Question about Measuring Tools & Sensors
I have a 8hp Briggs and stratton engine on a go cart that idles but when throttle is applied bogs out at top speed and a fast throttle push without feathering it up. I cant figure it out.
  • 107 Answers
Could be a float or an air leak between the intake and carb?
Posted on Oct 17, 2013
Why doesn't throttle control work on snapper rider mower with briggs and stratton engine
I need a little more information. Does it run at an idle or is it runing at a moderate to high speed? Does the throttle lever move or is it frozen?
Jun 24, 2014 | Briggs & Stratton Garden
How do I adjust a throttle on a briggs and stratton engine?
If it the simple handle type throttle cable..push it to full tbottle and follow the cable to the carb..you should fund a small clamp that hold the cable in position..jus loosen and adjust the carb throttle to full throttle and tighten..then push it back to idle to make sure it Idles if not adjust the clamp again until you reach both throttle and idle..good luck..
May 17, 2014 | Briggs & Stratton Briggs Stratton...
How do i idle down the engine or govern down the engine on a briggs and stratton 550 series mower model 10T802
that engine uses a fin style governor remove the upper cover and see if there is a nest or something holding the fins movement
Jul 12, 2012 | Briggs & Stratton Briggs Stratton...
Vanguard V Twin 18 hp. monted in Cushman Motor scooter, runs great at W.O.T and at on quarter throttle, misses at range inbetween
Sounds like your carb needs the fuel/air mix adjusted..uses all the gas at high speed but has excess at low speeds...find your adjusting screw and at med throttle slowly screw it clockwise until the engine starts to sputter then back it out until it starts to sputter again then continue to do this until you reach ideal mix where it runs the best it can..then go slowly through the throttle up and down..when set..unjust your idle speed screw to your ideal idle speed..if this dies not fix ..carb will bed cleaned or rebuilt. Good luck.. Note always push or pull your throttle handle slowly to position avoids gas load up causing sputter and backfire.
Mar 15, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Ok i have a problem with my Briggs & Stratton 16HP v-twin vanguard engine.When i start the engine and rev it up when i idles back down it sits there and rev's up and down then it straightens out and...
It appears that you have a slight mis-adjustment in the idle speed and idle mixture. To adjust setup, start with at least a half tank of fuel, and have engine at operating temperature (That is warm but not overly Hot). The Briggs & Stratton Website manuals section should show the locations of the adjusting screws if you are not sure of them.
To adjust idle speed set Throttle control to minimum and adjust screw on throttle butterfly to maintain a good idle speed. To adjust idle mixture, screw in idle mixture screw (Lean) until motor falters and then screw out (Rich) until it falters again. Correct setting is the halfway point of these two positions. You may have to re-adjust idle speed again and also the mixture to get best running.
If you are not comfortable doing this, take it to a B & S dealer.
Sep 21, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
I have a Briggs and STatton 24 OHV intek motor on a craftsman lawn tractor. I got it on sale and when I got home it ran rough. The fuel line had collapsed or was plugged with some white powder. I took off...
It sounds like the fuel mixture is running very Lean..There are usually two adjusting screw screws on the carburettor that control the mixture. A Larger one is for the Main Jet and a smaller one for the Idle Jet. There is also an adjusting screw on the throttle butterfly to control the idle speed.
To adjust setup, start with at least a half tank of fuel, and have engine at operating tempurature (That is warm but not overly Hot). As a starting point, loosen (anticlockwise) Main Jet screw about half a turn, to richen mixture,so that engine will run without choke. Run engine at full speed and adjust main jet for highest smooth speed without engine missing due to mixture being too lean or rich.
Allow engine to idle and the adjust Idle Jet Screw for smoothest idle. Idle Speed screw may have to be adjusted if idle speed is too high/low.
Sequence above may have to be repeated to get best running. If engine hesitates sometime when sudden load is applied but then picks up, try adjusting Main Jet by 1/8 to 1/4 turn richer until it handles the load without faltering.
Aug 22, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton engine stumble
Hello there:
first i would shorten the gap on the plug and if needed readjust the air/fuel mixture as per specifications
Sep 15, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
8hp briggs and stratton in a go cart. is feeling very underpowered compared to what i remember. hasnt done much for last 8 years. done basics but no better? any ideas
Make sure the governor baffle is working freely. and the carb has no crud in it. Chk out this site:
bsppwebtools.com/data/manuals/1678_0esfw.pdf
Aug 04, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Replaced diaphram and gasket between tank and carb
This sounds like an airleak between the carb and the engine acting like the throttle is open.. Try and take some carb cleaner and spray it where the manifold bolts to the engine if you hear the engine bog or lower the rpm's then replace your manifold gasket should fix this problem
Apr 27, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Measuring Tools & Sensors Logo
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
