How do i insert paper roll into sagem monetel eft9309g
I need a manual for phonefax 2804 have been given this and need help getting set up and running
Dear Valerie Barlow,
I have found what appears to be the support site for your device, and the link for the website is listed just below here. . You should be able to download your manual from there.
http://support.sagemcom.com/site/page_accueil.php?site=1&pays=uk
I hope this is the fixya for you and I look forward to hearing how you get on with this.
Yours sincerely
Ouszen
Feb 07, 2012 | Sagem Office Equipment & Supplies
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    Trying to replace the paper roll on a sharp EL1801V
    1 Turn off the Sharp EL-1801V.
    How do you put the adding paper into the machine? My machine is a EL-1197iv
    Never insert paper roll if torn. Doing so will cause paper to jam.
    Always cut leading edge with scissors first.
    1) Insert the leading edge of the paper roll into the opening. (Fig. 1)
    2) Turn the power on and feed the paper by pressing . (Fig. 2)
    3) Insert the paper roll to the paper holder. (Fig. 3)
    DO NOT PULL PAPER BACKWARDS AS THIS MAY CAUSE
    DAMAGE TO PRINTING MECHANISM.
    Jan 03, 2011 | Sharp EL-1197PIII Calculator
    Will not feed paper
    PAPER ROLL REPLACEMENT
    jam.
    (Fig. 1)
    2)
    3) Lift the attached metal paper holder up and insert the paper
    Dec 19, 2010 | Sharp EL-1801AII Calculator
    Want to know how to load thermal paper on my sharp Fax model FO-71
    1 - Grasp the finger hold and pull up to open the operation panel.
    2 - Flip up the front paper guide.
    3 - If you are loading paper that is 210mm in width, place the paper roll shims on each side of the paper compartment. (Note that Sharp recommended paper, including the initial roll, is 216 mm in width.) • The ribbed side of the shims should face in (toward each other).
    4 - Unwrap the roll of thermal paper and insert the paper shaft.
    5 - Place the roll of thermal paper in the compartment, making sure the ends of the paper shaft fit into the notches on each side of the compartment.
    • Important: The roll must be placed so that the leading edge of the paper unrolls as shown. (The paper is only coated on one side for printing. If the roll is placed backwards, the paper will
    come out blank after printing.)
    6 - Insert the leading edge of the paper into the slot as shown. Continue to push the paper through the slot until it comes out the opening in the front of the machine.
    7 - Make sure the paper comes out straight, and then flip down the paper guide.
    8 - Close the operation panel, making sure it clicks into place.
    • FO-71: A short length of the paper will be cut off.
    Dec 01, 2010 | Office Equipment & Supplies
    I ran out of paper and purchased a new roll of paper. I do not know how to install the new roll of paper.
    Just drop in, the paper needs to come toward you from the bottom and just past the paper cover once closed. If you have a paper roll spindle, insert and line up with the spindle guides on the machine.
    Mar 20, 2009 | VeriFone Omni 3200 Printer
    Sharp UX-184 Paper Feed
    On inside of machine it states how to:
    1. Place new paper roll on the left hub while pushing it in, lowering the roll into the compartment making sure it is inserted onto the right hub.
    2. Pass the leading edge of the paper through the paper cutter guide and the cutter.
    3. Remove any slack in the paper.
    4. Close the cover. The paper will feed out automatically.
    The paper rolls over top front to back.
    Nov 09, 2008 | Sharp UX 108 Roll paper Thermal Fax
    Sharp EL-2196BL
    Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
    1. Lift the paper holder up.
    2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
    3. Insert the paper roll from the left side of the paper holder and make sure the paper
    roll is set in the proper direction (with the paper feeding from the bottom).
    4. Insert the leading edge of the paper into the opening directly behind the print
    mechanism.
    5. Press the paper feed key and feed the paper under the edge of the paper cutter.
    Dec 07, 2007 | Sharp EL-2196BL Calculator
    Computers & Internet Logo
    26 people viewed this question
    David Payne
    David Payne
