Question about RTO Cummins Onan HomeSite Power 5500
I have an onan marquis 5500 watt RV generator that runs fine ,but won't generate.
    Scholar:
  • 95 Answers
Call Onan and tell them the Inverter Board is bad. If you're not producing AC Power, have them send you a new board or warranty the entire genset. It's unusual for Onan products to go out like that, but not unlikely that this is the source of the problem.
Typically, the DC motor outputs at 12 volts, so the leads going in to the inverter are only going to be a ground and a positive lead. Should be very simple to replace. Worst case scenario is you can hook an external inverter up to the DC leads on the front of that generator. Might not get the full 5.5kw from the system, but you'll be able to produce some power.
Posted on Oct 18, 2013
4 Suggested Answers
  • 76 Answers
SOURCE: 1000 watt Yamaha generator surges when on low setting
YOU PROBABLY HAVE LINKAGE PROBLEMS ON THE CARB IS IT AUTO THROTTLE IF SO YOU MAY ONLY NEED TO ADJUST THE SETTING SCREWS GIVE ME SOME DETAILS LIKE BRAND HORSE POWER CARB BRAND AND MODEL AND I MAY HAVE THE EXACT ANSWER FOR YOU I HAVE ALOT OF SMALL ENGINE RESOURCES FOR SPECS AND DIAGRAMS
Posted on Jun 24, 2009
  • 52 Answers
SOURCE: i need an onan generater wiring diagram
Many times these generators are sold at camper/ motor home dealers some already installed in their units. It's an outside chance but they may have access to a manual. Also if generator has 1-800# call it.they may can help as well. Hope this helped God Bless
Posted on Sep 18, 2009
harlan301
  • 205 Answers
SOURCE: onan generator.will start but will flood out
your going to need to check the carburetor. sounds like your fuel sys is contaminated. when you unplug the fuel solenoid the plunger pops up and cuts the fuel off. the solenoid is used to shut off fuel to keep the unit from back firing
Posted on Oct 14, 2009
The generator surges and stops while rv is in motion.
Did you get this fixed? this is an old post. If not visit www,advanced-power-technologies.com (Cert Cummins Dealers) They can answer your questions.
Oct 05, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
WHAT IS ERROR/FAULT CODE 37 ON A ONAN 5500 MARQUE GOLD GENERATOR ?
Code 37 is a bad set configuration, that means engine cranking speed and generator output aren't happy with each other..
Sep 30, 2014 | Onan Marquis Gold RV Generator 5500 Gas
Where is the fuse on the onan 5500 built in generator?
Try under the bench seats around the table, near the heater.
Jul 14, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
My onan marquis gold generator runs no problem, when I put a load on it, it doesnt ramp up, the fault code is 14, this is a marguis gold 5500 spec d
Does it bog down? if so have engine checked for ability to deliver HP. Cylinder compression, leakdown test. When was it tuned?
Jun 23, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
Onan marquis gold gas generator 5500 stops running after 5 minutes
Check fuel pump pressure, how long has it sat. What load is on after it stops?
Jun 10, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
Onan 7000 watt generator rv starter problems
Can you be more specific than just starter problems?
Jan 17, 2013 | Onan Marquis RV Generator 7000 Watts Gas
RV Onan 4000 runs fine but not putting out enough voltage to run anything
Not sure how to set it up but you can take it and have the voltage turned up on your generator or the voltage regulator is out.
Sep 09, 2009 | Watts Onan Portable Generator - 4000 ,...
Onan genset generator in rv is running but no power to rv...circuit breaker has been checked and main breaker in rv has been checked still no power
on your generator ther is a reset if thats not it check for fuses if still no then u neda check the wires in the pluges if no then ur generator it self needs re bilt
Aug 29, 2009 | Watts Onan Portable Generator - 4000 ,...
RTO Cummins Onan HomeSite Power 5500 Logo
219 people viewed this question
Top RTO Electrical Supplies Experts
Ottoniel
Steve
Tom Chichester
Are you a RTO Electrical Supply Expert? Answer questions, earn points and help others
