Question about Echo Backpack Blower PB-500T
It want crank at all i just rebuilt the carb and still want crank and now it also has gas coming out the muffler
    Sergeant:
  • 322 Answers
You either have a bad carburetor or you didn't put it together right when you rebuilt it. double check the diaphragm is on top of the gasket on the metering side. if the needle is stuck open the fuel will continue to flow causing it to come out the muffler
Posted on Oct 17, 2013
Why does a 2cycle chainsaw blow gas out the carb.
possible cause is that the muffler is carboned up and producing excessive back pressure
Apr 23, 2016 | Garden
Why wont my mower start and gas comes out of muffler
carb is flooding out ether bad plug or your carberator needs rebuilt
Aug 25, 2014 | Toro Lawn Boy Self Propelled CARB Walk...
Echo srm-210 powers up fine on a flat surface, but it cuts out after a few seconds in the upright (usable) position. I rebuilt the carb, cleaned muffler screen, good gas and fuel filter. tank lines seem...
Make sure you rebuilt the carb with a carb kit. Put a hose on each pipe coming out of the carb and blow and suck on them. One should seal completely and one should provide vacuum. If there is a leak, you need new check valves. If you rotate the trimmer and it runs poorly, you may have a pierced diaphragm.
Oct 22, 2013 | Echo Zama Carb Kit For Shc210 For Rbk66b...
I have a older jiffy I have gas that comes out of the muffler is that a carb problem.
Could well be the needle valve leaking in the carb, or if you have been cranking the engine for some time and it has not started this will also pull fuel into the engine and blow out of the muffler, a pressure test of the carb will quickly tell you if the needle is leaking.
Jan 23, 2013 | Garden
Carb full of gas
sounds like the float is sticking inside the carberator might need new needle and seat as wel as a float check to see if float is gas logged
Jul 06, 2012 | Parks Optical 13.5hp Briggs And Stratton...
I have a 25 cc Craftsman weedeater. Using fresh 40:1 gas. I've replaced the fuel lines, cleaned in tank filter, cleaned and rebuilt carb and getting spark, but it still won't start. Also cleaned...
the other possibilities you have is a bad crank seal, or a flywheel came loose and its out of time, will it fire on carb cleaner sprayed in the carb, If it runs for seconds and , then I would say it's not getting fuel, If it only farts once or twice then I would check crank seals cause if they are leaking then your crankcase cannot draw vacumn which in turn causes fuel pump in carb to draw fuel, If you have to check flywheel pull it apart and take flywheel nut off and pull flywheel off and inspect the key that is built into flywheel to see if it is sheared off or messed up, also while checking muffler check for the opening that the mud dobbers havent put mud in muffler pipe, good luck
May 15, 2011 | Craftsman 25cc Gas Line Trimmer
Jet pulse carb will not feed gas to engine after start
Make sure the gaskets were installed correctly.
Oct 08, 2009 | Garden
No power
Try to remove the muffler and try it with no muffler but DO NOT run the machine for too long without muffler or you can damage the piston rings . Try to rev it up only once and if it works you have a internal blocked muffler . Replace the muffler and you should be good .
Aug 29, 2009 | Craftsman 25cc Gas Line Trimmer
Echo Backpack Blower PB-500T Logo
138 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
