Home | Dell | Axim X30 Pocket PC | Axim x30 won't come up
Dell Axim X30 Pocket PC
Problem for Dell Axim X30 Pocket PC
By jdjmizell on Apr 24, 2009
It has green light on but nothing else. I just got this.. So I don't know how to do the resets. Any help appreciated.
Jd
Solution #1
posted on May 01, 2009
Not Rated)
combomatrix
Rank: Apprentice
Rating: 0%, 0 votes
The Dell Axim X30 be soft reset by pressing the "Reset" button (from the stylus tip) on the rear of the unit, below the battery.
If the Dell logo in blue background lights up and then goes off again, its probably the brightness setting of your unit. Once the device has started up, just press and hold the jog wheel (the volume wheel above the headphone jack on the left side of the PDA) and press the UP directional key in the front bottom of the PDA. Every press of the up key should brighten up the screen a bit.
If the above solution does not work, you probably might need to hard reset your device.
WARNING: A "hard" reset wipes the RAM and returns the Pocket PC to its factory defaults. You might (mostly) lose all your data if you perform a hard reset. Do not hard-reset your device without having a backup of your data.
The procedures for hard resetting your ppc is given in a very detailed steps in the following page:
http://www.pocketpccentral.net/help/dellx3reset.htm
Was this helpful?
Yes
No
Popular Solutions for Dell Axim X30 Pocket PC
Questions and Unsolved Problems for Dell Axim X30 Pocket PC
Do you recommend Dell Axim X30 Pocket PC?
Answer
Answer
how do i connect my dell axim x30 to my bt home hub so i can surf the internet? I am totally lost.... (More)
Answer
Cuando conecto el Pocket al computador este no reconoce la conexion. Cuando trato de sincronizar no... (More)
Answer
can you tell me how to connect to the internet
Answer
The screen is shwing vertical lines of various colors will nit soft or hard reset.
Answer
what charger will work that is sold in a retail store that will charge a axim x30 pocket pc?
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell Axim X30 Pocket PC:
Top PDA Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more PDA Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
