Question about Samsung LN40B500 40 40" HDTV LCD TV
My Samsung LN40B500P3FXZA LCD HDTV will change from HDMI/CABLE to PC to HDMI BluRay TO AV to CAMCORDER all on its own. The red light would flicker constantly, as if the remote is being used, but that is not the case. I cannot use my TV remote. Whenever this happens, I would need to manually control the tv by pressing the buttons on the right side of the tv.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 74 Answers
Tv is faulty and need for repair
Posted on Dec 28, 2014
    New Friend:
    Problem Solver:
I experienced a similar situation.Purchased a side button PCB assembly BN9607269A for ~ $10.00 delivered from
https://www.partstore.com/Part/Samsung/Samsung/LN40B500P3FXZA/Samsung/Samsung/BN9607269A/New.aspx
Here were my symptoms:
A. Plug in the TV and it turns on without pushing side On Button or Remote Power Button. (I even removed the remote batteries to be sure)
B. Bottom right Red LED constantly blinking without any input.
C. Volume Maxed out and couldn\'t be lowered with remote or side button.
D. Menu picture selections would all Max out or go to the final choice. With some Side button manipulation using the menu and channel selection buttons, I could temporarily disrupt the constant menu cycling.
Good Luck and be safe; don\'t work on energized equipment.
Archie Stagg
Active US Postal Service Electronics Technician
Retired Electronics Technician US Navy
Posted on Dec 24, 2014
    New Friend:
  • 23 Answers
Probably you have defect mainboard .
Posted on Oct 17, 2013
SOURCE: Samsung ltm1555B - lcd tv blinking on button
I am having the same problem with the blinking orange light
Posted on Aug 31, 2008
SHOGUN125
  • 58 Answers
SOURCE: using my Samsung LCD TV as monitor for my Sony Vaio Laptop
yes sir..i think you must looking and buy VGA adapter 15 to HDMI complete with the HDMI cable set. you can find this adapter at the computer spare part store or electronic part store. not cheap but very usefull for you in the next day.
is very easy to connecting...plug you adapter to the output VGA VAIO.. connect the HDMI cable to adapter (like USB) and the rest to the input at your samsung lcd...good luck..
Posted on Jan 31, 2009
SOURCE: Samsung LN-R408D - No Picture
My Mom's LNR408D also had sound but no picture. I was able to fix it by soldering in a jumper wire across a blown (1.5A ???) SMD picofuse on the "T-Con" board.
Consider attempting this ONLY if you: 0) Know enough to avoid the potentially fatal High Voltage parts of the power supply board!!!
1) Are a fearless hackazoid 2) know what you're doing with a soldering iron and teensie SMD parts 3) are gonna throw the busted thing out anyway so you have nothing to lose and won't be sad if you screw something up.
4) Know enough to avoid the potentially FATAL High Voltage parts of the power supply board!!!!!
This board is at the top center under a close fitting RF shield. The suspect part was labeled "CP" on the board and marked with "P" on the part. It is visible above the right-center of the connector from the main board. An ohmmeter showed it as open, so I bypassed it with a jumper wire from connector VIN to the hot side of C13. One image shows the suspect part and the jumper in place.
The other shows the TCON board placement top-center (under its RF shield). With care, it seems possible to test the fuse and put the jumper in place without removing the shield. (Obviously don't touch anything else with the VOM leads!)
Thanks to ZORBUS and Steve's TV and Electronics for the idea.
http://www.avforums.com/forums/lcd-televisions/892447-no-picture-but-got-sound-my-samsung-lcd.html
http://www.gesda.com/transformer/Fall08_files/Page336.htm
Steve C
Posted on Sep 22, 2009
lightnbaby
  • 36 Answers
SOURCE: hi my samsung lcd tv model le40s8, it won't switch on
if you can do soldering work, replace two 1000uF10v bulging capacitor with 1000uF 16v or 25v in powersupply board. you will save $200.
Posted on Nov 12, 2009
  • 304 Answers
SOURCE: my 32" Samsung lcd tv won't turn on, led is solid red
The Main bd is bad. It is not sending a turn on signal to the power supply.
Posted on Apr 16, 2010
Hi,I have a XP-65DHD RUNCO PLASMA DISPLAY when I want to play a blu-ray movie on 1080p the screen starts flickering so I have to watch the movies on either 1080i or 720p,I really don't know what to do
If you got a blueray player (the hardware) it should have come with a disk with software. If you got the OEM version without, you need to buy your own software. PowerDVD should work. If you are somehow looking to download something to play bluray disks on a PC without an actual bluray player, you need to buy the drive.
Mar 21, 2014 | Runco CW42i 42 in. HDTV-Ready Plasma...
Dynex 32" 720p Flat-Panel LCD HDTV - Matte Black Logo Print Email Problem with Dynex 32" 720p Flat-Panel LCD HDTV - Matte Black I have a Dynex Bluray Player and when I connect it with AV Cab
If the item is under warranty return it asp. The problem is in the power supply, the cause is a open capacitor sometimes leaving a bulge at the top.
Apr 25, 2012 | Olympus Televison & Video
I have a VR-6025Z 60"
unplug TV and Bluray power cords from wall socket, replug HDMI cable in both units, replug power cords back in, turn them On and check.
Let me know how it worked. it seems Bluray player set its display resolution bit higher that TV doesn't support.
Please connect Bluray in TV by usual AV cable (yellow-red-white) and go to BD player setup menu and reduce HDMI Out resolution like 1080p to 1080i, then check it in TV HDMI input.
May 14, 2017 | Westinghouse LVM-42w2 Television
My sansung pn50a460s4dxza says it is 3d ready. how can i use this feature on my tv.
Your tv is a 2008 model, legacy 3d tv and requires a lot more than a current 3d HDTV does to view 3d. Today with a current 3d HDTV, Normally you only need a 3d source like a 3d Bluray movie and 3d glasses from Samsung and a HDMI cable connection from bluray player to HDTV. See below for your TV. You need a PC and IR emitter and Samsung 3d glasses plus user selected options on the tv.
Samsung 3-D Ready HDTV How do Samsung 3-D Ready HDTVs work?
Samsung 3-D Ready HDTVs are enabled by Digital Light Processing (DLP(R)) or Plasma Display Panel (PDP) engines that are capable of very fast refresh rates (120Hz). The inherent speed of these display technologies enables high quality stereoscopic 3-D by alternatively displaying left and right eye images. The display is synchronised with 3-D shutter glasses to provide the observer with a vivid perception of depth.
How do I connect my PC to a Samsung 3-D Ready HDTV?
The DVI output from the PC's graphics card must be connected to the TV's 3-D compatible HDMI port using a DVI-to-HDMI cable (or a HDMI cable plus a DVI to HDMI adaptor).
Alternatively, some newer graphics cards have a HDMI port instead of a DVI port. In this case, simply use a HDMI cable to connect the PC directly to the TV.
On all models, the 3-D compatible HDMI port is identified by the letters "DVI". (eg, "HDMI 3/DVI IN" or "HDMI 1/DVI IN")
What other equipment do I need to enjoy 3-D on my 3-D Ready HDTV?
  • Windows PC with DVI output
  • Compatible 3-D Shutter glasses and IR emitter with VESA compatible sync connector
How do I connect the IR emitter to the 3-D TV to support wireless 3-D shutter glasses?
The IR emitter should be connected to the "3D SYNC OUT" socket. The emitter should be placed on top of the TV with the LEDs facing towards the room. How do I turn the TV into 3-D mode?
Ensure that the TV source is set to "HDMI 3/DVI" (or "HDMI 1/DVI" for 720p models).
Plasma HDTVs Press the Tools button and select 3D Effect. Update from Off to Mode1.
May 04, 2011 | Samsung PN50C430 50Inch 720p Plasma HDTV...
How to tune in for blu ray dvd
You do not tune in your Bluray player but connect using an HDMI cable or Composite cable. If you have a HDMI cable connect the Bluray's HDMI out to the TV's HDMI in at the back and using the TV's remote switch the Input source to HDMI. You will see the image from the Bluray player in high definition.
If you don not have a HDMI cable connect the composite out of the Bluray player using the Yellow/Red/White cable to the TV's composite input ( same three color sockets ) and switch to AV input on the TV. Using this connection won't give you high definition image but will work OK.
Apr 23, 2011 | Sanyo DP32746 32 in. LCD Television
Issues with LG 26LE5300 26 in HDTV LCD TV Both audio & video flicker off & on when connected to PC via an HDMI cable. No problem when in TV or AV (DVD) modes. PS. worked fine on Day 1, did not...
Reduce the resolution of the PC to 1024 x 768. This can be done by right clicking on the desktop ( not any icon ) click properties / click settings / slide the screen resolution pointer to 1024 by 768 / slick apply / Computer will ask if you want to save this setting /Click yes and then try connecting the TV to the HDMI port. Should work
Mar 11, 2011 | LG 26LE5300 26 in. LCD HDTV
I have 4 samsung tvs. I want to connect camcorder
Get an RCA cable and connect the following to the back of your HDTV:
Yellow - Video
Red- Right Audio
White - Left Audio
The other end should be compatible with the Audio-Video output of your Camcorder... Like a small av-jack.
Jun 12, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
How to connect motorola cable box to samsung dvd/vcr model vr375 to a Westinghouse hdtv with 2 hdmi connections
The DVD-VR375 does not have an HDMI input. The connection should be:
• RED WHITE & YELLOW CABLE from your cable box (AV OUT) should connect to the DVD-VR375 (AV IN 1). Set the DVD-VR375 to AV 1 using the INPUT SEL. button.
• Next, connect an HDMI cable from the DVD-VR375 (HDMI OUT) to the TV (HDMI IN). Set the TV to the proper source.
This connection would allow the recorder to work as a pass through and will let you record TV programs as well as watch your cable channels.
Hope this helps!
Jul 06, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Samsung LN40B500 40 40" HDTV LCD TV Logo
446 people viewed this question
Jerry Greenberg
Jerry Greenberg
