Question about Irons
Polti Vaparella Forever 600 Steam generator Iron.Working when used last week Pump not working, boiler & iron heat up, no lit LED's pump appears to be 240v 2 neg terminals 1 live via diode from PCB & Earth. Found condensation under PCB which had discoloured the solder joints but tracks tested OK to solder pads cleaned PCB. There is a reed switch on 2 wire fly leads from PCB. 2 sided PCB all top side components look pristine electrolitic capacitor looks normal no leaks or bulges. Any idea Anyone as all components now listed as obsolete & unavailable from internet stockists. Any advise would be most welcome Thanks
snakehead
  • 1074 Answers
SOURCE: My Tefal Steam Generater Iron will not steam
check the little tube that regulates the water to the holes it needs to be changed.good luck.
Posted on Apr 18, 2007
  • 833 Answers
SOURCE: Tefal Pro Express Steam Generator Iron
Irons are generally not worth repairing. That said, try to clean out any mineral deposits with a mixture of 1/3 vinegar and 2/3 water. Put in the usual amount. Warm the iron, try to get steam. Empty the iron and do it twice more. Then, rinse it out with plain water.
You may get lucky!
Posted on Jan 23, 2008
SOURCE: Tefal Pro Express Steam Generator doesn't.
OK... so I have fixed my problem of NO STEAM, just lots of water coming out of the iron press plate itself... I had already cleaned the boiler, so I tried adding 1/4 tsp - 1/2 tsp bicarbonate soda to the water and flushing it through. From what came out of the iron press plate, I would say the problem was caused by a build up of goop (technical term) inside the iron. Once cleared, the iron is steaming away again. Please note, u will need to have an old towel handy if this is ur problem, 'cos until it starts getting better, there is a fair amount of water coming out of the iron press plate. Just add the bicarb to the water reserve and use the steam buttons to bring the bicarb through. Do not attempt to iron clothing with the bicarb in the water!!! Carolyn ;)
Posted on Sep 20, 2008
SOURCE: Seeking stopper for Tefal pro 2500 1875 steam iron/generator
I too was looking for one
http://www.partmaster.co.uk/cgi-bin/product.pl?PID=146230&query=tefal%20stopper
cost £20.99
Posted on Nov 13, 2009
  • 96 Answers
SOURCE: no steam from iron
check the dial is in steam position or maybe you may have build up in the line for the steam
Posted on Dec 13, 2009
Hi guys. I have a Hoover ironspeed IS21-1 steam generator iron. I love this iron it's the best steam generator I've ever had but now once it's heated up and I go to use it as soon as I press the button...
Try unplugging everything that is using that circuit because it's possible that you have too many items plugged up. Also try other outlet.
Jan 14, 2015 | Irons
Logik steam generator iron no steam
Service the steam and spray mechanism:
Unplug the iron.
Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
God bless you
Jan 24, 2013 | Irons
The boiler part is working fine but i have no
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Oct 25, 2009 | DeLonghi Stiromeglio Compact PRO 300 Iron
I have a Russell Hobbs Steam Generator iron - less than two years old. It has started to leak water - not really sure where it's coming from - it just pours out and eventually fuses the plug.
My Russel Hobbs Steamglide iron has stopped pumping steam , iron itself heats up but no steam...has the pump gone and can it be reapired
Oct 08, 2009 | Irons
Steam button on iron has stopped working yet iron still heats up and light on boiler still goes on.
this just happened to us & the electronics man at my husband's plant took it apart & said the thermostat needs replaced. the wires were all eaten up so to speak
Jun 10, 2009 | Rowenta Steam Generator DG050 Iron
Euro-Pro Steam Generator G6200H iron
heatman101
May 18, 2008 | Euro-Pro Steam Generator EP8001 Iron
Nov 12, 2007 | Tefal Ultraglide 1549 Iron
Irons Logo
93 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
