Question about Photography
Pentax me super. Help I was attempting to rewind film manually. I may have not used all the film. But pressed the little button on the bottom and started to rewind. But after some turning it won't budge and the knob will not pull up to release door to retrieve film.
    Novelist:
  • 357 Answers
Did you rewind in the direction of the arrow on the knob. Sound like you might have rewound film backwards
Posted on Oct 17, 2013
informatica
  • 1114 Answers
SOURCE: Pentax ME SuperProgram shutter button doesn't release shutter
It is possible that the mirror is stuck in th "up" position. You should be able to fire the shutter as you say on the 125x setting with no batteries. You can download the manual from the link below: http://mcfaddenphoto.com/camera_manuals/pdf/ME_Super.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 26, 2007
  • 44 Answers
SOURCE: Camera keeps rewinding film
Check the manual rewind button on the bottom plate of the camera. Make sure the button is not jammed under the edge of the button opening. If it is you might be able to carefully pry it out with a sharp pin or tooth pick (be careful not to pierce the button or you could damage the circuit board underneath) Or you could remove the bottom plate and reseat the button (be careful of a loose spring to the film door latch)
Posted on Dec 12, 2008
  • 185 Answers
SOURCE: Film Rewind Button Problem!
mistermanage,
turn the advance lever to charge the shutter.or open the film door and rotate the drive sprocket to the right, this will release the button. if the button didn't pop up then the bottom cover will have to be removed in order to release it manually.
Posted on Feb 03, 2009
  • 4 Answers
SOURCE: Pentax MZ 50 film winding problem
Well, I'm not a camera repairman, but it sounds to me (and probably to you too) that the electronics are damaged or perhaps there's dust in the contacts inside. I also have an MZ-50. There's so many electronics involved and they don't age so gracefully. I would consider buying another one off eBay or you can get a ZX-30 (same as MZ-30) for $75 from Blue Moon Camera & Machine with a 1 year warranty (parts and labor). The best way would be, in my opinion, to get a manual, mechanical camera from the 1970s and put a good lens on it. Those seem to last forever. No electronics to worry about. Advance and rewind the film manually. You can use a digital camera as a light meter to set the aperture and shutter speed. I'm thinking of going this route when my MZ-50 finally conks out.
Posted on Mar 26, 2010
SOURCE: pentax me super mirror in up position
If the batteries are flat or missing you wont get LED's to light up and it will set itself to 125 naturally. I know as I have tried it. It could be that the shutter has got stuck on its way down and it is preventing the mirror from coming down as a result this is a mechanical issue, not battery related. The best way I found to release the mirror was to gently, really gently stroke the shutter nearest to the film down towards the groove it goes home in. Recommend a cotton budd so you don't damage the shutter leaves or get grease from your fingers on the movement. This should release the mirror. The next thing to do is try preventing the shutter getting stuck again by removing the bottom plate which will allow you access to the cogs for the shutter. it is tight in there and it is recommended by some that you remove some of the movement to see and clean them up. I did this but it is tricky and it involves winding on the camera and rocking parts out with itself. Not easy to do. The shutter cogs are brass (or look like it) and they may have old oil stuck inbetween the teeth which needs cleaning out with a tooth pick and then lubricate but not with WD40 which gets sticky with age. Use a cotton budd again with the lubricant on so you don't affect other sensitive parts around this section. Alternatively send the camera for a good service. I just had mine done, got it sorted with a warranty for 12 months to and cost me just £45. They cleaned everything up, new light seals and sorted issues common to this model of camera. The photos are instantly back to their best. Compare a good service to a series of wasted film with an inconsistent camera. Peace of mind too, it is worth it and so is the camera!
Posted on Jun 02, 2010
Rewind button on bottom of camera is stuck in a depressed state and will not release. This causes me to be unable to rewind or load film, shutter button will not cause shutter to click, film advance crank...
Sounds like your camera could use a cleaning and oiling, I'd suggest sending it off to Gus Lazzari for repair. He does good reliable work to film cameras. Hope this helps.
May 10, 2011 | Pentax ME Super 35mm SLR Camera
How can you rewind the film
Lift up the rewind crank. Press the film rewind button on the bottom of the camera and turn the crank clockwise. Rewind until the tension on the crank lessens, indicating that the film leader has been released from the take-up spool. Pull up on the film rewind crank and the back will open.
Dec 03, 2010 | Pentax ME Super 35mm SLR Camera
Don't know how to open the film door
To open the film door just pull the rewind crank upwards. Make sure that you have rewound the film first though! (press the rewind button on the bottom rear right of the baseplate, and then turn the rewind crank clockwise until you feel the film disengage from the take-up spool).
Please take a moment to rate my reply.
Sep 03, 2010 | Pentax ME Super 35mm SLR Camera
How do I rewind and take the film out of a pentax k1000?
mhamabrown,
push the rewind button on bottom of camera and turn rewind knob to the right, ( clock wise ) then pull the rewind knob up to open the film door.
Feb 24, 2009 | Pentax K1000 35mm SLR Camera
How can I rewind film in a Pentax Zoom 60-X camera
I used to use point and shoot film cameras. My guess is that there is a button underneath which when you depress will automatically rewind the film. Sometimes the button is very small that you may need a ballpen point to press it. Hope this helps cuz i have no idea what the Pentax Zoom looks like. I am guess it is a point an shoot type and not an SLR. If it is a point and shoot type, you must be sure the battery has power or else it won't rewind.
Jul 18, 2008 | Pentax Cameras
Film advance broken.
Press the rewind button and wind the film advance lever, It will set to its place. Release the rewind button, press the shutter release button.Once again try wind the film.( provided your camera is not fitted with motor wind )
Mar 27, 2008 | Pentax ME Super 35mm SLR Camera
Film will not advance
Pressing the rewind button wind the film advance lever,if it is free It will set to its place. Release the rewind button, press the shutter release button.Once again try wind the film.( provided your camera is not fitted with motor wind )
Then your winding gears need cleaning
Jan 18, 2008 | Pentax ME Super 35mm SLR Camera
Manual Rewind Pentax PZ
Hi Joel,
If your battery is dead, just put in a new battery.
Go into somewhere that is completely dark and open the back of the camera and remove the film.
Or go Costco, WalMart and Kmart and they will do it for free.
Dec 13, 2007 | Pentax ME Super 35mm SLR Camera
Wind up film button
This is a common problem with the older Pentax SLRs : shutter / mirror box needs servicing . The problem is caused by perished rubber parts. Although the problem is easy to fix, it has to be carried out by a pro because the mirror box has to be removed from the camera so that one can have access to the shutter and the side of the m-box where the problem is. Costs ? +- $150.
Nov 04, 2007 | Pentax ME Super 35mm SLR Camera
Aug 26, 2007 | Pentax ME Super 35mm SLR Camera
Photography Logo
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
