Question about Linksys WAP300N Dual Band N300 Wireless AP
Not connecting through network. Was before. Don't understatnd
Need network key
What cable or internet modem are you using at&t, comcast,dish network,etc?
Jan 20, 2013 | Computers & Internet
Wireless is connected but internet wont detect connection
For wireless connections:
1. Hold the Windows key and press the R key, type services.msc and press Enter or click OK. This should open a new window - services local.
2. Look for Wireless Zero Configuration on the list in the right pane. The list is alphabetical, so you should be able to locate it maybe third from the bottom.
3. Double-click it to open it.
4. Click on the STOP button to stop it (lower left). If it is not highlighted or is grayed out, then the service is stopped. (it should also say that the SERVICE STATUS is stopped).
5. Look for STARTUP TYPE drop-down menu. Change it from AUTOMATIC to DISABLED. then click on APPLY (lower right).
6. Then just change it right back from disabled to automatic and click on apply again.
7. Click on START button (right beside the STOP button) on the same window to start the service.
--- We are essentially restarting the windows wireless service. What we did just turned it off and on again ---
8. Close the services local window.
9. Go to Start and then Control Panel. Network Connections. If you don't see Wireless Network Connections or Local Area Connection after opening Network Connections, kindly look for Network Connections again (it maybe on the lower right).
--- We need to be on the page where you have the wireless network connections icon. ---
11. Right-click on the icon for Wireless Network Connections then left-click on Properties.
12. You should have several tabs. Click on Wireless Network Connections tab (near the top of the window).
13. Make sure you have a checkmark on where it says, "Use windows to configure your wireless connections..." or something like that.
--- Before going into the next step. Kindly make sure first that you have the following CORRECT information: (1) your own SSID; (2) Network key (if you have one) - WEP or WPA or whichever encryption you are using. If you don't know these information, kindly secure these information first or better yet, try calling your router manufacturer to help you out on this ---
14. Then on the list that shows on the same window, remove everything on the list. That list shows all the wireless networks that you have been connected to before.
--- Don't worry about deleting it. The next time that you connect to the wireless network, it will be automatically added back into this list ---
15. Once everything is removed. Kindly close the window.
16. Go back to where you have the Wireless Network Connections icon again.
17. Right-click again the icon and left-click on View Wireless Network Connections.
18. If your wireless router is broadcasting your SSID, then you should be able to see it on the list of wireless network(s) that will appear on the screen.
19. Select your SSID and hit Connect.
20. It should be asking for your network key. Type it in. In might ask you to confirm the network key. Just type it in again.
21. It will attempt to connect it. And you will get a notification that you are connected.
22. Once you are connected, go back to the window where you have the Wireless Network Connections icon we were working on before.
23. That icon should say that it is connected.
24. Double-click it. It should open a new window.
25. You should have a General tab and a Support tab.
26. General tab should say it is connected.
27. Click on the Support tab.
28. Now confirm if your IP Address says 192.168.x.x. where x can represent any number. Example: 192.168.0.100
29. If you have these confirmed. Kindly try to see if you can now get into the internet or into your network.
30. Enjoy!
let me know if this don;t work for you Blankzero
Apr 15, 2012 | Computers & Internet
I cant get wi-fi on my acer 5742-7620 dont know what username or password and defult means or how to get an ip addres or even my pin number is or what networks im looking for i live in winkleman arizona
Rachael,
YYou need the SSID (network name) and password of the wireless network you are trying to connect to. If you don't have this information, there is a 99% chance you will not be able to connect. If you don't have access to a wireless network, go to any computer store and buy a wireless router to connect to your home network. The login information for the router will be included.
Oct 09, 2011 | Computers & Internet
Laptop will not connect to internet via router. Will work when connected direct through a cable. Getting message 'validating identity'.
This happens when windows can't complete identifying whether you are connected to a public, private or home network. This is often the case when the router doesn't support IP6 (which virtually all home routers don't).
In most cases you can safely disable IP6. To disable see the following microsoft knowledge base article (which also has 'FixIT' scripts to make the changes for you)
http://support.microsoft.com/kb/929852
Once IP6 is disabled re-join the wireless network and complete the identifying process, i.e. select home, work or public network depending on what you are connecting to.
Please take the time to rate this answer.
Many Thanks Don.
Sep 05, 2011 | Computers & Internet
Cannot connect to network
Let's get you connected!
Please Note:A broadband Internet connection and wireless router are required. Follow the steps below to get connected.
For a step-by-step video tutorial, click here.
  1. Turn on your Nintendo DSi and access the System Settings by clicking on the wrench icon.
  2. Scroll over to the third page, and select "Internet."
  3. Now choose "Connection Settings."
  4. Click on "None" for "Connection 1."
      connection_1.png (Don't see "None" for Connection 1? To ensure any existing settings don't interfere with getting connected, tap the button, then choose "Clear Settings.")
  5. Click on "Search for an Access Point."
  6. The Nintendo DSi will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds. Look for your wireless network. (If you're not sure which is yours, or you don't see any wireless networks, click here.)
  7. What to do next will depend on the "lock" icon you see next to your network on the Nintendo DSi. Click the image below that matches the lock icon you see on the screen of your Nintendo DSi.
Aug 14, 2011 | Nintendo Dsi Pink Console
How do you connect internet
1. Turn it on and access system settings. [[wrench icon]] 2. Scroll to page 3 and select "Internet" 3. Choose connection settings. 4. Click on "None" for "Connection 1." If you don't see "none" option for Connection 1? Make sure any existing settings don't interfere with getting connected, tap the button, then choose "Clear Settings."
5. Click "Search for an Access Point." 6. The Nintendo DSi will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.Look for your wireless network.
7. What you'll do next is choose the open lock, gold closed lock, or silver lock...
Open lock: No security.
8. Select ok, save settings, then yes. Once you see connection successful... the support code is unimportant.
Jul 09, 2011 | Nintendo DSi Blue Console
I have an I4 phone. The only wifi I can connect to is Linksys. I have other networks available but don't know codes to join with. What to do?
Hi there!
It is possible that the Linksys wireless doesn't have any password/WEP key to connect that is why your phone can connect to it. You can't the other networks available if you don't have the password/WEP key. It has password enabled to prevent unauthorize connection to the wireless. I suggest you subscribe to your own wireless connection so you don't need to worry about connecting to any wireless network available.
May 08, 2011 | Apple Cell Phones
Trying to connect DSI to internet
These instructions come from http://www.nintendo.com/consumer/systems/dsi/en_na/usb/index.jsp and should be able to help you solve your problem. Good luck!
May 07, 2011 | Nintendo DSi White Console
I can't connect internet because i don;t have the
click here type you model in the top left corner and find the driver.
Dec 29, 2009 | ASUS PCI-L3C920 Network Adapter
Central Locking system blows 20 A fuse.
In response to your request I'd like to say that I have not solved the problem yet but intend to investigate the central locking relay in the engine compartment.
Also wish to say that I was led to believe that Fixya was a group of enthusiasts willing to share their knowledge. I did not understatnd that it was a for fee service.
Thanks for the reply.
les87
Dec 27, 2008 | 1999 Volvo S80
Linksys WAP300N Dual Band N300 Wireless AP Logo
35 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
