Question about Sony Car Audio & Video
My subwoofers/amplifier were attempted to be stolen and the wires were all cut. Can I still use these wires or do I have to break open the sub box and replace the wires (which is the only way to get to the wires).
  • Sony Master
  • 637 Answers
I suggest replacing the patch cors at least. The other cables can be spliced. Not taped.
.A thumbs up would be greatly appreciated if this answer is helpful to you. My subwoofers/amplifier were attempted to be - uploadserror image is too large. maximum size: 500k
Posted on Dec 19, 2014
    New Friend:
    Problem Solver:
  • 5 Answers
Yes you can still use these wires as long as there is enough room left to wire them back together and use black tape over them
Posted on Oct 17, 2013
  • 631 Answers
SOURCE: No power output
Set the meter to AC volts and measure the AC voltage on the RCA cables where they plug into the amplifier. The black meter leat will go on the shield ground of the RCA cable. The red lead on the center conductor. You may have to turn the volume up to get a reading on the meter. At high volume, you should read at least one volt but the actual voltage will vary due to the audio signal. If you get no voltage on the RCAs, measure the AC voltage on the input to the LOC. Let me know what you find.
Posted on Oct 05, 2007
Hazardsneon
  • 100 Answers
SOURCE: Lanxar VW12D no sound after excess play
I'm not understanding what you mean by the "Sub doesn't even sound blown" if it doesn't play at all. One thing you can check is if you gently push in on the cone you shouldn't hear anything, if you hear a scratching noise and can feel resistance then you have a problem. If you have an OHM meter, you can check the voice coil impedance, it is a down and dirty way of checking to see if it is good or not. Measure all of the voice coils that you have and they should all read about the same, not necessarily exactly the same but pretty close. This test should tell you a lot. If it seems to test out fine there is something wrong else where. Let me know if you need more help.
-Andrew Hawkins
Posted on Apr 03, 2008
sumthin
  • 71 Answers
SOURCE: lanzar optidrive series 4000watts mono block digital compitition class amplifier
Firstly, sorry to to tell you, but their is no such thing as a 4000 watt car amp. Google Ohm's law and RMS .
Check the owners manual or website to find the amps minimum impedance. Usually 4 or 2 Ohms. Next,
check the woofers impedance , If unsure check with a Ohmmeter,
It's actually the resistance,but close enough.
If they are 8 Ohm and you twist those wires together (parallel circuit) your amp will see 4 Ohms.
If they are 4 Ohms (paralleled) your amp will see 2 Ohms.
Do not connect in a series circuit (+ amp terminal to a + speaker terminal and that speaker - terminal to the other speakers + terminal and that speakers - terminal to the - amp terminal) .
It creates phase problems, and sounds like ****.
Most mono amps are really internally bridged stereo amps ,it's cheaper that way, but it limits how low of a impedance they will handle. Read the specs. Use the correct size connectors, scrape off paint for a good ground connection.Use the right gauge wire and above all. Fuse that power lead at the Battery!!!!!!!!
ps . if you have dual voice coils thats another chapter.
Good luck, Sumthin
Posted on Jun 11, 2008
etirbynnor
  • 655 Answers
SOURCE: amplifier loads
Hello ronnieyannon,
A single 4 ohm speaker wired to each channel, like you have them wired, presents a 4 ohm load. And it appears that you have them connected properly. The 401s is only stable to 4 ohms when bridged, so if you were to parallel the 2 4 ohm subs in bridged mode, the load would be 2 ohms and the amp would most likely overheat and go into protection.
I'd wire them the way you have them wired.
Each channel of the amp outputs only 100 watts into 4 ohms. That is adequate for regular full-range speakers, component speakers, mid-range drivers, and even some small subs. But it is a little low on power for most subwoofer applications.
Hope this helps.
Posted on Apr 23, 2009
etirbynnor
  • 655 Answers
SOURCE: amplifier turns on but not the subwoofer?
Hello thedj3214,
You can find the color codes for a 1999 Buick Regal here. There is no dedicated amp remote wire. Neither is there a power antenna wire.
You could use the 12V "switched lead (yellow) from the radio or any switched 12V lead directly from the vehicle fuse box. I'd wire it through a dash mounted toggle switch so as to be able to turn the amp on and off manually.
The Sony 2150GSX is a 2-channel amp with the speaker terminals on either side. You do not want to ground the subwoofer itself, only the ground terminal should be connected to bare metal on the vehicle chassis or body as close to the amp as possible. The ground wire does not need to be run to the negative battery terminal.
A ground on one of the speaker leads will probably cause the amp not to power up. A ground on a speaker wire usually activates the amps protection circuit, causing it to not operate until the fault is corrected.
Hope this helps.
Posted on Jul 29, 2009
Sony xplode 1000watt amp. Was playing music turned up louder and sub cut out. Checking wires found ground wasnt crimped completely to connector so redid that. Now as soon as I put fuse in power line box I...
Isolate the problem by testing the subwoofer to make sure it isn't fried. If the problem isn't the subwoofer then your amplifier must be checked at an audio store.
Nov 19, 2017 | Car Audio & Video
I have all alpine speakers,deck,amp, and subs. My subs were working for about a year until one time i started my car and they keep cutting in and out .. at times they will work but then they cut off...
Sounds like blown subs, in the process of completely dying out, or a loose wire, possibly inside the box or from the box to the amp. Have your subs tested at a sound shop, or using a multi-meter, check for resistance across the sub terminals. An open line indicates a blown sub.
Jan 19, 2011 | Alpine MRP-M500 Car Audio Amplifier
Wondering if non soldered terminals will cause subwoofers to cut in and out...amplifier turns on and stays lit green but subs cut in and out...have had amp and subs switched over from another vehicle in...
You're right; The clip-type or pinch-terminals could have just enough wiggle room to break connection when the box vibrates....causing the In & Out scenario.
You mentioned that the set (amp & subs) were mated in another vehicle, so there's little doubt that the subs are under-rated for the amp, right?
No chance that the sub-level adjustment was cranked up during the move, causing the aging subs to wash out...and you triple-checked the polarities,right?
Mar 28, 2010 | Sony TA-FE370 2-Channel Amplifier
Connect stereo amplifier to powered sub
You can y out from the main out to the sub.This output is post volume control. set level on sub to desired balance of lows feq to highs
Nov 20, 2009 | Yamaha YST-SW015 Subwoofer
I have found a Oz Audio Vector Power 15 but this is all I can find on this beast: http://www.carreview.com/mfr/oz-audio/subwoofers/PRD_173701_1808crx.aspx I need numbers to formulate a box and to determine...
On the amplifier side, I will need the wattage, and frequency of the speaker to tell you what amp you will need.
Subwoofers differ in only one way. You get an "Open Air" and a "Closed air" subwoofer, That being said, you'll have to check on your magnet which one you have to make the boxes for that sub. If it is an "Open air" Subwoofer, you should see a "wire mesh" or "grid" in the centre, at the back of the magnet. If it is a "Closed air", the magnet will be solid with no hole whatsoever.
If it is a "Open air" sub, your boxes should be sealed with silicone, and no ports are to be cut in your box.
With "Closed air" subs, you should have 2 ports below your sub and the port sizes should be around 50mm in diameter. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 250mm, depending on the frequency of bass you require.
On a 15 inch subwoofer ranging between 80Hz and 120Hz, the box size required should be around 27 liters, meaning that you will end up with a box of 16 inches high, x 16 inches wide, x 16 inches deep. Or 320mm high, x 320mm wide, x 320mm deep.
Enjoy!
Nov 15, 2009 | Car Audio & Video
1 10 jl jl 250/1 mono block amp cuts off an on help
your subwoofer is wired incorrectly to your amplifier. Figure out which ohm load of subs you have and then what ohm load options your amp is stable at. Next go to either the Crutchfield website. find their learning center. go to subwoofer wiring diagrams. or go to www.the12volt.com and find their section on it
Jun 11, 2009 | Jl Audio 250/1 Car Audio Amplifier
How do i hook it up
On the Sub you have 4 connectors, 2 for each voice coil... Run a jumper wire from One side of the sub to the other. Positive to negative so that now you have one set of connectors free. Doing this will make the sub able to handle more cause you're using both voice coils. Thats how i've always hooked mine up when i have duel voice coil and they always last a long time. If you're gonna bridge the amp, make sure its turned down for about 5 or 6 hours to let the sub break in.
Mar 10, 2009 | Pioneer TS-W307D4 Car Subwoofer
How to wire 2 ohm 2 12ich alpine type r's to box terminals?
Dual 4 ohm subwoofers can only be wired @ 1 ohm, 4 ohm or 8 ohm.
2 ohm mono load is not possible.
You will need to use (1) subwoofer to get the 1000W out of the amp.
Wire both positives on one sub to + on amplifier and both - on the same sub to - on amplifier to give the amplifier a 2 Ohm load.
Add a second amplifier, or buy an amplifier that is 1 ohm mono stable.
You can wire both to the amplifier at 4 ohms 600W, but they will share the power and only see 300W ea.
Jan 12, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
Subs not hitting
remote wire turning on amplifier?
Ground for amplifier?
Gain improperly set?
Radio output crossed over above tuning freq. of enclosure?
Just suggestions. Not much info to go by.
Dec 15, 2008 | Jensen BP212 Car Subwoofer
Car Audio & Video Logo
75 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
