Home Logo
Stacy Posted on Oct 17, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Swinging glass door
How do I adjust cylinder on swinging glass door, it's like it gets stuck on metal frame
Trevor Marsh
Level 2:
Habit-Forming:
  • Expert 114 Answers
  • Posted on Oct 17, 2013
Trevor Marsh
Expert
Level 2:
Habit-Forming:
Answers
114
Questions
Helped
42897
Points
368
Are there screws or adjustments points on the hinge?
  • 3 more comments
  • Stacy Oct 17, 2013
    There are 2 screws at the top where the cylinder is, I've tried tighten and loosing the screws but the door is still rubbing against door frame
  • Trevor Marsh Oct 17, 2013
    I would check the screws in the hinges to be sure they are tight (sorry if you already did this) Where is it rubbing? Top or bottom? is it latching?
    There is no hinges just knobs that go in the top and bottom that holds it together, the cylinder is at the top where hinges should be, the door is rubbing at the top these doors were first hung in 1975 so they are pretty old doors,
  • Anonymous Oct 21, 2013
    I've been looking for doors and windows in Barrie. Do you know where I could find a place to get them?
  • Michelle Balcom May 05, 2014
    there should be an adjustment nut to raise / lower door at the top and bottom of the hinge side of the door, you probably have a concealed closer, look for 3 little holes in the frame top, one will be latch speed, one is closing speed and one is backstop. Tighten with allen wrench until door does not move and slowly release until desired swing is achieved. There should be 1/8 clearance around the door, tighten or loosen the 2 nuts at frame side until the clearance is good.
What is the most common executive toy in offices?
The most common executive toy found in offices is Newton's Cradle.
This toy is named after Isaac Newton and consists of a series of identical metal spheres attached to a frame by strings, so that they touch each other at rest. When one sphere is lifted and released, it strikes the first ball in the series and stops. The energy of the first ball is acquired by the last ball in the series, which swings and coming back releases its energy, which causes the first ball to swing again, and so on. This creates a constant swinging from one side to the other, leaving all the other spheres unmoved.
The swinging can also be done by more than one sphere at a time, even by three out of five, causing the middle sphere to never stop swinging.
Here is a picture of a Newton's Cradle in movement:
https://www.google.co.il/search?q=Newton's+Cradle&es_sm=93&source=lnms&tbm=isch&sa=X&ei=xzdNUv2mLaaw0QW2yoDACw&ved=0CAkQ_AUoAQ&biw=1680&bih=925&dpr=1#facrc=_&imgdii=_&imgrc=9_r5da5GqG8JpM%3A%3BLSfGAPqGwpXSNM%3Bhttp%253A%252F%252Fwww.teachersource.com%252Fimages%252Fproducts%252Flrg%252Fnew100.gif%3Bhttp%253A%252F%252Fwww.teachersource.com%252Fproduct%252Fnewtons-cradle%252Fenergy%3B551%3B412
Cat flap
No... unless the door is removed entirely or you customize.
1helpful
Can i replace the glass doors on my cooler to the solid doors?
If they are swinging doors yes but if they are sliding doors probubally not, but you could get doors and brackets made up if you really wanted to I wouldn't recommend it
Hi I've got a babyweaver swinging crib and I'm missing one part and dont really no the name it is the middle part that connects the crib to tenge stand it goes in the middle to separate them...
Sounds like you are missing the central support rod or bar that connects the Babyweaver swinging crib to the stand, providing stability and support for the crib. This component is crucial for maintaining the structural integrity of the crib and ensuring safe usage. Here are some steps you can take to address the missing part:
1. Contact the Manufacturer:
- Reach out to Babyweaver or the manufacturer of the swinging crib to inquire about obtaining a replacement central support rod.
- Provide them with details about the missing part and the specific model of the swinging crib to ensure you receive the correct component.
2. Check for Spare Parts:
- Check if the swinging crib came with a user manual or assembly instructions that may have information about spare parts or replacement components.
- Look for any contact information provided for customer support or spare parts inquiries.
3. Online Search:
- Conduct an online search using keywords such as "Babyweaver swinging crib central support rod" or "Babyweaver crib replacement parts" to see if you can find the specific part for purchase.
- Explore baby product retailers, online marketplaces, and specialty stores that offer replacement parts for nursery furniture.
4. Local Retailers:
- Visit local baby product stores or furniture stores that carry nursery items.
- Bring the existing part (if you have one side of the support rod) to help them identify and match the missing component.
5. Custom Fabrication:
- If you are unable to find a suitable replacement part, consider contacting a metal fabrication shop or a carpenter who may be able to custom-make a central support rod that fits your Babyweaver swinging crib.
- Provide them with measurements and details about the required specifications for the part.
Oct 19, 2017 • Toys
1helpful
The inside shower door is uneven, making it come of the hinge after moving it more than 4-6 inches.The metal attachment holding the glass is lower than the other ones.How do I get it even so it slides...
The top rollers should have adjustments on them to bring the door to horizontal as it swings accross the track.
Start with door in the middle and adsust by seinging it to both sides.
Glass on sliding door
this is the link to the information http://www.swisco.com/Screen/how-to-repl...
Opening your patio sliding glass door should be an easy task. If your sliding door is giving you a work out every time you open it, most likely it is your rollers that are causing the problem. The rollers are located on the bottom of the sliding door and give the door the ability to slide. Often times they get dirty and wear out, making it difficult to open the door. If you have an older sliding glass door your rollers may have become rusty because sliding door units did not always use stainless steel rollers.
Hiring a professional to replace your rollers could cost you around $100 not including the cost of the replacement parts. Below are detailed steps containing all the information you will need to know to replace your patio sliding glass door rollers yourself.
* Before you start, understand that you need to take the sliding glass door out of its frame to work on the rollers. The sliding glass door is heavy. You may need the assistance of another to help you remove the door.
1) Your patio glass door will have two separate glass units. One unit is the door that you slide and the other unit is stationary. First, stand outside your house and look at your sliding glass door. If the stationary unit is between you and the sliding unit you will most likely have to remove the stationary unit so that you can get to the glass sliding unit.
Before you go through the trouble of removing the stationary unit, first try to go inside your house and see if you can remove the sliding unit. Usually you cannot because there is a lip along the bottom of the patio glass door frame (it keeps moisture out of the house) that prevents the sliding glass door from being removed from the inside.
If the rollers on the bottom of the door are difficult to get over the lip, you can adjust them to help you create more room (go down to step 2). If it is not the rollers but the sliding unit�s frame preventing you from pulling the sliding unit out of the door frame, you are going to need to remove the stationary unit first before you can remove the sliding unit.
To remove the stationary unit, you first need to take out your screen door (if you have one). Lift one end of the screen door frame and use a screwdriver to lift the roller on the bottom of the screen door frame off of the track. Do this to both ends of the screen door and your screen door will pull out of the door frame.
The stationary unit is held in place by a metal piece that runs along the bottom of the track from the corner of the stationary unit to the bottom of the side jamb (there is a chance this piece is missing but if you do have one remove it from the track). After you have removed the metal piece, look for screws holding the stationary unit frame in place. After removing all of the screws try pulling the stationary unit out of the door frame. If you are having trouble pulling out the stationary unit, try placing a screwdriver between the stationary unit�s bottom frame and the track it is resting on. Lift up on the screwdriver while you have a helper pull out the stationary unit from the door frame. Be careful not to use too much force with the screwdriver so that you do not damage the door track.
2) You may need to create more room when you attempt to remove the sliding unit from the door frame. To create more room you can adjust the rollers on the bottom of the sliding unit. By turning the adjusting screws on the rollers clockwise the wheels move up into the sliding unit�s frame giving you more room. The adjusting screws are located either at the bottom of the sliding unit�s frame or in the sides of the frame. There is a chance that there are plugs covering the screws.
After you adjust both rollers (one on each side of the sliding units frame) try to remove the sliding unit from the door frame. If the unit is still getting stuck you may need to get someone to help you. Have your helper lift one side of the unit and pull outwards while you try to pry the other side of the unit over the track.
3) To remove the rollers from most sliding units you need to remove the bottom of the sliding units frame. Most likely the screw that holds the roller in place is the same screw that holds the frame together. Remove the screw from both sides of the unit. Then try to remove the bottom piece of the frame off of the sliding unit; you may need to use a rubber mallet or a piece of wood and tap on the bottom of the frame until it comes off of the sliding unit.
Now that you have removed the bottom of the frame you can take a close look at your patio glass door rollers. Remove one of the rollers and match it up with one of the rollers on this page http://www.swisco.com/page/SI/CTGY/patio...
It is a good idea to replace both sliding door rollers at the same time to prevent extra wear-and-tear to one new roller, which will have to work twice as hard when paired with an older roller.
4) After your new rollers come in, replace your old rollers with the new ones. To make it easier to install the sliding unit back into the door frame, adjust the rollers to be all the way up into the frame. Once you have the sliding unit back in the door frame you can adjust the rollers for optimal performance. Keep adjusting the rollers until the door is sliding back and forth easily
Continous burst mode
The Movie Mode takes very low resolution frames and can be re-played frame-by-frame.
Use the Continuous Mode for resolutions 2,048x1,536 or 1,600x1,200 or 640x480 get more details than movie.
For higher frame rates, use 1,600x1,200 and you can get quite good photos.
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
