I have a mitsibushi 735 series n there are very tiny black dots u can see only when the tv is on some look like they blink and are white but all fade away slowly once the tv is turned off!
    Top Expert:
  • Televison & ... Master
  • 74,468 Answers
This is not a fault to TV. This is a manufacturing defect to the panel, and can't be repaired at all. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Posted on Oct 17, 2013
  • 367 Answers
SOURCE: TruTech PLV1615T has Sound but No Picture
Open the back of the TV,and look at the can shaped items on the board that the power cord is hooked to.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.So far I have fixed four of the same make,and model TV as this,and they all had either one,or two bad capacitors.I hope this helps.If you have any other questions,please let me know.Thank You very much!
Tyler
Posted on Aug 23, 2008
  • 304 Answers
SOURCE: I cannot get the tv to turn on. The red standby
You either have a bad T-Con bd or a bad Main bd. Have a trained samsung troubleshoot the set.
Posted on Jul 17, 2009
falter
  • 245 Answers
SOURCE: First our tv had purple dots now we have about six
well u have stopped ur movies(dvds) to many times and the dots are burn marks on ur screens
if u read ur manual it will tell u NOT to leave a still picture on for to long as it will damage ur screen
i assume u have a PLASMA TELEVISION
if not... sorry cant help u
Posted on Nov 20, 2009
SOURCE: the television just went black then slowly faded
What is decoder board?
Can you give me part number of that board and where do I buy that board?
Posted on Apr 14, 2010
TV #1
  • 129 Answers
SOURCE: I was watching Tv and the picture starting from
You need to replace backlight inverter.
Posted on Nov 01, 2010
Msi L1350d screen has tiny horizontal lines
If it works fine when you connect to your tv then you've probably got a loose cable on the screen. You'll have to strip it to check.
Mar 29, 2014 | MSI L1350D-1672US Netbook
Little white dots in tv modle# wdt657 what are they how can i get them off
Your TV is DLP projection TV. DLP is Digital Light Processing. Digitally processed light coming out of DMD (Digital Micro mirror Device) is projected on the TV screen. This DMD is made of thousands of tiny mirrors & the size is about 0.7 inch. These mirrors are fixed with tiny hinges for its movement. They reflect light as per processed signal. DLP is invented by Texas Instruments. When there are dots on the screen, that means the tiny mirrors representing the dots are stuck in its position. If the dots are few & the viewing is bearable, just leave as it is. If the dots are more than bearable then you will have replace the DMD chip which is quite costly.
Sep 25, 2011 | Mitsubishi WD-Y657 65" HDTV
I have a mitsubishi 735 series dlp tv. Has red blinking status light. The error code was 4 blinks then two blinks. Do you know what is wrong with it?
That's the error indicating the lamp/ ballast fan has stopped working. You can get the Mitsubishi lamp / Ballast fan 299P321010 used in the V39 series DLP televisions. It comes with installation instructions and is available from www.tvrepairworld.com under the Mitsubishi DLP parts category.
Aug 25, 2011 | Mitsubishi Televison & Video
PB Minos GP2W screen has coloured lines fades white then black
Most likely it's graphic card problem, but also may be monitor itself. First, check the signal by connecting to TV (if yours has a PC input), then replace card if that shows the same.
Aug 29, 2017 | Computers & Internet
White dots on tv screen-HL=55686W
You have a faulty dmd board. That board is responsible for all the tiny mirrors and some of those mirrors are in the stuck on position. Replace the dmd board and the dlp chip and you will be good to go. I would recommend having an authorized service center do this as there can be some painful alignedment needing to be done.
When it powers off by itself, do the LED's on the front blink? All 3 or any combination of the 3?
Dec 29, 2009 | Televison & Video
First our tv had purple dots now we have about six tiny black dots on the tv screen. We notice we had large purple dots running vertical on our tv screen. A couple of days ago we noticed a small black dot...
Nov 20, 2009 | Televison & Video
Had one last week and now there are 6. they are
You get white spots inside the samsung DLP tv due to bad Digital Micromiror Device , or bad DMD board .
What is actually the problem is the DMV chip connected to this board . Inside this chip are 3 million tiny mirrors ,and when they physically get stuck , they either show black or white instead of a color
This is well know problem with SAMSUNG DLP...
The DMD chip is failing.If not under warranty expect to pay a few hundred to several hundred to get it fixed
The mirrors on the DLP chip are slowly sticking either fully open (white) or fully closed (black). The part that contains the DLP chip is the Light Engine. It is the most expensive part of the TV.Only the Samsung TVs has this issue.
Replacing the DLP chip and the micro mirror would solve this issue...
Pleaserate this solution,
Rnj VINODKUMAR
Nov 11, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
There are tiny black dots on my LG Vantage screen
I have the same thing too. My guess is that some of your MEGApixels (tiny squares that create your screen) Are fried.
Mar 30, 2009 | Cell Phones
Two week old Samsung LCD TV has a tiny white dot on screen when black.
it sounds like a pixel is messed up. if its only two weeks old, then your best option would b to exchange it and get a new one
Oct 21, 2008 | Televison & Video
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
