Question about Marantz CDR310 Professional Portable CD Recorder
Will not save settings - Marantz CDR310 Professional Portable CD Recorder
Volume settings dont save on Mitel 5312 ip phone
You can't save the volume if you put it up to 10. Set it at 7 and see if it saves. If not volume save in the class of service option is not enabled
Jul 18, 2012 | Mitel 5212 IP Phone
On my hand set l was not save internet configaration when i was saved it call only 70 set allowed save disscarded .now what was my solution
hello bro
Just Follow the following steps to save your configuration settings.
1: Download & install OxyCube.
2: Connect your phone with USB cable. (USB Cable drivers must be installed)
3: Run OxyCube.
4: Select C: (Your phone memory).
5: In folders tree select Omadm Folder.
6: There will be 70 Numbered folders under Omadm.
7: Delete all folders accept first 5 & the folder named PRECFG.
8: Disconnect your phone.
9: Reboot your phone.
10: Either request you provider to send you settings. or insert it manually.
11: This time the settings will save normally.
Mar 07, 2011 | Nokia 6300 Cellular Phone
Nokia 6300 cannot receive configuraton settings only 70 sets can be saved find a solution
Hi sohail_srk20,
Each time you change the SIM card onto the phone, GPRS settings are automatically saved in the phone memory. Your phone can save only 70 sets of GPRS settings and the 70 empty lots are used now. So now when you change the SIM, you automatically receive settings, and they cant be saved because the GPRS settings memory is full. Hence you get the message.
Follow the steps below to remove the settings:
1) Go to MENU > SETTINGS > CONFIGURATION > DEFAULT CONFIGURATION SETTINGS.
2) You'll see the list of GPRS settings saved on your phone in this page.
3) Select each of the settings you want to remove by selecting OPTIONS > DELETE.
Next time you change back to another SIM card, the settings are saved in the empty lots you just created. Once they become full, the same message shows up again.
If this information was helpful, please rate it.
Thank you for using fixya,
Arun Zac
Dec 05, 2010 | Computers & Internet
The camera when tells me images are being saved to computer but nothing happens
FinepixViewer will only save images that are not already saved.
Maybe they are saved to a different location that you expect? In FinepixViewer under Settings / Save Image Settings you can see, where images are saved to. You can also switch setting to Save Files Again, if you prefer that.
May 03, 2010 | Fuji FinePix S8000fd Digital Camera
This modem does not save settings. like when you open your nat. How do i update my firmware
After changing the settings on modem have you selected "save and reboot" even after save and reboot is done the settings were unable to save, it means there was an problem with your modem itself its unable to save the settings.
Mar 29, 2010 | Belkin F5D8631-4 Router (F5D8631au4A)
GPRS settings
This might be due to insufficient space.You have to Delete other Settings already Saved on your mobile. Then try to save after requesting from Mobile Operator..
Mar 26, 2010 | Nokia 5320 XpressMusic Cellular Phone
I set the printer settings, save. When the printers power is turned off, the saved setting are lost- why?
Check in the Configuration Menu for your "Power on" configuration set. It is most likely set to "Factory Default" Change to your custom set (1,2,3 etc) and save. Make sure you save your set again after you set this (you just changed the config so save it)
Mar 02, 2010 | IBM Infoprint 6500 Matrix Printer
When i saving gprs settings it says 'only 70
clean up your phone memory try to do restore factory settings .... and try save the gprs settings in your phone it will work... thats all
Feb 02, 2010 | Nokia 6300 Cellular Phone
I have a Fender Cyber Twin that does not save my settings. I can set up my volume,gain, treble ect.. hit save button to store the setting and if I switch settings to a different sound and back to the...
From the manual... is THIS the proceedure you are using to save the settings?
 T o SAVE:
1) Press the SAVE key once and a prompt displays the PLAYER’S
LOUNGE preset about to be replaced, (example prompt shown).
2) Rotate the DATA WHEEL to select a PLAYER’S LOUNGE preset to
overwrite with the currently active amp design
(last chance to press EXIT, cancelling the save).
3) Press the SAVE key a second time to complete the save.
Jan 24, 2010 | Music
IN NOKIA 5200 GPRS SETTING NOT SAVE DISPLAY SHOWS ONLY 70 SET ALLOWED nokia 5200 gprs setting when I try to save it will say only 70 sets allowed setting discarded
Nov 06, 2009 | Nokia 5200 Cellular Phone
Marantz CDR310 Professional Portable CD Recorder Logo
64 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
