Question about Garden
Ryobi 410r cultivator starts and runs, for lack of a better term, at full throttle continuously, no matter the position of the throttle, needle screw settings or idle screw position. The carb has been disassembled, cleaned and reassembled, using the original gaskets, they looked new. This problem started within months after the original purchase. Dealer was somewhat helpful but went out of business about end of warranty period. Need to find solution to this problem.
  • 7,482 Answers
Hi Dennis
Check to make sure the governor spring has not fallen off, broken, etc. from the frame of the engine.
Also make sure that the governor blade is not jammed with leaves, weeds, sticks, etc.
Bud
Posted on Oct 18, 2013
4 Suggested Answers
SOURCE: Ryobi gas string trimmer won't run
I have a RYobi SS30 and it will not run at all. I have pulled the cord about a hundred times, yes after about 10 I should have gotten the picture, but if anyone knows what to do to correct this I would appreciate this. I am not very mechanically inclined so any help would be appreciated
Posted on Sep 28, 2008
#1 Taper
  • 1040 Answers
SOURCE: Ryobi SS30 trimmer starts fine and runs at when in full choke position to about half choke position. But when I put the choke lever to the full run position, it stalls out. Ryobi ss30 same problem of
You need to rebuild the carburetor. You will need to go to an outdoor power & equipment store of some kind to get a carburetor kit for your specific trimmer. It will come with various gaskets, (some of which you won't use), a needle valve, and a small screen that goes in the carb. Replace all old parts with new. New primer bulb is sold seperately. When you have the carb. apart, you will also need to clean the small ports with a Den Tek Brush (used for cleaning teeth). Use carb. cleaner when cleaning.
Jim
Posted on May 29, 2009
  • 85 Answers
SOURCE: Ryobi SS30 Carburetor Problems
Replace thecarb screen, make sure you can see through the screen
Posted on Aug 19, 2009
Ryobi 410r
Go to lowes ask for mechanic in a bottle, see directions. Before using dump old gasoline out.
May 26, 2013 | Garden
I have a Ryobi 410r 31cc tiller. It will start and run for acouple of minutes then stop.
take off the muffler and try it again if better then open the muffler and clean the screen most pry open
Aug 18, 2012 | Ryobi Garden
Fuel oil mixture ratio for ryobi 410r cultivator
I have a 410R still looks like new.
it has on it gas & oil = 40. to 1 for mixture.
mine never gets used so it is still new.
Jun 23, 2010 | Ryobi Cultivator
Ryobi 410r cultivator needs intital carb adjust ments,where do i start,how vmany turns on idle and high idle?
screw in lightly till seated then back out 1 turn each. low is for idling and turn in or out for best idle then run full throttle and do the same for it, get highest rpm then turn out 1/8 more on the high jet.
Jul 10, 2009 | Ryobi Cultivator
Gas tank leaks on a 410r how do we take it off.
remove the screws holding the recoil cover off I would think and go here for parts and use your model numbers to find your unit.
www.ereplacementparts.com/ryobi-tiller-parts-c-7931_15702.html
Jul 01, 2009 | Ryobi Cultivator
No choke on 410r
you need to leave the trigger alone until it fires.once it fire you throttle up to release the the choke.the choke is internal.hopes this helps and if you have any other questions let me know..............
Jun 02, 2009 | Ryobi Cultivator
Unable to start Ryobi 410r cultivator
After starting close the choke , push the lever back in
Vitally
Carburator floods as soon as you fill the gas tank . this is a ryobi 410r tiller.
you have a needle valve stuck open. i am not familiar with your model but if you can remove the float bowl and clean it out maybe replace the needle and seat and the float it should fix the problem good luck.
Apr 27, 2009 | Ryobi Cultivator
Need Replacement Gas Line for Ryobi 410r
They have the parts your looking for at www.lawnmowerpartstore.com
Apr 12, 2009 | Ryobi Cultivator
Garden Logo
63 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
