Question about Mitsubishi WT-42311 42" Rear Projection Television
Mitsubishi WT-42311 hd tv has "pulsating" problem
My Mitsubishi WT-42311 42" rear projection hd tv recently started "pulsating in and out". The "pulses" start relatively small and sometimes will stop without switching the tv off and then back on. At other times, the pulsating will become larger and if the tv is not manually switched off and then back on, the pulsating will cause the tv to shut off. I searched the internet and found one result where the owner experienced the exact same problem and indicated that a $7 part was required, but no additional information was provided. Hoping someone has a clue about what is wrong with my tv.
    Genius:
  • 1,694 Answers
A Mits qualified tech and/or warranty repair facility near you should be consulted.Involve Mits in the repair loop for accurate info.
Posted on Sep 26, 2007
SOURCE:
Sizing screen on wt 42311
A problem in HD BUT not on standard 480 programs-----Convergence not good in HD OR WHAT?
Mar 23, 2012 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi tv model wt-42311, error code 2-2. what can i do?
2,2 IS short protection and 95% chance it means one of the two pico fuses that protect the convergence IC chips are bad.
This model uses two of the chips: STK-392-110 and you would have to pull the light box out to replace them safely (total parts cost will be under 30 dollars).
It involves getting at the chips and the fuses and replacing them: how much skill do you have?
SD TECH
Mar 25, 2010 | Mitsubishi WT-42311 42" Rear Projection...
Replacing a bulb in a mitsubishi rear projection tv
Are you sure tube is bad and that projecion fluild isnt contamiated if tube lights up but you can not see a picture clearily or at all fliuld is bad remove old fluid replace with new problem FIXED Call Mats for projection fluild 1-800-628-1118
Sep 18, 2009 | Mitsubishi WT-42311 42" Rear Projection...
I have a Mitsubishi HD 1080 42" and the pictures has a yellow shadow on the right side of the tv. also yellow and green shadows
Your television needs convergence adjusted. Seek your owners manual to do this.
If you need help locating it, let me know.
Jan 19, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi wt-42311 tv wont stay on
convergance ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 28, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi tv wt-42311
convergance ic bad
Oct 22, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi WT-42311 42" Rear Projection Television Logo
109 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
