Question about Refrigerators
LG fridge is not working. NOT COLD in FREEZER or REFRIDGERATOR LED in main circuit board keep flashing
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 109 Answers
Look for a reset button, and try resetting . If compressor , is working and still not cooling , check refrigerant gas.
Posted on Oct 17, 2013
Testimonial: "How do I check the check refrigerant gas."
  • Oscar Netto
    Oscar Netto Jun 13, 2014
    Sorry you cannot check refrigerant gas without a set of gauges and a welding set. Better get your local technician in.
4 Suggested Answers
Trifect7
  • 57 Answers
SOURCE: refridgerator not very cold
It could be some many things, to save time let me give you this check list:
Do what you feel qualified to do.
If you found this helpful please Vote. Good Luck!
Posted on Mar 04, 2008
SOURCE: whirlpool gold refridgerator light not working and is making funny noise
I had the same problem. Model Number GS5SHAXNL00 Light wouldn't work on the fridge side and the led's wouldn't light up. Ended up being a blown circuit path on the control board.
All I did was soder a wire between the 2 points that path was connecting and *BINGO* the lights are back on!
Hope this helps someone. To find the burned out spot just look for a little black smudge on the white plastic case when you remove the board.
Posted on Feb 24, 2009
  • 37 Answers
SOURCE: electrolux fridge freezer.FRIDGE NOT COOLING?
i checked out a different website and got my solution straight away.
Posted on Jan 09, 2010
LG LED LN5200 3 LED strips flash 3 do not. I do have sound and can see screen with flashlight and red power LED flashes 3 times.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Dec 25, 2016 | LG 47 Inch LED TV 47LN5200 LN5200 Series...
Kenmore Refridgerator/Freezer does not work.
check your damper vent door located between the fridge and freezer and make sure its opening up to let cold air into the fridge,also check the evaporator fan motor and make sure its operating to blow the air around the inside of the unit
May 23, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Maytag wide by side MZD2667HEW freezer works fridge does'nt
Was it the damper control you replaced and it's still not adjusting the vent(damper)? And is the cold air from the freezer being blown through the vent by the fan in the freezer.
The circuit board mainly controls the defrost timing and the fans. I don't know that it would solve your problem.
Sep 21, 2009 | Maytag MZD2667HE Side by Side Refrigerator
LG French door fridge freezer not freezing
hopefully you looked out back ...rear lower panel and checked little white condenser fan running...it really needs too to keep temp stable across the condenser coils and no overheat condition to the compressor.hopefully you wont need the $300 circuit board like I just bought
Jun 26, 2009 | LG LFC20740ST Stainless Steel
Freezer in nice and cold but refridgerator is not
due to lots of moisture in the air or high humidity it creates extra frost in the freezing unit this creates blockage in the air flow once the ice crystals build up. the freezer is what keeps the fridge at the normal temperature if the air flow between the two are blocked in the ducting then the fridge temperature will rise the best way to solve this is to open the freezer take out the 4 screws in the back panel tilt the panel forward and blow it with a blow dryer till the ice chunk has melted its a good idea to use a towel and on the top self of the fridge to obsorb excess water this can be kinda messy. or you can unplug your fridge for about 6 or so hours. good luck hope i helped. :)
Mar 25, 2009 | KitchenAid KTRS22EM Top Freezer...
Whirlpool gold refridgerator light not working and is making funny noise
Feb 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer works fine refridgerator does not
problem may be that the return vent from freezer to fridge is blocked with ice. best solution is to switch off for 24 hours with doors open. 2 hours may not be long enough to clear this blockage
Jun 13, 2007 | LG LRBN20510WW Bottom Freezer Refrigerator
Refrigerators Logo
88 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
