Question about Lands Phones
Answer machine doesn't disconnect upon caller hang up
    Scholar:
  • 277 Answers
What phone? what answering machine? what phone system?
You have not provided any details.
If you mean Voice Mail on a Business Phone system then Supervision Disconnect needs to be programmed, call a vendor/tech in.
Posted on Oct 17, 2013
2 Suggested Answers
SOURCE: GE Cordless answering system-27995
hi all i want to have inst. manual in english which isnt with me can anyone tell me how to download from net. thanks.Pls. also email to peraanalagan@hotmail.com
Posted on Sep 22, 2008
Phone ringing but not switching over to answer machine
I used to have an answering machine. The line needs to be plugged into the machine, "LINE IN" and the phone needs to be plugged into the machine "PHONE," the machine needs power and be turned on.
Depending on the model there might be an "ANSWER ON" that has to show a light, to have it intercept incoming calls after the set number of rings have elapsed. You may have all of the above set up correctly, but the machine is not set to ANSWER ON.
My machine could answer and leave a message to the caller and hang up, or it could be set to record the caller after the greeting. These options were in my menu.
Since I do not have specific information on your setup, This will serve as a general checklist.
Jan 08, 2018 | Answer Lands Phones
How to change number of rings on VTect cordless CS6114-11
The CS6114-11 isn't an answering machine. It will ring until you answer, an answering machine or voicemail system picks up, or the caller hangs up.
To change the ring count on your answering machine, consult its documentation. If you require further assistance, please add a comment to this question and identify the answering machine or voicemail system.
Jul 30, 2014 | VTech Communications CS6114 - cordless...
Want to change from a 3 ring answer to a 5 ring answer
The CS6119 isn't an answering machine. It will continue to ring until someone or something picks up or the caller hangs up.
If you have an answering machine connected, please refer to its documentation or else repost your question and specify the make and model of the answering machine.
Sep 03, 2012 | Lands Phones
Change from 3 ring answer to a 5 ring answer
Answering machine Model 25865. Is there any way to turn the answering machine "on" remotely. Example: while away, electrical storm causes machine to turn off. Is there any way to remotely...
The manual for this phone doesn't say you can turn the answering machine on remotely, but every one I've ever seen can do so. Most of them say call your number and let the phone ring...and ring...and ring, and eventually the answering machine will turn on. Ten rings is what I've seen most often. I guess the manufacturers figure most callers will hang up fairly soon if the machine doesn't answer, so they pick a large number. Try it on your phone; worst that can happen is it won't work.
Jul 09, 2011 | Uniden Cordless Phone
Call conferencing
Here are the instructions for making a conference call on a Norstar system.
Conference [Feature] [3]
  • Establish a conference call between yourself and two other parties.
1. Make or answer the first call.
2. Put the first call on hold.
3. Make or answer the second call.
4. After the second call is connected, press [Feature] [3].
5. Press the line or intercom button of the first held call.
6. Press [Rls] to end the conference call
  • To remove yourself from a conference permanently (unsupervised conference):
    • Press [Feature] [7] [0]. The other two callers remain connected. (Some external lines may not support this feature.)
  • To put a conference on hold:
    • Press [Hold]. The other two callers can still talk to each other.
  • To split a conference:
    • Press the line or intercom button of one caller to consult privately while the other caller is on hold. To re-establish the conference, press [Feature] [3].
  • To disconnect one party:
    • Press the line or intercom button of the caller you want to disconnect, then press [Rls].
    • Press the line or intercom button of the remaining caller to resume your conversation.
  • To independently hold two calls:
    • Press the line or intercom button of the first caller, then press [Hold]. The second caller is automatically put on hold. To re-establish the conference, retrieve one call from hold, press [Feature] [3], then retrieve the second call from hold.
May 11, 2009 | NorStar Meridian M7310 Phone
Call waiting
when the phone ring just press the answer key, when the calls end then just click yes to retrieve the lst call without disconnect the caller
May 12, 2008 | Motorola Mobility RAZR V3
Auto-answer issue: fax beeps on line when voicecall received
Try changing the receive mode from automatic to FAX ONLY and set the number of fax rings higher. You should be able to receive phone calls and if you are not answering your phone it will automatically receive a fax.
Mar 27, 2008 | Office Equipment & Supplies
Tg5632
Check your settings in your answering machine menu. 1) is it on? 2) number of rings? 3) is it set to take messages or answer only? If the machine is ringing and never answers look for a problem under items 1 and 2. If it answers, plays your greeting then hangs up on the caller, look at number 3. If all those settings are correct, power it down, repower it back up, wait a few minutes to call it.
Jan 29, 2008 | Panasonic KX-TG5632 Phone
Lands Phones Logo
20 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
