Question about Cuddeback Attack IR Trail Camera 1156
My camera does not have anything on the LCD when I turn it to any setting. The batteries are good and there is no corrosion on the battery contacts. Is there a reset on this camera?
    Master:
  • 359 Answers
Removing the batteries and putting them back in should reset the camera. Try downloading the newest firmware and updating it here: http://support.cuddeback.com/Firmware/Attack/AttackIRFirmware.html
Posted on Oct 17, 2013
I don't know what to do... I have a sony cybershot... Turn it on and the lens goes in and out 3 times and then stays out then the lcd says turn camera off and on. Please suggest a remedy... camera just...
If the camera has recently been dropped you may have lens damage that's preventing it from powering up. If it hasn't been dropped your problem may be due to corrosion on the battery contacts inside the camera - which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then clean the battery contacts, place the batteries back in the camera and give them a full charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 80% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Jan 08, 2010 | Sony Cyber-shot DSC-W90 Digital Camera
Turns on for 2-3 seconds shuts right off battery is ok hp 707 pho
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries, place them back in the camera, and give them a good charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
If this response helps, please post a rating for me. "Very Helpful" would be appreciated . .
Dec 06, 2009 | HP Photosmart R707 Digital Camera
Camera wont power on. I tried 3 sets of batteries
If the camera has recently been dropped it may have lens damage that is preventing it from powering up. If it hasn't been dropped, your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries, place them back in the camera, and give them a good charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Dec 05, 2009 | Kodak Easyshare C813 Digital Camera
Hp photosmart R927. No power, no operation, no LCD, battery good.
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Nov 28, 2009 | HP Photosmart R927 Digital Camera
Lens will not extend when camera is first turned on. LCD flashes, and lens attempts to rotate and move out put stops after about 2 seconds
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Nov 27, 2009 | Pentax Optio S50 Digital Camera
When I turn on my Samsung NV3 camera, the shutter opens, a blurry image appears on the LCD screen and then it turns its self off. Although the camera appears to be off, if you press the button to view...
Nov 25, 2009 | Samsung NV3 Digital Camera
My vivicam 5022 turns then beebs twice and like falls asleep
If this response helped, please post a rating for me. A rating of "Very Helpful" would be appreciated . . .
Nov 25, 2009 | Vivitar ViviCam 3705 Digital Camera
Got message to change batteries. Tried to sets and now power will not turn on at all
Oct 30, 2009 | Canon Powershot A1000IS Digital Camera
My samsung ES17 camera isn't turning on. It turns on and then it says I need to replace the battery. I'm using really expensive good batteries but it won't work.
Oct 25, 2009 | Samsung Digimax 4010 Digital Camera
Polaroid t737 camera.what to do when the LCD comes on for a few seconds and then the camera shuts back down. the lens stays closed and doesnt move. Is there anything that can be done?
Oct 24, 2009 | Polaroid T737 Digital Camera
Cuddeback Attack IR Trail Camera 1156 Logo
148 people viewed this question
Top Cuddeback Cameras Experts
Are you a Cuddeback Camera Expert? Answer questions, earn points and help others
