Question about Whirlpool Duet GHW9150P Front Load Washer
Washer comes up with error f6 - Whirlpool Duet GHW9150P Front Load Washer
  • Whirlpool Master
  • 5,343 Answers
The F6 error on a Whirlpool Duet means that the control unit doesn't know the drum RPM speed during the spin cycle. It occurs with a number of problems. The problem could be with the MCU (motor control unit) or the wiring between the motor and the MCU. Next you should check the wiring between the MCU and the CCU (main clock). A problem with the door lock or that wiring could also cause the issue. Finally, the bearing on which the drum spins is bad.
The MCU is the most likely faulty part unless you find a wiring problem. (The wiring harness has a number of small wires connected to it; it's not uncommon for one wire in the group to break while the rest are intact.) Inside the washer's front panel, there should be a wiring diagram with additional information on some diagnostic steps.
If you can't easily spin the drum by hand, then the bearing is a likely suspect.
I hope this helps.
Posted on Oct 17, 2013
I have an f6 code and the machine will not operate once it comes up
The F6 error code means that the computer on the control didnt detect that the motor reached a high speed on the spin cycle, sometimes it thinks the washer didnt spin fast enough because of a loose wire connection either on the motor or the control boards (motor &machine control) if you find that the washer did actually spin at high speed (clothes dont come out sopping wet at the end of cycle) the wire connections or the motor control board will be the potential causes of the F6 error code. Try unplugging the machine for five minutes to let the computer reset then try again. Next check the control panel wires. f6 code flashing on display Kenmore Elite HE3 Washing Machine
May 19, 2015 | Washing Machines
Washer error F06 E01
The error codes F6 E1 for Maytag Maxima 6000 front load washer means that the MCU AND CCU are not communicating. You need to check the wiring and plugs to make sure they have a good connection.
Feb 10, 2015 | Maytag Washing Machines
Ho do I reset the whirlpool error codes f6
F06 Drive motor tachometer error The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Replace failed component.
Whirlpool Duet error f6 Google Search
Sep 06, 2014 | Whirlpool Duet WFW9151YW 27" Front-Load...
F6 error on Hitachi washing machine Sk 120KJS
Jul 09, 2012 | Washing Machines
Why does the washer stop during a load and "F 06"
GENE
Sep 09, 2011 | Kenmore HE2 Plus Front Load Washer
Whirlpool front load washer getting an error code of "F6"
f 06 is a in issue with the motor control board, check the wiring harness attached to the board.
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error "F6" on my Smartwash Quite Pak9
I believe the F6 code is a motor failure. I suggest you call a pro to come out and look at it.
Sep 22, 2009 | Kenmore Elite 45986 Front Load Washer
He 3t error code f6,washer will not spin,door will not open
"f6" error code means that there a miss communication between mcu(motor speed control board) and ccu(central control unit). i recommend you to ohm out the motor. most likely its your motor speed control located at the bottom left of the washer good luck. replace the motor speed control board and you should be all set to go.
May 09, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
F6 Code
f6 communication error in ht emotor controll board, located in the lower left front of machine
Nov 07, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
47 people viewed this question
Dan Webster
Dan Webster
Sal De
