Question about Car Audio & Video
Sony cdx gt170s wiring diagram
Can i hook up amp for sub woofer in this model and what is compatible with it
  • 101 Answers
Yes. This model has a dedicated zubwoofer output. Virtually any sub woofer amp that connects via RCA will work.
Posted on Oct 17, 2013
Cerfer39
  • 709 Answers
SOURCE: sony cdx-gt170
Hi MalJars,
Clarion normally uses the following colors for each channel.
Front Right Gray and Gray/Black -
Front Left White and white/black
Rear Right Purple and purple/black
Rear Left Green and Green / black
Yellow is memory backup Stays at 12 volts all the time
Red is Switched power and comes on only with Key on.
Posted on Nov 30, 2007
welcomejee
  • 10594 Answers
SOURCE: need a wiring diagram for sony cdx-gt41ou head
Click Sony Support to download wiring . connection manual of CDX-GT410U
Posted on May 17, 2009
SOURCE: Wiring Diagram For Sony Disc Player
how do i install a cdx-s2210 to my 92 camry..what wires do i connect?
Posted on Jul 11, 2009
  • 10 Answers
SOURCE: need wiring diagram for sony cdx-gt200
blue\white stripped= amp remote
black= ground
blue= ant
red=positive
yelow=positive 12v
white=left +
white\black striped= left -
gray= right +
gray\black striped= right -
green=left rear +
green\black striped=left right -
purple=leftr rear +
purple\black striped=right rear -
Posted on Jul 19, 2009
  • 1126 Answers
SOURCE: Need A wiring harness diagram for sony CDX-GT300
Sony head units use either a 9 pin connector, link below:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C285614
Or a 16 pin connector, link below:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C217600
And here is a kink to your installation guide.
http://www.docs.sony.com/release/CDXGT300_Installation_Guide.pdf
And your Operating Instructions.
http://www.docs.sony.com/release/CDXGT300.pdf
Posted on Jan 09, 2010
How do I install amp and sub woofer to my Sony CDX-GT110?
Your amplifier must have speaker level inputs in order to connect to this Car deck. Can you give me the model number of the amp?
Feb 16, 2017 | Sony Car Audio & Video
What's the best way to hook up my jl audio 13" w 7 sub to my jl audio 1000/1 amp
the best way? hmm. i would start off with some wire. Keep in mind that you will need to separate the positive (usually red or has a stripe or marking on it) from the negative (Black usually is the common color for this wire) and hook the up according to your amps positive and negative hook ups / terminals following your sub-woofers terminals. then depending on your sub woofers Voice coils (Duel or single voice coils) yours are duel or quad coils but i\'m sure they are duel (2 of each positive and negative equaling a total of 4 posts on each sub-woofer). figure out your amps ohm load handling and does your amp run hot (1,2 or 4 ohm stable some are even less like 0.5 or lower) i would run at a 1 or 2 ohm load as that is usually standard on 1 channel amps. make sure to check your wiring and if your not sure about ohm loads just Google wiring for sub-woofer ohm loads such as 0.5 ohm, 1 ohm, 2 ohm or 4 ohm loads. also make sure your box is not sealed do to the fact they are siht and cant produce sound like a vented / ported enclosure keep the size as big as you can fit in your car or truck the bigger the better. i had one 8\'\' sony sub pounding like a 15\'\' sub real loud . Also MDF particle board is garbage it causes port noise and absorbs water
Apr 28, 2014 | Car Audio & Video
How do I hook up a sub woofer to my 52wx4 radio. I
You can hook it up a couple of ways.
Depending on how many subs you have and what ohms they are running at here is the chart you need. If your going to run one sub off it the last option is the way to go. Your going to need to find out the power of your subs or else the power could be off and you could blow the sub. If the rms power is higher than 130watts per coil you will be fine. If so there are four channels on the amp and two should show a line going to each other that says bridge. Hook up the positives and the negative of the subs as shown on the amp that will get your max power. If your sub is running at 4 ohm. Let me know, if not thats how you would do it.
Also for the power and remote wires. Hook up a power wire (16 gauge would be plenty fine) from the battery to the + terminal of the amp. Then take an equal or bigger sized wire from the - side of the amp and secure it to any medal part of the body of the car. If there is paint on it get if off. (not on the outside of your car or where any water would be.) Then run a remote wire from your stereo (most the times it is blue and white) to the remote terminal of the amp. This tell the amp when to turn on and off. Your amp will not turn on with out all of these wires. Good luck to you and let me know how it works out.
  • 4 x 55W RMS @ 4Ohm
  • 4 x 65W RMS @ 2Ohm
  • 1 x 130W RMS @ 4Ohm - Bridge
  • Mar 14, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
    Sony X-Plode amplifier. NOT working
    It is possible if the model amp you have is bridgable to 1 channel. Usually when you bridge an amp you will need to hook one wire to the positive side of one channel and the negative side to the other. You will need to consult you user manual for the amp or get the manual from the sony website for instructions on how to bridge the amp or if the amp is even bridgable.
    Oct 11, 2009 | Car Audio & Video
    No sub signal from a CDX GT520.
    connect the speake(sub) directly to the stereo(just use one of the rear 6x9 speaker wire to test the sub and make sure it's not the amp. if it does not work, it's the sub
    Sep 07, 2009 | Sony CDX-GT520 FM / AM Receiver
    Circuit diagram of 1400 watt woofer amplifier
    www.the12volt.com/ subwoofer wiring diagrams and then find out what ohm of sub u have and how many voice coils and what ohm your amp is stable at.
    Jun 10, 2009 | Beyma WOOFER, 1400 WTS, 18" => Model...
    Amp powers on but sub does not come on
    I would double-check your RCA's on the amplifier. You should hear a thud if you unplug them. If not they are either not hooked up or defective.
    Feb 07, 2009 | Sony XM-2150GSX Car Audio Amplifier
    Amp help
    it might not be the amp that is not working it could be the sub or sub's. Try takeing a sub out of the box and look down the hole in the center of the magnet on the back of the sub and look and see if you can see any wire's or any thing that has come unwound in the sub and if you do see wire's then you have blown your sub. If you dont see any wires then you could completly disconect your amp for 20 to 25 minutes and then plug it back in and see if that fix's your problem. If none of this works then you can take your amp to an audio store and have them test the circut board in your amp.
    Dec 22, 2006 | Sony Xplod XM-1652Z Car Audio Amplifier
    Car Audio & Video Logo
    46 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
