Question about Brother HL 5250DN Laser Printer
Brother hl-5350DN drum light on won't print - Brother HL 5250DN Laser Printer
SOURCE: Brother Printer HL 1240
OK figured out the sequence to resolve this error:
power off unit
unplug power cable for 1 minute
reset the power cable
open front door
press and hold the reset button under the lights
turn the power on
printer should then be reset
Posted on Aug 16, 2008
SOURCE: brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Posted on Feb 01, 2009
komguy
  • 2306 Answers
SOURCE: Drum light comes on my Brother HL-5040
You need to reset the drum counter. Open the front door and hold the go button until all the lights flash. Shut the door, ready to print...If you press the go button 3 times it will give you a printout that shows the usage level of the drum.
Posted on Jun 25, 2009
komguy
  • 2306 Answers
SOURCE: I have a Brother HL-5250, drum light on, not printing
When the drum light is on solid, it's time for a new drum, if you have a new drum, just open the front door and hold the go button til all lights flash and the drum is reset. Press the go button 3 times and it will print a sheet showing the drum status.
Posted on Sep 15, 2009
Testimonial: "Thanks!"
  • 20 Answers
SOURCE: I've installed a new drum AND a new toner
Try this....
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Posted on Mar 05, 2011
What are the steps to reset toner lights for Brother HL 2240
Try this Toner reset sequence (worked on Brother HL-5350DN)
With Printer off open the toner door
Hold the Go button as you turn the printer on.
All lights will turn on. Keep holding Go until status light goes off.
Press the Go button 2x.
The Paper, Drum & Toner light will come on
Press Go 6x
Status light will turn red
Close the front.
Jul 02, 2014 | Brother Hl2240d - Hl-2240d Laser Printer...
All lights are blinking on brother hl 5350dn
ll the LEDs are flashing.
led_11_2sec1.gifMeaning of LED Indication
Jan 02, 2013 | Brother HL5350DN Laser Printer
My drum light is flushing
Open front door where toner/drum goes in
Hold GO button down for about 5 seconds
All lights should come on then go out when GO button is released
Shut door and wait for warm up to end
Drum light should no longer be flashing
If still flashing then try procedure again
Oct 14, 2010 | Brother HL-2040 Laser Printer
Hi! the drum light on my Brother HL-2170 laser
1. Open Cover.
2. Press the Clear key to display drum status.
3. Press 1 (hold) on the telephone keypad.
4. When the display shows "ACCEPTED", close the front cover.
PRESTO!
Oct 19, 2009 | Brother HL-2170W Laser Printer
Sep 15, 2009 | Brother HL 5250DN Laser Printer
Drum light on HL2030 won´t go off!
Open the front door, and press the go button until the lights flash, after closing, press the go button 3 times for a printout showing the drum as full again. The instructions come with the new drum...
Jul 30, 2009 | Brother HL-2030 Laser Printer
Jun 25, 2009 | Brother HL 5040 Laser Printer
Brother 1440 laser printer. Started printing with
may some dust in corona ware or drum clean the drum.
Apr 06, 2009 | Brother HL 1440 Laser Printer
Printer drum light on
Have you already replaced the drum? If you have not replaced the drum that may be why you are getting smudges. If you have already replaced the drum, here is the reset procedure. The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one. The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below: Open the front cover of the printer. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button. Close the front cover. CautionReset the drum counter only when you replaced the drum unit with a new one.Related Models HL-2030, HL-2030R, HL-2040, HL-2040R, HL-2070N, HL-2070NR http://www.tonerovernight.com
Mar 31, 2007 | Brother HL-2040 Laser Printer
Brother HL 5250DN Laser Printer Logo
43 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
