Question about Refrigerators
LG fridge Model lmx25964st is not working. NOT COLD in FREEZER or REFRIDGERATOR LED in main circuit board keep flashing
4 Suggested Answers
Trifect7
  • 57 Answers
SOURCE: refridgerator not very cold
It could be some many things, to save time let me give you this check list:
Do what you feel qualified to do.
If you found this helpful please Vote. Good Luck!
Posted on Mar 04, 2008
  • 62 Answers
SOURCE: Fridge not keeping cold
check the controls and make sure they are set properly, so that you are getting air into the ref. also a common thing is that the evap fan motor could be bad and not blowing air into the ref area. it could also be the start of a defrost problem
Posted on Sep 06, 2008
SOURCE: Fridge not getting cold enough
The cold from the freezer is piped up to the refrigerator and if that tube gets clogged with frost or ice it will not be able to blow to the cold air into the refrigerator area. I took everything out, unpluged the unit for about 6 hours, till all the frost from the freezer was gone, wiped up all moisture and turn it back on. It worked!
Posted on Aug 04, 2009
LG LED LN5200 3 LED strips flash 3 do not. I do have sound and can see screen with flashlight and red power LED flashes 3 times.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Dec 25, 2016 | LG 47 Inch LED TV 47LN5200 LN5200 Series...
LG 47LN5400 blank screen after brief flash
Dec 12, 2016 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
LG LED model# 47LB5800-UG. Black screen, full screen flashes every few seconds. Audio OK. LEDs appear to be lit when screen flashes. Sounds like LED driver or inverted board and/or connecting cable?
Sep 22, 2016 | LG Televison & Video
LG fridge is not working. NOT COLD in FREEZER or REFRIDGERATOR LED in main circuit board keep flashing
Look for a reset button, and try resetting . If compressor , is working and still not cooling , check refrigerant gas.
Oct 17, 2013 | Refrigerators
Not cold
The most likely suspect is a defective WR55X10656 main control board. The board is located on rear of refrigerator and the fridge will need to be unplugged to examine it. Remove cover to the board by removing the sheet metal screws on the cover concealing the board. Examine both sides for burn marks or signs od heat or loose solder damage. If you find no problem there then we will mover to the next step. You can see a photo of that control board at both site below. Enter your model or part number in the search feature to check for those or other parts. Let me know if you need more help. Thanks, Sea Breeze
http://appliancepartseast.blogspot.com/
http://servicepartstec.blogspot.com/
May 11, 2009 | GE Profile 22.2 Cu. Ft. Side-by-Side...
Fridgidare, freezer cold fridge warm
sounds like you may have gotten a refridgerant leak causing a low charge condition. some refridgerators have a evaporator fan if this quit working it will cause it to freeze up .thus the freezer does not use a fan and it will still get cold
Jan 05, 2009 | Frigidaire FRS26ZSG
Whirlpool gold refridgerator light not working and is making funny noise
I had the same problem. Model Number GS5SHAXNL00 Light wouldn't work on the fridge side and the led's wouldn't light up. Ended up being a blown circuit path on the control board.
All I did was soder a wire between the 2 points that path was connecting and *BINGO* the lights are back on!
Hope this helps someone. To find the burned out spot just look for a little black smudge on the white plastic case when you remove the board.
Feb 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer works fine refridgerator does not
problem may be that the return vent from freezer to fridge is blocked with ice. best solution is to switch off for 24 hours with doors open. 2 hours may not be long enough to clear this blockage
Jun 13, 2007 | LG LRBN20510WW Bottom Freezer Refrigerator
Refrigerators Logo
843 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
