Divide 844 by 4 use the distributive property to draw a bar diagram
6 divided by 2/3 + 1/2
First add 2/3 (4/6) + 1/2 (3/6) = (7/6) = 1.1666
6 divided by 1.1666 = 5.1431
Oct 03, 2017 | Office Equipment & Supplies
99 cadillac battery draw
You have to find out what all is on those fuse's and isolate the circuits till you find the draw . Looking at a electrical distribution chart would help ! Free diagrams at http://www.bbbind.com/free_tsb.html
After entering vehicle info . under system click on electrical distribution , then under subsystem click on fuse panel . This will tell you what all that fuse power's up . Disconnect componets till draw goes away . Could be a bad BCM or some other module not powering down .
Dec 08, 2016 | Cadillac Cars & Trucks
How do you find a total number of a percent in a word problem
Divide 100 by 40. You get 2.5. Now, multiply 30 by 2.5. You get 75, which is the percent of distributed flyers.
Jan 02, 2015 | Office Equipment & Supplies
How do you draw a tape diagram of 12 divided by 3 times 3 equal 12
Your question is in the wrong section. Look for something under math help. 12/3=4, 4x3=12 I am not sure what your teacher is looking for, but I think I would draw a circle with 12 at the top, 3 at the 3 o'clock position, a 4 at the 6 o'clock position, and a 3 at the 9 o'clock position. then put a division symbol between 12 and the 3, an = between the 3 and 4, an x between the 4 and the 3, and an = between the 3 and the 12.
Sep 12, 2014 | Cars & Trucks
5I+5(I-31)=55 how do i solve this
Start by using the distributive property to expand the term 5(I-31)=5*I-5*31=5*I-155.
Rewrite the equation as 5*I+5*I-155=55
Combine the terms with I, this yields 10*I-155=55
Add 155 to both sides of the equation 10*I-155+155=55+155
you now get 10*I=210
Divide both sides of the equation by 10
(10*I)/10=210/10
Cancel the 10's on the left and divide 210 by 10 to get 21
Thus I=21
Basically you use the priority order of operations BEDMAS backwards
Feb 13, 2013 | SoftMath Algebrator - Algebra Homework...
1994 chevy c15 power distribution diagram
Go to autozone website they have wiring diagram available online
Feb 03, 2013 | Chevrolet C1500 Cars & Trucks
Underhood fusebox fuse #13 50 amp what is it for
The large MAXI fuses in the engine compartment fuse block are the MAIN fuses. They supply voltage to several other fuses or circuits.
MAXI Fuse #13 in your 1996 Ford Ranger is supposed to be a 30 Amp fuse (not a 50 Amp) according to the power distribution diagrams as well as the fuse block detail diagram. This fuse supplies voltage to the Powertrain Control Module (PCM) power relay and to the oxygen sensor heater circuits.
Please note that it is NORMAL for this fuse to cause a draw on the battery during vehicle operation and also after engine shut down. The OBD-2 oxygen sensor heater circuit monitors run after engine shut down and key off. This can take up to 45 minutes to complete. After the O2 heater monitor has run, the PCM will go into sleep mode.
When the PCM goes into sleep mode, the battery draw from this fuse will be reduced greatly. If you are performing "ignition-off-draw" tests trying to figure out why the battery keeps going dead, it is best to use an ammeter that has a 1 or 2 amp scale. You should set-up for the test using a shunt bar. Wait for 45 minutes to an hour for all of the computer systems in the vehicle to go into sleep mode, then open the shunt. Your computer memory, radio pre-sets, clock, etc. will continue to draw without ever shutting completely off. Any draw under 300 Milliamps is considered "acceptable". It is my experience that most vehicles have an ignition-off-draw of somewhere near 150 Milliamps.
The underhood fuse box diagram can be found on page 314 in the 1996 Ford Ranger Owner's Manual.
If you do not have an Owner's Manual, you can get a PDF version HERE (direct link)
May 15, 2012 | 1996 Ford Ranger SuperCab
When I turn on my tv there is a white bar going verticaly on the left side. The rest of the screen is red and none of the functions are working. I cant change video feeds or get any of the menu to come up....
Optical Assy block/Light Engine.PN# A-1606-039-A
Encompass Parts Distribution they have Free Service Manual for this Model and Parts.
1-800-638-3328
UED 1-800-648-6657
PTS 1-800-844-7871
Jan 14, 2011 | Sony Grand WEGA KDF-60XBR950 60" Rear...
I need to produce a diagram of a typical wiring system for a small factory showing the arrangment from the incomeing service cable to a 3-phase motor, with seperate distribution to lighting and other...
Are you asking how to draw it like CAD or what to include in the diagram. I would hate to ask why you have to produce this diagram. This type of diagram is always furnished with the complete electrical drawings of a facility when built. To produce an ACCURATE diagram is not so simple. Normally you would also include the wires sizes, conduit sizes, and panels and sub panels as well as main trainsformer size. If this diagram is to be used to say calculate available fault currents for an arc flash study, it should only be done by an experienced individual, such as an electrical engineer. Are you getting paid enough for this responsibility?
Apr 21, 2010 | General Electric GE ELECTRICAL TQD22200X2...
I must create scale diagram of my kitchen on a
Convert your meters to centimeters and divide by 20. That gives you 1/20 scale
Oct 15, 2009 | Kitchen Appliances - Others
Computers & Internet Logo
153 people viewed this question
David Payne
David Payne
