Question about Icon Image 17.5 S Treadmill
I have an Icon Image 17.5 treadmill that has began skipping (or stalling) when running on it. We were told (because we don't have the manual) to add paraffin wax to the board. We got the professional kind...the powder, and applied. However, now the belt just STOPS when pressure is applied and the board no longer feels slick. What can I do to get my treadmill working properly? please help!
    Top Expert:
  • Icon Master
  • 12,223 Answers
See the video attached. Lube the rollers bearing front +back.
However if the problem persist time to replace the old board deck.
God bless you
Posted on Oct 17, 2013
I need a prts manual for an Image 17.5 S treadmill. Specifically i need a right end cap.
Dear Sir:
Please go to the next webs: www.manualsfactory. com + fitness.manualsonline.com + www.iconservice. com for free download.
if you want pay try this www.fitnessrepairparts.com .
sincerely. God bless you.
Ernesto Cuadra
Managua, Nicaragua. c.a
Mar 05, 2012 | Icon Image 17.5 S Treadmill
I have a Image 15.0 R treadmill. It skips and I tried tightening the belt 1/4 turn as directed and not over tighten it. Still skips and actually squeaks now especially when running on the treadmill at 6...
3 different possibilities in my opinion:
belt is too loose, belt is too tight, belt is worn out.
Try to lift the belt and get your hand under it in the middle of the deck. If you cannot reach, it is possible that your belt is too tight. Another clue for this would be the belt "curling" on both sides at the edges. Try to loosen the belt, gradually and testing it along the way.
If on the contrary you can easily slide your hand under the belt from one side to the other, it is more likely that the belt is too loose. The squeaking might be due to the belt not being "square" on the deck. Try to loosen it even more until you can slide it with your hands across the deck. And have it aligned evenly at the front and back. Then retighten and adjust the tracking at low speed.
!!! Do not over loosen as the bolts might come out of the back roller.
A worn out belt might squeak and skip when its old.
Mar 04, 2011 | RTO Image 15.0R Treadmill Walking Belt
My belt is skipping. How do you tighten it and does it need oil
Lubrication will not stop the belt from slipping. If you do lubricate it, do not use oil, use whatever is recommended by the manufacturer, probably silicone.
It is likely your belt is stretched to the point that is needs replacement. You can order a new one through Treadmill World
Oct 05, 2010 | Icon Image 17.5 S Treadmill
My 17.0 R image incline stuck in the highest mode, how do I bring it down.
If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
Jun 14, 2010 | Icon Image 17.5 S Treadmill
Belt squeaking and hesitating when I run
Before beginning this repair: Check to make certain that the drive belt requires adjustment. Check out belt slipping instructions or with the motor cover removed, walk on the belt normally and try to stall the belt to make it slip. Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley.
Step 1- Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust. Step 2- Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt(s) but do not remove. Jack bolt models will have flat mounts and may contain up to four bolts. Step 3- Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with this bolt, skip to Step 4. If your treadmill is equipped with this bolt (very few are) the repair will only require one person. Using 2 7/16" wrenches, make a few turns to this bolt, tighten the bolts from Steps 1 and 2 and test your treadmill for slipping. If belt continues to slip, repeat Steps 1, 2, & 3. If a second attempt does not repair the problem, skip to Step 5. Step 4- If your treadmill is not equipped with a bolt as described in Step 3, the drive belt must be tensioned by hand. While one person applied increased tension to the drive belt, the other person should tighten the motor set bolt(s) that are described in Step 2. Tighten the bolt from Step 1 and test. If the problem is not corrected, repeat Steps 1, 2, & 4 and retest. If problem persists, skip to Step 5. Step 5- If you have arrived at this step, let's make sure you have a drive belt tension problem. With the motor cover removed, walk on the belt normally and try to stall the belt to make it slip. Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. the problem. Another possibility is that the drive belt has worn down. In some cases, belt dressing may help correct the problem. If not, the drive belt must be replaced. Step 6- The belt should be able to be turned by hand at approximately a 90 degree angle from its normal operating position
Jun 02, 2010 | Proform Exercise & Fitness
I have a Image 15.5 Treadmill, it turn on, Incline...
First we need to do a calibration follow this procedure
Press the Stop and the Speed Up keys down while inserting the safety key.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
Press either incline key and the incline will calibrate automatically.
THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED. After completing calibration of incline, press the Stop key and then remove the safety key.
If the incline moves but you it will not operate normally nor calibrate, check the wiring from the incline sensor to the power board. If all looks normal, put it back in calibration and see if you see a blinking “- -” symbol in the incline window when you are calibrating. If not, the incline sensor is bad call icon Fitness @ 800-999-3756, they may have the sensor or they tell you, you need to replace the incline motor
May 21, 2010 | Icon Image 17.5 S Treadmill
I have an icon image 12.0Q that is 8 years old. The front roller began squeeling and catching during the firt few minutes of use. Any idea if it can be fixed and if it should considering the age?
I would consider the age it may start nickel and dime you to death on the other hand if you can get a year or two out it for minimal cost it might be worth it!
go to iconfitness.com go to customer service then replacement parts then make your decision
Feb 28, 2010 | Icon Image 17.5 S Treadmill
Image 10.0 treadmill incline not working
You have a stripped drive gear on the lift motor, order a new incline motor, install it and then calibrate it and you should be fine.
Apr 26, 2009 | Icon Exercise & Fitness
Icon Image 17.5 S Treadmill Logo
136 people viewed this question
Top Icon Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Alienware X51
Alienware X51
Level 1 Expert
Are you an Icon Exercise and Fitnes Expert? Answer questions, earn points and help others
