Question about Prestige Replacement Alarm Antenna Elvntrcb 118c1123
I have an after market alarm the model number on it is 118c1123 -- other than that I do not know what it is called. Sometimes the car will not unlock when pressing the remote many times. It only does this periodically but is an issue since if I manually unlock the doors with the car key the alarm goes off and the "kill-start" is activated. No help from place who installed, which seems to be out of business, or from the dealer. Do I need a new alarm system?
    Sergeant:
  • 206 Answers
Hi
first i would change the remote control battery's
if that works i would buy compatible remotes and reprogram via that working remote for a spare
i that didnt work
i would open the car via the key remove the cover under the dash below the steering wheel
there are normally 2 fuses to a car alarm remove the fuse on the red power led that will disable the alarm
but it will also disable the remote central locking
but you will b able to unlock the door with the key a start the car
aries
Posted on Oct 19, 2013
I have a Seat Altea and need to know if I will encounter any CPU or alarm problems if I remove the factory fitted Blaupunkt radio entirely from the vehicle?
Radio's don't affect the security. But if installing another factory radio, it has to be programmed to your car. After market radios don't. If using an after market one, you will loose some chimes, like door,key,lights, ect...
Sep 03, 2016 | 2008 Seat Altea 2.0
How can I deactivate the alarm on my car short term? Is there a fuse I can take out to make the alarm stop altogether?
If the alarm is factory wired, you may not be able to because it may set off the immobilizer and kill the ignition system. If it's after market then you need to either read the paperwork that came with it and learn how to go into valet mode or you need to contact the manufacturer of the alarm system and ask them. But they'll want to know model and serial number.
Nov 01, 2013 | 2008 Nissan Sentra
An emergency personal alarm for seniors with high risk heart problems?
There are several on the market from a audible alarm to the more sofisticated models that ring an emergency number when activated. They can be found at shops that cater for this equipment or at chemist shops that will give directions as to get them .
Oct 12, 2013 | Cars & Trucks
There is a non-factory anti-theft device keeping my truck from starting. How do i remove it
I would before you do that call a few places that install after market alarms---cutting may not solve the issue and could just make things worse--see if you can locate the unit (brand on the remote??) for a brand or model number.
Cutting without knowing may be foolish.
Dec 05, 2012 | 1997 Ford Expedition
How to determane if my jeep has a after market alarm or a factory?
The factory alarm is tied into your ignition switch. Most newer vehicles have an anti start system incorporated into this in case it is broken into. The alarm will shut the system down and will not allow the vehicle to start. Look under the dash under the driver side and see if you can locate a small box. Should have a serial number barcode on it. If so it has a factory alarm.
Mar 31, 2012 | 2007 Jeep Liberty
Car alarm goes off after locking the car.sometimes ten minutes smoetimes three hours after but it still goes off ive disconnected the alarm horn for now but still get the siren noise.i dont know what to...
How old is the alarm? If you have glass breakage detection or motion sensors installed one of these could be faulty. If the alarm is more than a year old and it's an after market alarm it is possible the alarm is faulty and needs to be replaced. There is a fuse in the power supply line, usually running along the firewall between the power point and the alarm. Remove this fuse and the alarm should be deactivated but the ignition kill switch will not be active so you can use the vehicle and the siren will stop going off.
Sep 09, 2009 | Vehicle Parts & Accessories
Alarm system stoped working on 87 caddy fleetwood
First question , is it a FACTORY alarm or an AFTER MARKET alarm. Regardless, I haven't met an alarm yet, that protects the radio.. My guess is, that if it is an aft/market alarm, inadvertantly placed the system in the "VALET" where it doesn'i work. Let me know if you disconnected battery, and are there alarm toggle switches.
Mar 23, 2009 | 1995 Cadillac DeVille
Prestige Replacement Alarm Antenna Elvntrcb  118c1123 Logo
169 people viewed this question
Top Prestige Electronics Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Prestige Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
