Question about Garden
Makita gasoline leaf blower acts like it's running out of fuel. Doesn't run at full power and often dies when I'm using it. Machine is 2 years old and has never had any issues. I always make sure that it has "good" gasoline in it, but the problem continues. Any suggestions?
  • 64 Answers
Inside your little carbuator is this little fuel strainer (you need to dismantle the carby to do this) just check it And clean it with air gun replace your fuel lines as they don't last very well any more and tend to melt over time
Posted on Oct 17, 2013
    Sergeant:
  • 224 Answers
Sounds like the carb needs to be cleaned, this is very normal after a while of being used, you should also change the plug and clean the exhaust screen as well
  • Kelly Oct 17, 2013
    You should also check for loose bolts in the head and carb, either can cause this issue, and also check fuel lines for cracks or breaks
SOURCE: Poulan wt200 "wildthing" gas leaf blower
no compression wont start
Posted on Oct 16, 2008
  • 8 Answers
SOURCE: ryobi leaf blower #8544,25.4 cc
I have a McCulloch, that the hose rotted off the fuel strainer in the tank, I replace the hoses, it ran for awhile then stopped, removed the carb. an have cleaned, { 7 Times} it runs for awhile then stops, Usually I dump lighter fluid in the carb. if it starts Ign is OK if not its a fuel problem. You could check on the filter, I still have a problem with mine, its a pain when your on the roof an it stops. so check the fuel filter is the only thing I could suggest to you GOOD LUCK
Posted on Nov 11, 2008
boscia
  • 163 Answers
SOURCE: Leaf blower will not achieve full RPM's
try removing the muffler and scraping out any carbon build up in the exhaust mouth of the block. if that doesnt help you will probably need to replace the carb.
Posted on Nov 29, 2008
  • 211 Answers
SOURCE: leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Posted on Dec 05, 2008
SOURCE: Engine will not reach full operating speed, needs
Need to replace exhaust? Are you for real? Guru of what? Asinine answers?
Posted on Nov 23, 2009
Brand new Ryobi 2-cycle backpack leaf blower. It will not run full throttle. Should I take back and get new one or ?
Take it back. If the new one doesn't perform like it should get your money back and buy a Stihl. They will fuel and run the machine before you ever leave the dealer with it to make sure it runs like it should and they can answer any questions and even get you parts. Husqvarna may do the same thing
Nov 20, 2014 | Ryobi Garden
Poulan 2000 leaf blower shuts down after getting hot (7-10min)
Make sure your oil to fuel ratio is correct. You cannot run it on gasoline alone.
Oct 20, 2014 | Garden
I have the hand held 4 stroke blower and have been having troubles with the full trottle blowing. If i get to that point it tends to bog down and if i dont let off the gas it will die out. I have cleaned...
A good carburetor cleaning may be ion order here. If you can get it, try running some SeaFoam through the fuel system. Check the bottle for the correct amount to use. If you guys don't have that available, try using some Berryman B-12 ChemTool fuel system cleaner in it. The dosage rate on that is about 1 ounce per gallon of gas or so and it will clean. I am trying to help you keep from taking the carb off and manually cleaning it. Try introducing one of those 2 additives to your fuel tank, run the machine and post back if needed.
Dec 13, 2010 | Makita Garden
I have a mikita leaf blower i have had right at a year and used only a few times, it starts and runs but as soon as you try to give it gas with choke on or off it will die. it runs fine with choke on or...
Try changing the gas. Pour old gas out and put new gas in. Make sure the fuel mixture is correct.
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Nov 27, 2009 | Makita Garden
My Homelite backpack leaf blower runs until tank is 1/2 full
thats what it is try opening the gas lid look inside to see where the fuel line lies if its up high them try pushing it down to the bottom
Nov 13, 2009 | Homelite Consumer Products Backpack...
Engine starts easy. Engine can only achieve high
eitrher a clogged fuel filter thats in the tank, old gasoline or the fuel pump daiphragm in the carb has hardened
Oct 30, 2009 | Echo Inc. 25.4 CC Backpack Blower
Troy bilt blower (gas) will not run on full throttle,if I have the choke on will run but as soon as I cut back on choke the machine dies.
I believe you need some carburetor adjustment done or you have some bad gas. The manufacturer's school we have been to this year, told us any fuel over 30 days old is considered bad gas. And in many cases we have found that to be true with the repairs we have had to do.
Good Day.
Oct 07, 2009 | Troy Bilt Tb310qs Gas Blower
Mightylite 26 leaf blower
have you tried changing the air filter and spark plug?
Nov 20, 2008 | Homelite Consumer Products MightyLite...
Craftsman 2 cycle leave blower will not start
That fuel/oil mix ratio should be 32to1 or 32 ounces gasoline to 1 ounce oil. You will have to make up a new mix and probably clean the fuel system and the spark plug before it will start.
Sep 30, 2008 | Garden
Garden Logo
169 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
