Question about Depo Auto Parts Chrysler Sebring Sedan/Convertible New Radiator/Condenser Cooling Fan Motor 2001 2002 2003 2004 2005 2006 OEM 5019290AA
Have a 2002 chrysler sebring 2.7 motor an I need to change the oil pump but do I need to remove the exhaust in order to get the oil pan outr of my way, also the water pump leaked water in the motor would it be wise to use a motor flush or just clean up like im doin with the removel of the pan an pump ect
Does the engine have to be taken out of the 2006 Chrysler Sebring to replace the water pump?
NO in does not. some you have to disconnect the upper motor mount and jack it up a little bit [use a piece of wood between the oil pan and the jack if you do this] most times the water pump is easy to change.
Feb 13, 2015 | 2006 Chrysler Sebring
Where is the oil drain plug at?
Is the motor a 2.4L , 2.7L or a 3.0L?
Nov 11, 2014 | 2002 Chrysler Sebring
Where is the oil filter on the 2001 chrysler sebring? cant find it.
OIL FILTER IS IN FRONT NEXT OIL PAN BUT HIGHER UP POSITION. OIL FILTER ABOVE THE BOTTOM OF THE OIL PAN WHERE YOU CANT SEE IT.IF HAVE TO RAISE FRONT CAR UP TO SEE IT.NEED SPECIAL FILTER WRENCH TO REMOVE IT.
Apr 13, 2011 | 2001 Chrysler Sebring
Oil light come on seems that there little oil pressur
1) Check your car to see if it has oil and oil is at the recommended level. 2) Check if there is any leakage from the oil pan, or sign of oil be consumed 3) If everything looks good, you may need to replace your oil pump.
Jan 30, 2011 | 2002 Chrysler Sebring
Do I have to take the motor out in order to replace the water pump on a 2002 chrysler sebring??
NO YOU HAVE TO TAKE THE COVERS OFF,AN POSSIBLY REMOVE TIMING BELT ASSEMBLY
Dec 19, 2010 | 2002 Chrysler Sebring
Where is the oil sending unit on a 2002 Chevy Suburban V 8 engine?
Your oil pump is located under your oil pan. You need to remove the pan in order to access it. There is one bolt holding it in place, remove that bolt and then remove the oil pump. This is if you have a 4.3 liter motor.
If you have a 4.8, 5.3 or 6.0 liter motor it is considerably more difficult. If you need step by step instructions let me know, but to answer your question it is located behind the front cover of the engine. You need to remove the front cover exposing the timing chain and the oil pan in order to remove the pump on these motors. Let me know if you need further help.
Nov 04, 2009 | Chevrolet Chevy Cars & Trucks
Oil light on while driving 2002 Sebring
2.7 ? This motor has oil problems if not changed every 3000 miles. Put a chrysler filter on it and the correct weight of oil, never use a fram oil filter.
Jul 02, 2009 | 2002 Chrysler Sebring
2002 Chrysler Sebring Oil pressure light
Could be a bad oil pressure switch, or a bad oil pump. Both will cause this issue. Hope it is the switch b/c the oil pump is a costly repair.
Mar 26, 2009 | 2002 Chrysler Sebring
Fuel filter
fuel filters are usually located under the driver side of the car. it will be a metal cylinder with 2 lines on it. one going to the engine and one coming from the gas tank.
Aug 02, 2008 | 2002 Chrysler Sebring
Depo Auto Parts Chrysler Sebring Sedan/Convertible New Radiator/Condenser Cooling Fan Motor 2001 2002 2003 2004 2005 2006 OEM 5019290AA Logo
42 people viewed this question
Top Depo Auto Parts Computers & Internet Experts
Todd Arndt
Todd Arndt
Matthew Spark
Matthew Spark
Andrew Taylor
Andrew Taylor
Are you a Depo Auto Parts Computer and Internet Expert? Answer questions, earn points and help others
