Question about Cell Phones
Its has been using a different network.I want it to work with any network
How do i establish a subnet with a A address
The subnet is determined by the subnet mask. Class A addresses are contained in the following range: 0.0.0.0 - 127.255.255.255. The most common use of a class A address is 10.0.0.0
In class A networking you may use a subnet mask from 255.0.0.0 all the way to 255.255.255.255
The subnet would work as the following example:
Network Address: 10.x.x.x
Subnet mask: 255.0.0.0
The first number in the above example would determine our subnet. So if you have 2 devices and you would want to put them in a different subnets you would want the first octet (octet is each number seperated by periods) to be a different number.
Network 1: 10.x.x.x
Network 2: 11.x.x.x
Unless these devices use a router to communicate they would not "talk" properly. Thus giving you 2 different subnets.
Oct 24, 2013 | Computers & Internet
Router upgrade?
A new router is just one piece of the network. The components work with one another and depend on ALL the components working in harmony, you might say. One piece will not guarantee improvement in a network. Do more research, what are the Network adapters connecting? What is my ISP speed, remember, your speed will differ, sometime greatly for advertised ISP speeds. The factors are infinite, unknown, and sometimes out of your control. That said if you are using a 802.11 N or AC Wireless in your Home Network, depending on the Computer, Printer, etc. Network Adapters, etc. I use 3 different Access Points, 2 Linksys wrt54g's, 1 wrt160n , all with different SSID's and channels, connecting to 2 printers 2 Laptops, 2 desktops, iPad, Smart HDTV/Netflix, Phone, all work quite well. As I move about the devices will switch to the best signal. Remember the old saying, "If it ain't broke, don't fix it". But I always try, with different levels of success . You may learn a new way not to do something, I do. Some people call it a mistake.
Apr 30, 2013 | Computers & Internet
I cannot connect to the WIFI at work, but I can connect to my WIFI network at home, and other public networks. The wireless network at work is pushed by a D-Link 8200AP with a WAP security, just like it is...
Your laptop cannot connect to your work's wireless network because the security settings (ir WAP) in the D-Link is different to the security setting in your Netgear.
The wireless card in your laptop will need the settings changed to suit the D-Link's wireless settings ie the SSID and WAP.
You will need to change the wireless card settings in your laptop back to the Netgear's wireless settings to connect to your wireless network at home.
Some wireless cards allow you to set up different profiles for different wireless networks which allow you to switch wireless networks easily by just selecting the profile for the network you want to connect to.
Jun 25, 2011 | Apple iBook G3 Mac Notebook
What if I put different sim to my sidekick slide except T-mobile? When I tried to put different sim my internet doesn't work?
As you said me that you will be using different sim but you can not use the internet because for example you will be using vodafone sim means you will be having that sim settings in your mobile if you use any other network sim means you need settings for network.So internet does not work in you are mobile for different network.If you use same network different sim means there you can use the internet.Thanks for your question happy to help.
Jun 16, 2011 | Cell Phones
How to use Nokia 6030 in US (T- mobile) which i bought in India.. This mobile is an unlocked mobile.. i was using with different networks in INDIA.. i bought this mobile in 2007.. so far i never had...
Try this:
Go to Settings > Network Settings > Network Mode and make sure Dual Mode is selected, if not select it by pressing the Ok button and choose Dual Mode.
Also go to Settings > Network Settings > Operator Selection and verify if Automatic is selected or not.
If both the above methods don't help, restore the phone to it's default settings. Go to Settings > Factory Default or Restore Factory and select it to proceed, if you are asked to enter security code, use 12345 (by default).
If this doesn't work, I think your phone has some problem or your phone is locked to some or one network. Try another sim card and see if it works or not.
Note: The sequence I've mentioned above to enter the select settings are general for Nokia, it might be a little different or the name of the options might be different. Hope you'll get it somehow. If you have problem, let me know.
Good Luck.
Thanks for using FixYa.
Jun 12, 2011 | Nokia 6030 Cellular Phone
Need to unlock motorola droid to work with my att acc i know it can be done
If this is a phone that is not branded by your service provider (example: it's a verizon phone and your trying to use it with att) you first need to make sure that it is compatible w/ att network. The phone needs to be able to take a sim card. Second, you would need to get an unlock code from the provider that the phone originally came from. Once you have that they will inform you how to unlock the phone and you will be able to use it on the other network. Be aware that since the phone is actually made for the other network that it may not work properly. This is because the phone is designed to work on a different network and will have different settings, therefore it is not guranteed that it will work to it's full capabilities, especially the internet.
Mar 14, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
My computers can't detect wireless signal from my
Yes ! the wireless network name could be different than the wired network name.
If you connect the cable to the router and the computer it works .
check the wireless settings of the router.
Click Here for step by step solutions
Nov 06, 2009 | D-Link AirPlus Xtreme G DI-624S Wireless...
Can't change printer in Corel Paintshop Pro
It sounds like this is a laptop because you mention different networks. If so, this is not a bug in the program. If you are completing a file on one network, choose the printer before you start. If you are changing networks, you need to remember to change the printer when you open a file. Use Print Preview to see if any adjustments are necessary.
This extra step is needed to have the flexibility of working with different printers,
Jul 29, 2009 | Corel Paint Shop Pro 9
Phone unlocking
Master Code: 2021307120
However for network unlock inform me the country and network to which your phone is locked and confirm the model is Nokia 6500 (NHM-7).
Sep 26, 2008 | Cell Phones
Cell Phones Logo
42 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
