Question about Welding Tools
200 maxstar str 200. Dosentwork...light dosent come on and makes. A humming sound
3 Suggested Answers
SOURCE: I have a miller maxstar 140 str that does not work
i have a miller 210, when i pull triger it makes clicking noise and does not feed wire, then when i pull trigger again it works, does this sound like a gun problem or controller problem
Posted on Feb 20, 2010
  • 23 Answers
look for a reset button or fuse
Posted on Dec 17, 2010
Why is there low humming in the receiver sub channel(only?)
Sounds like a shorted capacitor in the sub out circuit.
May 04, 2015 | RCA Audio Players & Recorders
Hel -10 on max star 200
The Help 10 code on a Miller Maxstar 200 indicates a depressed trigger. If it still doesn't clear, replace the trigger control.
Jul 29, 2014 | Miller Welding Tools
Str-de985 humming noise only when using FM tuner. Everything else works fine with no humming noise
Have you got a FM Antena hook up to it for the FM ,Sations, If not that could be causeing it to hum.
Dec 06, 2012 | Sony STR-DE985 Receiver
Humming sound from woofer
If there is humming , disconnect the powered Sub input to the receiver
If humming stops, check the cable connector and replace
only if necessary.
Oct 14, 2012 | Sony STR-DE685 Receiver
I have a Sony STR-DG520 5.1 receiver. My problem is that I can hear a high pitched background whine from all the speakers, even if the volume is set to zero or muted! If I switch the audio source off, the...
do u have the unit earth grounded? sounds like AC hum, most amps have a ground lug, make sure that is grouned and the power plug to o the amp has a good ground.
Jun 15, 2010 | Sony STR-DG520 Receiver
I have a miller maxstar 140 str that does not work I get no weld output. the ready light comes on initially then fades and blinks once.
Feb 03, 2010 | Miller Welding Tools
Engine turns over but dosent start ? 1997 ssei
my first guess would fuel pump have some turn the key in the on pos, while u stand buy fuel door must be quit around you you should hear a light humming sound coming from fuel tank area the humming is the fuel pump also check fuel pump relay in under hood fuse panel hope this helps
Oct 02, 2009 | 1997 Pontiac Bonneville
98 chevy cavalier (humming sound)
ck pwr str fluid for low level no 2 sounds like wear detector on brake pads. tire wheel off ck pads see it wear indicator is in contact with rotor
hope2help shack
Mar 23, 2009 | 1990 Honda Accord
STR-V444ES just hums
Sounds like the output stage is shot.
Here are a few things to try. If there is an option in the manual to reset the unit to factory settings, try that.
If that doesn't work, disconnect all of the peripherals, and select the radio. If you get sound there, you may have a bad cable.
Beyond that I would say the amp needs repaired.
Cheeres
Jan 01, 2009 | Sony STR-V444ES Receiver
Welding Tools Logo
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
