp to go too high and initiate a shutdown.
Jul 18, 2011 | Mbt Lighting Fazer Fog Machine
Even with the output turned to maximum the fog is thin and dissipates quickly. I have followed the cleaning instructions within the manual and I am still having this problem. What else could cause this?
A common problem is the use of the WRONG fog juice. Make sure you use the manufacturer's suggested product. Make sure you have the correct voltage. Use of a very long extension or attempting to run on a dimmer box also would cause the problem.
Jun 16, 2011 | Elation New Elation Ice 101 Low Fog...
It doesnt heat , i tested the heater n works fine ,change the termaL DIODE NOTHING HAPPENS, THE WIRE CONTROL ALWAYS HAD GREEN LIGHT ON I HOP YOU CANHELP ME THANKS¡¡
It sounds like you need to take it to a tech. Try a TV repairman rather than a music shop for this, should be cheaper and they will still understand how it works.
May 02, 2011 | American DJ Fog Storm 700 Fog Machine
American dj mini fog, I conected to wall, but the machine doesn't gets hot, and not make smoke, why?
There are two switches/buttons on top... You have to both turn on the unit and also activate it with the second button OR using a remote plugin box. The heater takes a bit of time to warm up internally. You will not sense much if any heat outside the unit... They take a few minutes to come on. Make sure you use approved "fog juice" in the unit.
Dec 18, 2010 | American DJ Mini-fog - 450 Watt Fogger Dj...
Antari Ice Low Lying Fog Machine + Logo
116 people viewed this question
Top Antari Music Experts
Michial Gueffroy
Are you an Antari Music Expert? Answer questions, earn points and help others
