My mouse button has stopped clicking. - Computers & Internet
The mouse is probably faulty. Test with another mouse; if the test mouse works, then all you need to do is buy a new mouse.
Posted on Oct 17, 2013
The right click button isn't working
does this mouse have a ball on it or its the ones with the red light.
Jan 28, 2014 | Microsoft Comfort Optical Mouse 3000...
Tip
Mouse pointer with keyboard keys
<span><b>You can control your mouse pointer with keyboard keys in all windows versions. When your mouse stops working, you can enable this keyboard feature to complete your important work. This keyboard mouse can performs all tasks same like a normal mouse.</b><br /><b>Follow the given steps to activate the keyboard mouse:</b><br /><b><br />To edit this feature, first you should log onto your computer with administrative rights.<br />To activate this feature, press Alt+Shift+NumLock keys at once and you will receive a small MouseKey box.<br />To keep MouseKeys on, click on Ok button or click on cancel button to cancel MouseKeys box.<br />Click on Settings button, if you want to adjust the mouse cursor detail settings.<br />Here a new dialog box will appear with the title Settings for MouseKeys", now you can manage all mouse settings for example mouse cursor speed, acceleration and some other features.<br />Now using Numeric keypad, you can move your mouse pointer. The controls are:<br />*<br />1,2,3,4,6,7,8 and 9 keys are used to move the mouse cursor into different directions.<br />*<br />Key 5 is used as mouse click button.<br />*<br />Insert key used to hold down mouse button.<br />*<br />+ Sign used to double click on any object.<br />*<br />Delete button used to release the mouse.<br />*<br />Click on NumLock button to disable this keyboard mouse feature</b></span>
on Apr 04, 2011 | Computers & Internet
This is a problem with a iHome Laser Mouse product. ihome 3-Button Laser Mouse Model Number- iH-M120LB Serial Number:0906001183 I am having trouble using the left click button on the mouse. I...
When you change the left mouse pointer to be the right mouse pointer in the settings of the mouse, then if the right mouse button stops working, it is a software problem and reinstalling drivers is the way to go. If on the otherhand the left mouse button still does not respond, then there is a problem with the switch in the mouse. This is hardware related. Either clean the mouse or buy a new one.
May 11, 2017 | iHome 3 Button Fast Track Laser Mouse...
HP 2530p EliteBook - touchpad stopped working. Scrolling works except touch scrolling on right side of pad) and right button, but that's all. Wireless mouse works fine.
To access Mouse Properties, select Start - Control Panel - Hardware and Sound -Mouse.
Use Mouse Properties in Windows to customize settings for pointing devices, such as button configuration, click speed, and pointer options.
Jan 18, 2013 | HP EliteBook 2530p Notebook
The left click button on my Logitech M555b mouse stopped working earlier today for no apparent reason. It has no physical damage, such as dents, scrapes, or water damage. The mouse is only about 2 months...
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7
then click on the >> all control panel items scroll to mouse in the buttons tab you will see the defaults left button right button and middle wheel click you might have to set the left click button again
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
Or disconnect the mouse from your computer restart.
If still does not work you need a new mouse.
hope this helps
Sep 30, 2012 | Logitech Mouse Bluetooth M555b Black Pc...
How do I enable my touchpad scrolling feature?
Right-click on the desktop, then click "Personalize."
Click "Change mouse pointers." This opens the mouse properties window.
Click the "Gestures" tab in the mouse properties window.
Click the "Use Vertical Scroll Function" and "Use Horizontal Scroll Function" check boxes.
Click "OK."
or you might
click "Start" button in the lower left corner of your desktop.
Scroll up and hit "Control Panel."
Choose "Mouse."
Click the "Device Settings" tab.
Highlight the touchpad in the list of devices. Hit the "Enable" button.
Hit the "Apply" button and hit the "OK" button.
to disable
Go to the control panel to the Mouse options and click on the Gestures tab and there is an
option that under Virtual Scrolling "Enable Virtual Scrolling" disable that option and that
should stop the auto scroll.
hope this helps
Sep 01, 2012 | Dell Inspiron 1520 Motherboard
My mouse has stopped working
The mouse buttons may have been swapped from LH to RH or vice versa.
Go to Control panel - Mouse - Buttons tab - in Button configuration click the selection box (Switch primary and secondary buttons) with the right button on the mouse.
If you have used the wrong mouse button then select it again with the correct button.
Then click Apply and then OK.
May 26, 2010 | ASUS F5R-AP038A Notebook
Replaced Microsoft Wireless Optical Mouse 2000 doesn't work
I would have suggested opening up your old mouse and cleaning the right click button first.
Generally, wireless devices have a connect button that finds the frequencies of the devices. On the receiver press this button, then press the button on the bottom of your new mouse. the receivers lights will stop flashing once connected.
Jul 21, 2009 | Microsoft Wireless Optical Mouse
Double-clicking
DID YOU TRY SWITCHING YOUR BUTTON ASSIGHNMENT (LOCATED IN MOUSE OPTIONS IN CONTROL PANEL) TO SEE IF IT HAPPENS ON BOTH RIGHT AND LEFT BUTTONS??? ALSO MAKE SURE YOUR SENDING UNIT IS NO FARTHER THAN A COUPLE FEET FROM YOUR MOUSE.
Apr 22, 2007 | HP P2350AA Mouse
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
