Question about Microwave Ovens
I have a Whirlpool GMH6185XVB-1 microwave that stopped mid- cooking. When I tried to restart it, it read "close door". The door was closed. I tried to clear it, and start over, opening and closing the door several times, but still the same message. I am unable to unplug it without removing it, as it is built in, and the outlet is behind the unit. Is there a door sensor? I have also noted sweating inside the unit, but I heat various foods for up to 15 min.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 72 Answers
THE SWITCH INSIDE THE DOOR LOCK IS FAULTY AND NEEDS REPLACING...GET IT FIXED IN A REPAIR SHOP..U CANTR FIX IT URSELF...
Posted on Oct 18, 2013
4 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Sylvania SM80704 microwave: after closing
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 23, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Hi. I pressed the 'quickstart'
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
It may be a problem with a door switch or door switch mount.
Posted on Sep 28, 2008
SOURCE: Whirlpool Gold Accubake system microwave indicates
I just had the same problem with my microwave. First DISCONNECT THE POWER. Remove the front top grill (screws are on top of microwave). Unscrew the one screw at the top of the control panel and lift it out of the way. You will see three micro switches to the left of the pannel. I bent the metal frame they were mounted to by hand to move them back into place. The microwave oven works great now. If this does not help, then I would consider replacing the top limit switch.
Posted on Sep 05, 2010
How do I turn on the microwave and set the clock
well setting the clock comes first if my memory is right
Jan 14, 2016 | Microwave Ovens
My microwave would not turn off. Door closed and light/turntable off, the microwave continues to work when not selected on.
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and the model & serial numbers of the Microwave.
Mar 09, 2017 | Whirlpool GT4185SK Microwave Oven
My microwave want cook
Hello
and/or circuit breakers, particularly in the case of recent power failure, and reset if necessary.
Unplug the microwave, wait 30 seconds and plug back in to the power supply to reset the microcomputer.
Open and close the microwave door firmly and press "Stop/Reset." Select a new cook time and press "Start."
Ensure a proper cooking temperature and/or time is chosen, as low cooking temperatures or short cooking times may prevent the microwave from heating food appropriately. Press "Power Level" to ensure the microwave is cooking at 100 percent power.
Contact an authorized service technician if the problem is still unresolved.
Oct 04, 2011 | Sanyo Microwave Microwave Oven
My Frigidaire PLMBZ209GCA Microwave stopped working. I was in the middle of cooking something for 10 minutes and it stopped working half way thru, but the display kept on counting down. If I try to use it...
If it stopped working while you were cooking my first guess is that the magnetron TCO got hot and opened. It is supposed to reset after cooling down, but if it is old it may not have done so. Of course, there should be at least two door switches that close when you close the door. There is also a monitor switch that closes when opening the door (open with door closed). If you remove the control you should be able to check continuity on all switches, but you need to remove the wires to get a true reading. Some M/O have a TCO on top of the cavity, but you need to remove the cover to get to that. If you need more help, just get back to me.
Aug 10, 2011 | Microwave Ovens
If I stop regular microwave cooking to check the progress, and then push start to continue, it does not cook. It just stops working. I have video of bacon taking 15 minutes to cook, because it stopped. ...
Sounds like door switch issues. Thinking the only thing you did was open and close the door, not change programing or anything. If you have an issue with a door switch and it doesnt close right after opening and closing the door( when you stir), the unit thinks the door is open so it will not run. Once the bad connection cools down it contracts and reconnects and the unit will work again. Frequently you can find which switch is doing that if you just look at the switches and see if you have any browning inside of the plastic insulators over the wires that push onto the switch terminals. If the connecton is bad it will get hot that will brown the plastic protector
Aug 14, 2017 | Whirlpool GMH5205XVS Microwave Oven
Model R-1460, when I shut the door it runs but doesn't heat up. What needs to be done to fix it?
Do you mean that when you close the door, the fan comes on? If so, it sounds like a bad door switch. Probably the secondary interlock switch.
This failure is caused by opening the door when the unit is in cook mode. On ALL microwaves, not just one or two brands.......
Be sure to push the stop button before opening the door to add or stir... Or wait for the cook cycle to end. (This is why microwaves have a two step function on the stop/clear button. Hit stop once to stop cook mode and twice to reset timer).
You should use an ohm meter to check all 3 switches. The switch can be either stuck 'closed' or physically closed but not 'making' electrically.
Sep 13, 2009 | Sharp Microwave Ovens
F6 appears on my Whirlpool Over Oven Microwave, Model GH7145XFB0. It will not let me perform the self-diagnostic test. When the door is closed, the light goes out and the unit begins the "cooking process"....
If it starts cooking as soon as you close the door,try unplugging it for a minute then try again. If it does the same its probably a defective triac or relay which is inside the microwave.
Aug 29, 2009 | Whirlpool MH7140XF Microwave Oven
MW8119SB cooks when door is closed regardless of settings
Clear the cook cycle when you remove the food. Some microwaves pick up where they left off, so you don't have to keep pressing buttons.
Aug 07, 2009 | Emerson MW8778 Microwave Oven
Door-activated power switch is loose and/or has a short
Fixed this problem! The door latches were greasy and sticking in the closed position (i.e., pushed down so not latching and engaging fully when the door was closed) and this created the problems described above. Solution was to squirt some Windex into the latch holes to dissolve the grease. The switches popped back into position (must be spring-loaded) and the door closed and latched properly, allowing the oven to function properly. I swabbed out the hole with a q-tip, let it dry for 20 minutes and all is well.
Nov 17, 2008 | Whirlpool MH6150XMS Microwave Oven
Microwave Ovens Logo
52 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
