Question about Pool & Spa
Sundance spa my pump 1 doesn't work. It's not humming when pushing the buttons. How can I diagnosis the problem?
    Champion:
  • 305 Answers
Check voltage getting to back of motor. windings or capacitor may be shot
Posted on Dec 05, 2013
I came home I did not hear the pump working so I pushed the button to turn on the jets and they seem to work fine, but when I shut the jets off everything shuts down. Just humming coming from motor.
That is a capacitor. Replace it. If it blows another or hums like that, then get a new motor. Also, see if the motor shaft turns freely.
Dec 28, 2016 | Pool & Spa
Model eco7111 not circulating water through system.
pumps that just hum indicate that the start /run capacitor has failed
replace it or have an electrician or pool pump expert check for a proper diagnosis and quote
May 28, 2016 | Intex Pool & Spa
Sundance spa
sounds like bad temp sensor
Jul 03, 2014 | Pool & Spa
Sundance spa
may be getting water in the blower and the safety bypass is turning it on to blow the backed up water out of those lines..the tub may be too full..
Nov 14, 2013 | Pool & Spa
Aquaflow 07140001-6 hums but can be manually starter
This usually means you have a bad motor. It has found a flat spot on the windings.
You will need a new pump for the fix.
Rod
US Parts Center
Jan 10, 2013 | Aqua Flo Aquaflo Flo - Master Xp2 2 Speed...
Heeeelp! How to hook up hoses on Sundance spa
There is a skimmer in the side of your tub( the part that skimms water off the top ) and what is called a main drain or a better tearm is deep suction that pulls water from the bottom of the tub and helps collect heavy dirt from in the tub these two lines ( three if there is more than one main drain) These will all come together and then hook to the front of the pump. If your filter is under the skimmer basket the top of the pump will go to the heater and then back to the spa. If your filter in not under the skimmre basket then it will come after the pump then on to the heater. So in answer to your second question, the front of the pump draws the water in and the top pushes the water out. But make sure that your heater is last in line so it only deals with clean water and it will not run on the suction side of the pump as it need water pressure in it to start and contious flow to keep it from over heating. Hope this helps.
Sep 25, 2009 | Pool & Spa
Pump does not pump water
Hi there. Not necessarily. Inside the pump the impellor is plastic. Sometines the fins deteriorate to the point where the pump hums but won't move water. Other times the pump hums but won't actually run. The pump is generally fixable. If you are handy you can remove the pump and take it to any pump repair shop to be reconditioned, usually for about $50-75.
Jul 26, 2009 | Waterway 1 Hp 115 Volt 2 Speed Side...
Pool & Spa Logo
60 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
