Question about LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher
LG dishwasher won't power up, but there is power to the machine.
  • Chad Helgemoe Oct 18, 2013
    Fixed. I took the front panel off and checked all the wires. Two of the wires had busted from being bent to many times opening and closing the door. Stripped and replaced. Back to working order.
    Master:
  • 492 Answers
Check to see if there is a fuse near the electronics board.
Posted on Oct 17, 2013
LG dishwasher LD1419W2 which would not fill -error code IE. I replaced the inlet hose complete. Now it has the error code FE and the water overflows onto the floor when in wash cycle. Peter
Try resetting by:
turn off dishwasher
trip circuit breaker to remove all power to unit
wait 30 seconds
restore power
start dishwasher
the drain pump should start and drain all water then start a cycle. Good luck
Nov 14, 2017 | LG Dishwashers
We have a LG Dishwasher. The first time it worked perfectly. The second time the machine started with the cycle and the tripped the power. What is the problem?
When in the cycle did the circuit-breaker trip? In the first few seconds, or after running successful for awhile?
Sep 21, 2017 | LG Dishwashers
LG Invertor Direct drive dishwasher - how to stop a cycle before it is finished and drain the machine
just turn power off and back on hit start it will drain first b4 new cycle starts
Nov 29, 2016 | LG Dishwashers
Power button will not turn on dishwasher.
Make sure that power is reaching the control panel of your machine. Many people are offended when I tell them to check the fuse or circuit breaker to make 100% sure that the machine is receiving power.
If it is receiving power and not switching on, you will have to have the main control PC Board checked, out as this controls the entire machine. This is rather left to experienced persons.
Jul 27, 2014 | LG LDS5540BB Semi-Integrated Dishwasher...
LG Dishwasher LD-1420T1 Tripping the main Power Board
Looks like the pump motor is drawing lot of current and tripping the circuit breaker. Need to check if there is any water inside it. Or simply the capacitor is leaky and causes motor to draw current.
See this part.
http://shop.onlineappliancespares.com.au/part/4681ea2002f-134640/43518
Apr 07, 2014 | LG Dishwashers
LG dishwasher model # LDS5811ST won't turn on
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then try to reset the dishwasher control by pressing the HEATED DRY button and hold it for 15 seconds, if its still not resolved then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 31, 2011 | LG Dishwashers
My VZ9996U1 built-in dishwasher won't lock &
sounds like the door latch is broken, turn off power to unit and remove in side of door, about 20 screws, at th etop of th edoor you will see the latch it will have several wires going to it, you may even find broken parts (PLASTIC ) you can order parts from here http://www.appliancepartspros.com/ they have very fast shipping you just need all the info on the machine
Jul 27, 2011 | De Dietrich 24 in. DVI100 Built-in...
LG dishwasher shuts off, power failure
Did your problems get resolved? I would love to hear what you found. OK?
Jan 06, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Dishwasher not responding to "power"
Check the door switch. THis will kill all power to machine.
Jul 03, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Trouble code LE
I believe that your error code is "IE". If so,its relates to water input problem Check first the filters on the inlet water line (both sides). Then, if problem still exist - check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)). If it doesn't work, test that it get power. In case it get power and doesn't work - You should replace it. Be aware you should disconnect the power cable from machine before doing it !!!! Good luck
Sep 13, 2007 | LG 24 in. LDS 5811ST Stainless Steel...
LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher Logo
100 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
