Question about Genie Company Televison & Video
Both of my intellicode remotes stopped working. When I tried to reset them, nothing happens. They are still not working.
    Top Expert:
  • Genie Company Master
  • 12,223 Answers
Test use the digital camera or cell when you hit any key the LED must be ON see the picture attached.. Otherwise open the r.control and clean the keypads for dirty, oxide, etc use contacts cleaner.
God bless youboth of my intellicode remotes stopped working. - aedd3001-c897-4ae6-ade3-dd8e7913c26d.jpg
Posted on Oct 17, 2013
Garage door will not close
if you can hear the motor running but nothing is happening then the internal gears may be stripped. if the motor does not run then it is electrical and could be several things.
Mar 07, 2015 | Genie Company Genie Gictd3 Three Button...
GT3-R -can
This is a dual frequency transmitter. (315/390) You need to select one button to program the TYPE 1 frequency of 390 MHz. Here's how:
Backwards compatable programming instructions for GT3-R dual-band remote: This is a 3 button remote, which can be used to operate up to 3 garage doors using IntelliCode radio controls. This remote is defaulted to operate the new IntelliCode 2 Genie garage door openers, but you can also program individual buttons to operate other IntelliCode 1 (pre 2011) models of Genie garage door openers made from 1998 to present. To change a button to operate a pre 2011 IntelliCode opener, the default IntelliCode 2 setting must be changed to IntelliCode 1. An LED light on the remote displays which mode the remote button is in: Red = IntelliCode 1 / Green = IntelliCode 2 To set one of the 3 buttons to be IntelliCode 1 (red), follow the instructions below:
  1. Select a button on the remote that has not been programmed.
  2. Press and hold that button for 10 seconds. Both Red and Green LEDs come on and stay on.
  3. Press the same button twice to toggle IntelliCode selection from IntelliCode 2 to IntelliCode 1.
  4. Press the same button again to confirm toggle. the LED should be Red. The IntelliCode selection for this button is set to IntelliCode 1.
You are now ready to program the remote to your garage door. Follow accompanying instructions for "Programming to IntelliCode 1 Genie garage door opener," or see below instructions: Programming Instructions: Gently press the Receiver Learn Code button on the power head receiver of your Genie garage door opener (motor head on ceiling in garage). This small, black, unmarked button is located behind the light lens at the motor head and is nearest the floppy 6 inch antenna wire that protrudes from the motor head. When pressed, a radio signal indicator light will start blinking red for 30 seconds. After pressing the Learn Code Button, press your transmitter button twice for your system to grab the frequency and code it in. (Keep the transmitter you're tuning at least 2 feet away from the power head while tuning.) Press the transmitter button once more to test the system and start your door moving.
Jan 06, 2012 | Video Game Consoles & Games
I have the gict390 - 1 button--- it used to work on my garage - doesn't anymore. Wife's remote still works. Tried reprogramming - didn't work. The led on it still works & haven't had it that long...
My remote stopped working and the light still came on as well. Replaced the battery and it's working again. Try the battery. Tip: when I took the shell apart, I had to take the circuit board completely out of both halves of the shell to get to the battery.
Sep 14, 2010 | Genie Company IntelliCode GICT390-1BL...
Genie Garage door will not close. Receiver Model: ACSR3 FCC ID: BBQ ACSR3
If you hit the button on the remote and nothing happens then you may need to code in the remote. On the motor head press the learn button and then press the button on the remote 3 times.
If it looks like the remote will work the opener or it opens the unit but not close it you are experiencing safety sensor problems. Make sure they are aligned. There will be a light on each and each should be on. Check the wiring to them too. They are not polarized. Thanks BB
Aug 20, 2010 | Genie Company Genie Intellicode 1-Button...
Genie Compact 3-Button Remote control will only open 1 door/not 2
On some of the remotes you will find a toggle switch to change frequencies, this might help. Note all new openers are operating on a different frequency than slightly older ones due to military interference. Even though both might be intellicode they might not work together on the same remote. Sometimes some openers are harder to program than others. So lets try to program the harder one. You need to find and press the learn button on the motor head. Then press the button on the remote once. The led light by the learn button should not flash. If so try it over. The light should either stay lit or go out after the first press. If it does press it again and then a third time. If it ever flashes during the program process try again. The third or fourth time the motor should operate. If not you either have a bad remote or more than likely a bed logic board. Thanks BB
May 15, 2010 | Genie Company IntelliCode GICT390-1BL...
Stolen remote solution
CLEAR ALL CODES
HOLD DOWN THE LEARN BUTTON UNTIL IT FLASHES (ABOUT 20 SECONDS).
PROGRAM YOUR REMOTE AGAIN.
Jan 02, 2010 | Genie Company Genie Intellicode 1-Button...
Garage door opener stopped working I replaced batteries in the remote the door bell button starts the motor but the chain does not engage Does work manually
Perhaps you pulled the emergency release cord to release the drive mechanism from the chain up on the track. Push the cam lever back up to reengage the drive follower to the chain. BJ.
Dec 31, 2009 | Genie Company IntelliCode GICT390-1BL...
My Wii remote stopped working.
Just sounds like the batteries are dead. To me the wii seems to tear through batteries pretty fast. Hope this helps.
Jan 19, 2009 | Nintendo Wii Console
Genie intellicode garage door opener
see if there is a reset button anywhere on the unit.you can try calling the manufactuer and ask, or troubleshoot from the manual.
good luck.
wg
p.s you can also try leaving it unplugged for 30 min, then trying it out again.
Feb 14, 2008 | Sears Craftsman LiftMaster Chamberlain...
Televison & Video Logo
49 people viewed this question
Top Genie Company Televison & Video Experts
Dan Apthorp
Leonard Manamela
Leonard Manamela
Are you a Genie Company Televison and Video Expert? Answer questions, earn points and help others
