Question about Video Game Consoles & Games
My sega plays the game but it's distorted and flipped a weird way why won't it work right I tried every thing
  • 118 Answers
Probably dust in the game cartridge (sometimes blowing on it is not sufficient). Best way to clean a game cartridge is with a cottonswab and some rubbing alcohol
Posted on Oct 19, 2013
  • adi mo
    adi mo Oct 19, 2013
    I've tried that and it don't help and it's with all the games
  • cole man Oct 19, 2013
    I have had a sega change colors on me before and ended up being the cord that attaches to the tv. I would wiggle the cord right where it attached to the sega and that would make the problem better or worse (propping up the cord where it attaches to the sega fixed it but if wiggling the cord produces no effect i wouldn't recommend doing this)
SOURCE: Sega Genesis not showing a picture
As I had just a similar problem with my MegaDrive/Genesis maybe this helps: Try an older TV set. I am not joking. It might very well be the case that newer TV sets/high-end TV systems can't handle the signals of the older video game systems. I have a 100 hz TV set and whereas there are no problems with a SNES, with the MegaDrive I just had a black and white screen with bars running through it. On a 60 Hz TV set this problem does not occur. Keep in mind that there were no 100 hz/HDTV sets around when these video game systems were in general use.
Posted on Aug 12, 2008
mumma_1
  • 903 Answers
SOURCE: xbox 360. My som moved
yes it is very possible, if moving the machine while in game play the disk can become burned, making it unplayable.
Posted on Nov 16, 2008
  • 42 Answers
SOURCE: My Sega Genesis/CD is not working. It seems to be
call a tech guy
Posted on Oct 07, 2009
  • 14 Answers
SOURCE: Sega Saturn doesn't boot correctly. Can't play games.
This could be a situation where the Laser Lens voltage is off and it is not reading CDs. I have had this before.
You will have to take your case off, and look for a little orange "screw" or "dial" which is just above the cable that connects the laser assembly to the circuit board. It might have a Philips head looking top.
Make sure the system is off and unplugged before doing this.
Turn the orange screw approx 35 degrees clockwise, and the reassemble the system. This should give the laser enough juice to start reading the discs again.
If this is not the solution, it is possible your clock battery is dead. Buy a new CR2032 3Volt battery from wal-mart or your local watch store, and pop it into your top right (on the back of the system) compartment to fix this.
Good Luck!
Posted on Feb 01, 2010
lexzy80
  • 943 Answers
SOURCE: Ps3 Graphics Distortion
maybe the tv you are using is not very well compatible with those game since they can be played in HD.try playing thme in another ps3 console or using another tv.
Posted on Mar 08, 2010
Sega genesis model 2 black screen
Well take all your game cartridges clean inside on the chip board thing you see that connects to system to make game play..take rubbing alcohol with q tip clean them all both sides .let dry bout few minutes..make sure console ain't dusty kinda blow it out a little...mine do same thing when stored..after games clean keep trying them ..it will get them to start working ..good luck
Aug 12, 2013 | Sega Genesis 2 Console
My sega genesis won't work - it was working fine
You screwed it up by plugging it into the 64. It is too old to handle that kind of stuff. I reccomend going and getting youself a Xbox 360 slim. They are much more efficient.
Oct 29, 2012 | Video Game Consoles & Games
Recently got a SEGA Genesis from GoodWill. When I put in a game the screen is very distorted and covered in pink pixels but the sound comes through just fine. Is it maybe the connector pins that need...
Under most circumstances the data is not dysfunctional. If other games work on your setup, than it's that individual game that is messed up, and the first thing that goes is the pins.
Aug 12, 2012 | Sega Genesis Console
I have 1985 Sega hang on......plays but won't
I don't think Hang On has a DIP switch for gear shifting or speed, it sounds like you may need to calibrate or replace some of the controls. Here is a link to the owner's manual.
http://www.arcade-museum.com/manuals-videogames/H/Hang%20On.pdf
May 11, 2012 | Sega Video Game Consoles & Games
Sega won't same game progress
These classic consoles don't have (long-term) saving features. Sorry
Oct 22, 2011 | Sega Genesis Console
Hi. I have a problem with my sega genesis console. When I play a game, in this case Mortal Kombat III, the screen freezes after a while and there is nothing I can do but to restart the game. Also, the...
This might sound stupid, but it always worked for me! Get a pencil with a clean pink/red eraser at the tip of it- one that's never been used. Put it into the game, and rub it like you did with the Q-Tips (Left to Right). Get out a Q-Tip and clean the inside once more (Without alcohol) so that all of the eraser shavings are out of the game, and try to play it.
If this doesn't help, I'm sorry, but I don't know what to do. I've never had a game glitch after doing the pencil trick.
I really hope this helps!
Aug 10, 2010 | Sega Genesis Console
I have Microsoft Windows XP Professional but I am unable to use Sega Worldwide Soccer CD Rom. I get a message coming up saying ' Cannot run on Windows NT 5.1 ( Build : 2600) I would be very grateful if you...
Hi Maguerite
Am I right in thinking that you are trying to play a game made for the Sega Saturn on a PC? If so, it will only work in a Saturn.
Hope this helps
Scott
Mar 24, 2010 | Sega Sports Worldwide Soccer for Sega...
Medieval Total War II Kingdoms screen is flashing
try getting a better graphics card i had the same problem and i got a better graphics card put in my computer and have never stopped playing it
Apr 30, 2009 | Sega Medieval II: Total War Kingdoms for...
BOX THINGY
the box is a RF switching box
the lead you require is a phono to ariel lead (megadrive, master system or any old computer will do)
or if you get an old video lead and cut of one end and wire a phono plug to it it will also work.
or you try ebay
http://shop.ebay.co.uk/items/_W0QQ_dmptZUKQ5fVideoGamesQ5fVideoGameAccessoriesQ5fVideoGameAccessoriesQ5fJN?_nkw=sega+rf++Master+System++&_sacat=0&_fromfsb=&_trksid=m270.l1313&_odkw=sega+rf&_osacat=0
a basic lead for £2.50
replacments upto £10
both work
Oct 15, 2008 | Sega Master System Console
Dreamcast Loading problem
you can get disks relayered at game stores.
there was a long period where this happened to me.
some games worked for a while, some didnt.
its the dreamcast.
you might wanna get anew power cable or just clear out the dust because that is the main problem with the dreamcast.
try playing with the console upside down
it sounds crazy but it worked for me.
Dec 18, 2007 | Sega Dreamcast Console
Video Game Consoles & Games Logo
21 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
