Question about Whirlpool Washing Machines
We have a whirlpool washing machine model no 6 A- SQ8000MW. It is 2 years old & from the time we bought it we have been unable to balance it. We have had it in for service twice for this problem with no change. There is nothing wrong with the washing cycles but we are worried about the long term damage to the machine by being off balance. Can you help? Kelly Seccombe. kellyseccombe@gmail.com
    Master:
  • 818 Answers
-you took it to them?-did you buy it from someone you dealt with before or was this a lowes-homedepot purchase. If the tech told you nothing wrong did he check it in your home the reason I'm asking because of the higher speed spin on newer models the floor has to be very solid beaneth the machine-also the feet need to be adjusted to give it a firm foundation. now assuming you've already done this, there are a series of springs that dampen the tub-you may have something out of wack in that department-you may want to try a different repair man. I hope this helps, its sooo frustrating these days to try and get anything done-cheers Denny
Posted on Oct 17, 2013
Testimonial: "Thank you for your help but someone on this site said to loosen the forward backward spring- this only made it worse. We are on a property in the middle of Queensland & out here we have to be able to do most things ourselves but this has us beat & we can't take it back to town again as twice they haven't been able to fix it. Kelly"
  • 11 Answers
SOURCE: Kenmore Waher spin cycle out of balance
Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
Posted on May 20, 2007
Bob Gemmell
  • 209 Answers
SOURCE: Miele washing machine model W713 front load - issues
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
Posted on Sep 13, 2007
futureloginn
  • 734 Answers
SOURCE: THE WASHING MACHINE IS LEAKING A OIL LIKE FLUID UNDER THE MACHINE?
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
michiganfan9
  • 179 Answers
SOURCE: Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Posted on Dec 30, 2008
  • 106 Answers
SOURCE: Loud banging noise durning washing machine spin cycles.
First plug off the wall. Open the machine from behind to examine if any shock-absorbers(known as dampers) or springs have come off or broken. Your dealer could help with spares. But you could do the job yourself.
For spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Posted on Mar 02, 2009
Model # SM 8280867 How old is this model?
6 - 10 years in 2012
Whirlpool Washer Ultimate Care ii - Appliance Repair Forums www.applianceblog.com/.../32099-Whirlpool-Washer-Ultimate-Care-ii
  • LAST UPDATED: 2012-05-28
  • 6 POSTS
  • FIRST POST: 2012-05-28
Whirlpool Washer Ultimate Care ii Model Number: SM 8280867 Brand: Whirlpool Age: 6-10 years Hello, The washer ...
Jan 27, 2016 | Washing Machines
Hi 2 years ago I bought a BUSH washing machine model A1249RLB after having the machine for about 6 months the counter balance weight came off in the middle of a cycle destroying the machine I contacted...
my advice is simple if your disabled like me they contact your local reclimation yard center,,,, there are many across europe they will take your old machine away and provide you with a front loader machine refurbished i can help you via a local charity who will help too get it fitted email me at vsmlibs@talktalk.net i can help you source a machine locally for free exchange ...
this isnt good enough im sorry youve had to ask for help here!!
Mar 05, 2015 | Washing Machines
Load pop when running ,shuts down,smoke from back,burning electrical
You have a tub "Balance" bearing that is Shot! Goner! Dead! And your Tub may be a goner too! Depending on the extent of damage, you said you saw SMOKE! I never seen smoke from a washer unless someone throws a Concrete Block Stone in one on You Tube! ON PURPOSE! You have to weigh the age of machine vs the price of a new/USED one. If your machine is over 7 years old. Get a new One! Not a LG for goodness sake. Get a Whirlpool or a Maytag. I just bought a used one (Whirlpool) for $150. Still works 2 years later right next to the Dead $1600 LG I bought 6 years ago! The man I bought it from is in Rosamond, Ca. right by Edwards AFB. He has a garage full of them and guarentees his machines. There are a lot of people that do this. New is Not always the best!
Dec 26, 2013 | LG WM-2032H Front Load Washer
How old is the Whirlpool washing maching model # LSQ9549PWO...ser CR3028092?
July 19, 2004. go here and you can tell how old any appliance is by putting in the model,serial numbers and brand name.http://www.appliance411.com/service/date-code.php
Jan 24, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool 6th sense washing machine- door light keeps flashing & it will not start the cycle,have to turn off the machine for the door to open .the machine is 4yrs old nxt month.
Hi could be 2 things
Motor brushes worn but at 4 years old unlikely
Or as mine turned out to be dry joints on the controller board just fixed it tonight I also replaaced the brushes on the motor as my machine is 6 years old and were worn
Both jobs are easy thanks hope this helps
Jan 31, 2011 | Whirlpool AWM6100 Front Load Washer
Whirlpool LSB6300 died mid-cycle now only clicks
HOPE THIS WORK, DON'T FORGET TO RATE ME
  • Timer is fried.
  • Washer went off-balance and tripped the off-balance switch.
  • Dec 28, 2008 | Whirlpool LSB6300PW Top Load Washer
    Off Balance
    1. Check all the filtration system...ie pump and all hose's and connetions there after...one of the most common is a coin where the drain hose connects to the back of the machine.
    2. Age of the machine could mean the suspension is getting soft...only fix is 4 new suspention rods.
    3. Balance switch Adjustment..most modern washers do not have this thou...not sure for your model
    Jan 03, 2008 | Admiral AW22 Top Load Washer
    Whirlpool washing machine
    check if the springs for support and leveling are in good condition and mounted properly039ec06.jpg1bd62d6.jpg
    Dec 28, 2007 | Washing Machines
    Washing Machines Logo
    Dan Webster
    Dan Webster
    Sal De
