My tv has wavy blue lines when the screen is black
  • 20 Answers
Your lcd (liquid crystal display) is defective. Wether it's a manufacturers defect or not it may be covered by warranty but this is usually caused from a tv facing a window with direct sunlight or perhaps children using magnets near the display. There is no repair other than replacing the entire display.
Posted on Oct 17, 2013
  • Josh Oct 17, 2013
    Thank you so what do you mean by whole display? How much will this cost? If so can I even still buy this?
  • 3 Answers
SOURCE: Wavy lines
This TV uses small voltage regulators. On each side of the regulators is the input voltage and the regulated output voltage on the other side. There are capacitors used for stabilization on the input and output. Change these capacitors.
Posted on Nov 27, 2006
SOURCE: my TV has blue lines,flashes then turns off
I spoke with a technician yesterday. I live in Quebec. He told me that he fixed this problem a lot but now it's impossible to find the blue and green tube needed to fix the problem. Some red tube are still available. So basically my Sony TV is now plastic and glass junk. There's hope for those with an extended garantie because they give you a new TV cause it's unfixable. Good luck. Too bad Sony doesn't do anything about this. I'll never buy Sony again...
Posted on Jan 08, 2008
  • 899 Answers
SOURCE: a wavy line with 3 colors
this a convergence problem and the convergence IC's will need replacing along with some testing of resistors and or replacement
to have a technician come out to do this repair will cost about $300 - $350 to get this fixed
Posted on Dec 12, 2008
SOURCE: Green screen with red and blue wavy lines
This is "NOT" meant as "expert" advice...as this is not my area...HOWEVER...I see no one has answered this yet...AND I got some good help from here a year or so ago that worked for me!
When I had a similar "green screen" problem with my SONY projection tv...the guy helped me by having me make "MINOR" adjustments to the red/blue/green etc knobs behind the panel. These were three small black plastic pieces and needed less than a 1/16 of an inch adjustment...try adjusting one at a time and giving it few seconds after each adjustment. It worked for me..at least for a while (till my wife gave it away to a friend because it was "too big"...ah! women!!! LOL)...hope this helps. (NON-expert help!)
Posted on Jan 11, 2009
localwonder
  • 6784 Answers
SOURCE: rear projection tv screen warped
HI, this is typical convergence chip failure. you will need to replace the convergence board in this set asap. this will fix this issue you are experiencing.
Posted on May 23, 2009
My samsung projection tv has blue wavy lines on top of screen, I adjusted convergence, the blue will not line up horizontally, is there a inexpensive solution?
It means one of the chips has a bad section inside it, both chips and maybe a resistor near them will have to be replaced, involves soldering as each has about 18 pins soldered in
Check with TVrepairparts.com who sells some kits for this by brand and model number
Dec 09, 2012 | Televison & Video
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
Toshiba Model 51h84
The wavy when cold is a issue with a board in the set--Hyper board--the warmup until it begins to work will gradually get longer and longer.
The blue: look at set on a unused video input--if see faint curved blue lines with some blue visable on the screen the blue screen control needs to be adjusted just slightly down until the blue and curved lines are not seen.
May 15, 2012 | Toshiba 51H84 51" Rear Projection...
Lines, then no picture, then turns off
Remove Front panel look for screen/focus controls adjust them you have R/G/B for each tube ,you have screen drive controls as well as focus Start with red turn green and blue off adjust each one untill you have a black/white picture, If screen drives are to high TV will turn off.Also if STK ICs are bad TV will not come on there is a blue capacitor behind hori output Transistor that also burns out CK it as well.LET me know if any of this has helped you or if you need more information.
Aug 06, 2009 | Sony KP-57HW40 57" Rear Projection...
Video distortion
You need to take your tv in and have the picture deflector re-aligned.  This doesn't cost much, My dad had to do that to his a few months ago and it cost 30 bucks.
Mar 21, 2009 | Mitsubishi VS-60705 60" Rear Projection...
Jan 11, 2009 | Televison & Video
A wavy line with 3 colors
Dec 12, 2008 | RCA HD52W59 HDTV Projection Television
Apex gb5108
'I to am getting only wavy blue lines, no sound, doesn't even show channel indicators. TV was off for 4 days, came home turned it on and ten minutes later this screen appeared, it wont even show the menu screen, different channels or video inputs no sound either.
Jun 21, 2008 | Apex Digital GB5108 51" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
