Question about NEC LT157 Multimedia Projector
Projector: Nec LT157 It doesn't power the lamp
Projector: Nec LT157 It doesn't power the lamp cause of a faulty temperature sensor. I discover the most obvious one near the case lamp and tested it Ok! Where are the other(s)^
dhiman
  • 115 Answers
SOURCE: NEC vt460 Projector have a ghost problem on the screen
Hello
Pls Service the LCD Panels of the Projector, Also check the Fly-Eye lens, just next to Lamp unit. This will solve your problem. if it's not then the only solution is Replacement of LCD Panels, But Must check or replace the external RGB Cable first befor doing all this exercise.
Posted on Feb 07, 2008
Gigatech
  • 259 Answers
SOURCE: NEC VT47 Lamp type VT70LP will not power up 2 red lights spear Lamp not working
When the lamp exceeds 2100hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Posted on Feb 27, 2008
dhiman
  • 115 Answers
SOURCE: lamp not lighting
Reset the lamp and try it.
Posted on Mar 29, 2008
  • 726 Answers
SOURCE: nec gt5000 projector turns off 10 seconds after power up
that is usally cause of the lamp this is not in my expertise but that happened to my dads one if the lamp is at the end it will shut down it usually give warnings first like change lamp then its over has to be replaced
Posted on Sep 13, 2008
SOURCE: How to reset Time clock on NEC MT830+ Projector
change the lamp even if the old lamp
use original nec remote contro
l6. After you install a new lamp, select the lamp Usage icon and press and hold
the "Power On" button on the remote control for ten seconds to reset the
lamp time clock to zero.
NOTE: If resetting the lamp clock back to zero after 2100 hours of service,
press the "Power Off" (not "Power On") button on the remote control for ten
seconds
Posted on Apr 12, 2009
What causes inside the lamp to shatter. It is a NEC Lamp NP21LP. Projector is mounted to ceiling so it uses same power sources and doesn't get moved around.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jan 23, 2014 | NEC Office Equipment & Supplies
NEC VT440 projector problems can you help
Please check its vantilation fans, are they rotating or not?
Jul 24, 2008 | NEC VT460 Multimedia Projector
Temperature error
Remve the lid and check that all fans are plugged in and can turn freely, if not a fan may need to be replaced, also check all other plugs which may connect to a temperature sensor, ensure that the projector is free from dust it can easily be cleaned with compressed air, replace the cover and power up, if the probelm presists there is likely to be a problem with either the lamp or the logic board
Dec 14, 2011 | NEC HT1100 Multimedia Projector
Projector acts like its turning on and then shuts off after a few seconds,what causes this?
Every projector is designed to check the status of various sensors for lamp,fan, inside temperature etc. It seems that your projector lamp turns ON & then OFF. If the lamp turns ON then lamp is OK.
Remove dust from the dust filters if they are blocked. There are many fans to cool down the projector. Some are blower fans. Some are exhaust fans. You will have to open the projector & check which one of them is not functioning. Replace the one which is not functioning. It is also likely that there may be some failure of components.
Aug 04, 2011 | NEC VT800 LCD Projector
Cant clear lamp usage hours warning after replacing bulb on model NEC LT 157
Try holding the off button down for 20 seconds, it may be the on button. I had an NEC MT830 which had a standby function once it had reached and exceeded the lamp life safe limit. Once this had happened it wouldn't come out of stanby uinless the lamplife was reset. Your user manual should have the correct method of reset
Good luck, hope I was of assistance
Jul 14, 2011 | NEC LT157 Projector Lamp Module (50021668)...
Red light blinking in nec lt 260
how many times? that will tell you what's wrong:
1x- lamp cover (close lamp cover)
2x- temperature problem (too hot. clean out and cool down)
3x- power problem (check power)
4x- fan problem (one or more fans not running)
6x- lamp fails to light (lamp or ballast problem)
Sep 02, 2009 | NEC LT 260 Multimedia Projector
I have replaced bulbs in 3 different types of NEC projectors: a silver, older model thta uses a VT60LP bulb, model VT595 and VT470. The lamp will still not work - the power and status light just continue...
I had the same issue, what I figured out was that I never removed the lamp door correctly, causing a small plastic piece to break off. To see if this is also your problem, inspect the back of the lamp door, top right corner, if it seems a rectangular plastic piece is missing, thats the problem. It presses in a small button nearby the lamp to let the projector know it's safe to power on.
Sep 01, 2009 | NEC VT695 LCD Projector
NEC MT1055 Will not power up
Hi there
This sounds like a faulty Ballast ( lamp's power supply ) It will unfortunately need repair or replacement.
Mar 25, 2008 | NEC MT850, MT1050, MT1055, MT1056...
NEC LT157 Multimedia Projector Logo
179 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
