Question about Precor C966i Treadmill C 966i
Flashing red led light on lower pca? - Precor C966i Treadmill C 966i
Precor efx546i error 30
Precor Error 30, 31, 32 and 33, Communications Error Probable Cause 1. Bad interconnect cable between upper PCA and lower PCA.
2. Interconnect cable is mistakenly plugged into the CSAFE connector at the upper PCA.
3. Elliptical 5.17 equipped with old software version 1.01 in upper and lower PCA.
4. Upper and lower PCAs have mismatched software.
5. Another component plugged onto the PCA is overloading the +5VDC power supply.
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
  1. Test unit with a know good interconnect cable or test the interconnect cable for continuity. Replace interconnect cable if necessary.
  2. Disconnect the interconnect cable from the CSAFE connector and attach to the proper position on the upper PCA.3.
  3. Replace the upper and lower software of the 5.17 elliptical with the most current versions.4.
  4. If one of the PCAs is found to have software version 1.01, replace it with the most current software version.
  5. Disconnect all components from the upper and lower PCA leaving the data cable connecting between the upper and lower PCAs and the AC power going to the lower PCA. If the unit shows any error other than the error 3x, reconnect components one at a time. Reset power between each newly connected component until the error 3x reappears. Whichever component was last connected when the error 3x reappears, is the cause for the error. Replace the faulty component.
  6. Test unit with a known good lower PCA. Replace the lower PCA if necessary.
  7. Test unit with a known good upper PCA. Replace the upper PCA if necessary.
Precor Error Code 30 31 32 33
Jun 25, 2014 | Precor EFX 546i Elliptical Version 4
I have a PROMASTER PROSELECT treadmill it stop, and error came up #30
Description
Errors 30 through 33 all indicate the loss of communications or erratic communications between
the microprocessors in the upper PCA and the lower PCA. The trouble shooting procedures for
all of the are essentially the same. Error 30 is defined as upper PCA not receiving from lower
PCA. Error 31 is defined as faulty data received from lower PCA. Error 32 is defined as lower
PCA not receiving from upper PCA. Error 33 is defined as faulty data received from upper PCA
Possible Causes
1. An upper PCA to lower PCA interconnect cable is bad.
2. The interconnect cable at the upper PCA was mistakenly plugged into the CSAFE connector.
3. A 5.17 EFX equipped with version 1.01 upper and lower software.
4. A 5.17 with mismatched upper and lower software.
5. A defective lower PCA.
6. A defective upper PCA.
Possible Remedies
1. Substitute a know good interconnect cable between the upper and lower PCAs to determine
if the interconnect cable is defective.
2. Remove the interconnect cable from the CSAFE connector and insert it in the correct upper
PCA connector.
3. Replace the 5.17 upper and lower software with the most current software versions.
4. If only one of the upper or lower software is version 1.01, replace the version 1.01 software
with the most current version of software.
5. Substitute a known good lower PCA to determine if the lower PCA is defective.
6. Substitute a known good upper PCA determine if the upper PCAs defective.
PCA =printed circuit assembly. test it and fix it.
God bless you
Feb 22, 2013 | Exercise & Fitness
Precore efx 546 error 30
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Jan 31, 2013 | Precor EFX 546i Elliptical Version 4
Efx546 error 32
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Feb 19, 2012 | Precor EFX 546i Elliptical Version 4
Precor EFX 5.23 display dead
CHeck the fuses on the lower board. You may also want to unplug the eddy current magnet and speed sensor from the lower board and the heart rate sensor(if there is one) from the upper board to make sure they are not shorted out and not allowing the upper to light up.
Jan 24, 2012 | Precor Exercise & Fitness
Error 32
Description
Possible Causes
Possible Remedies
PCA connector.
Dec 10, 2011 | Precor 9.31 Treadmill
Error 8:11 HP Designjet T1100ps 44in PS3
Error indicates Formatter,Hard disc & main PCA any one of them faulty.. Through light pattern we can estimate which part is faulty...Read carefully, understand the indications..
Led pattern: Power supply LED as 1
Formatter leds 3nos from left to right as 2,3 & 4..
* indicates "on"
# indicates "off"
& indicates "flashing"
* # # # ....Main PCA
* * # # ....Formatter
* $ # # ....Hard disc
* * * $ .....Main PCA or Formatter
Note down which LED are on.off & flashing,compare with above said indications find out the faulty part..
d4wd6icgpc9laaaaaelftksuqmcc
nloqafiqpfr0pqy6fgsl6z+nlcjwrqeuxlt5siey8sjpc+feblil6+xgwjruzafracof0e359teuwi1ozhlmhrx0xfmcd+bfeilmn5l+ppik2hpic6wgwvpqfwee1yw0nvg1qi9vzo58bnigp4octvkvtsy87834sjn6odbsmoha2eycmv8comsjb7raqh4aaaaasuvork5cyii=
May 03, 2011 | HP Designjet T1100ps Printer
When I turn on my plotter error message system error 08:11
* indicates "on"
# indicates "off"
Note down which LED are on.off & flashing,compare with above said indications find out the faulty part.. 11_19_2011_3_40_14_pm.jpg
Apr 19, 2011 | HP Designjet T1100ps Printer
ERROR CODE 18:10
* indicates "on"
# indicates "off"
Nov 29, 2010 | HP Designjet T1100ps Printer
My Hp Designjet T1120 fails to initialize. When mains is switched ON the Front Display Panel in the plooter illuminate without any display and the Power switch in the display panel flickers with green...
Reset the formatter & check,,
* indicates "on"
# indicates "off"
Oct 11, 2010 | HP DESIGNJET T1120 44 Printer
Precor C966i Treadmill C 966i Logo
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
