Question about Toshiba 42HPX95 42 in. Plasma Television
Where is the fuse on the inside of this tv? - Toshiba 42HPX95 42 in. Plasma Television
    Top Expert:
  • Toshiba Master
  • 74,198 Answers
Check for it at the main power supply regulator board. You can locate it there.
Posted on Oct 17, 2013
Can dust make a tv stop working
no its probably a fuse in the circuit board inside the TV, dust would only affect it if you threw a bucket full at the TV with the rear panel off,
you will need a fuse tester to try the fuse in the plug if you haven't already and then the ones inside the TV if the plug one is OK, you will need to buy the correct fuse amperage as putting a larger amperage in it could possibly result in a fire or further damage, usually the fuse only blows the tv fuse if it is left on standby all the time, replacing the fuse and turning it off every night will prolong the life but won't cure it it is only a temporary fix and in no way constitutes a fully tested repaired tv.
hope this helps
Nov 08, 2016 | Televison & Video
Sanyo DP26640 LCD TV won't power up. Is there a fuse somewhere inside?
Every TV will have an AC fuse inside. This fuse can be located at its main power regulator [SMPS] board. This is a protection fuse; and if it is found burned [open], there should be sufficient reason for it. some kind of short circuit, or over voltage etc: Replacing this fuse without make sure, about the cause to burn the fuse; the newly inserted fuse too will fail, and more damage to set can occur. So, it is better to contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Jul 22, 2016 | Sanyo DP26640 LCD TV
Not powering up at all. is there a fuse on the inside? quick fix?
Yes,there is a fuse inside in the tv main board near the a/c power cord.Hope that all the fuse problem,usally it is not.
Jun 13, 2011 | Toshiba MV20FM4 20 in. TV/VCR Combo
Toshiba TV dead: is there a fuse inside? Toshiba 24AF46 is dead after a thunderstorm and nearby lightning. Plug sparks when I plug it into the wall. Nothing happens on the TV. No sound, nothing when I hit...
Yes,there is a fuse in inside on the tv main pcb board near the power a/c cord.But if the tv have sparks,main pcb board could have more other components fries too.If tv less 10 years repair it by a shop,more than that should buy a another tv.
Jun 09, 2011 | Toshiba 24AF46 24" TV
Is it possible to change fuse on panasonic hi def plasma th50px75u tv. if so what are the fuses and where located?
They should be fuse(s) in the power board and or the Y Board.
When the fuse goes bad it means other component(s) are bad which made the fuse to go bad.
You can try but, just be very carefull use only the same fuse.
My advise is to call a repairman.
This information is for someone that knows electronic.
1000s of volts inside the TV that can kill. Even if you unplug the TV the high voltage can be stored inside the TV for days.
Best of luck.
www.aaatvservice.com
Mar 04, 2011 | Panasonic TH-50PX75U Plasma HDTV
Television has no power. outlet has power and cord from outlet to television has power. is there a fuse?
All telivisions has fuses inside. Some of them has one, and some has two. If your tv doesn't power on, and power chord and outlet is ok, surely the fuse inside may blown out. There may be some reason for the blowing of fuse. Fuses are used inside tvs are for protection purposes. f any overvoltage or over current taken by the system, the fuse will blow out. you must fist find out the resom for the bowing of fuse. New fuse must be put in only after that check. Otherwise you will spoil the whole circut board inside the tv irrepairable. Concat a service personnal, and let him do that. Ok.
Remember, different tvs have different power ratings. Must select proper fuse according to the ratings.
Oct 13, 2010 | RCA 32F531T 32" TV
The tv has no power its a sony kp-53s65 no light or nothing
hello you may to check the glass fuse inside the tv it will be in the power supply if it's black in colour it's blown make sure you put in the same rated fuse back in the value will be at the end of the fuse or on the fuse holder on the power supply board but beware if it blows again then you have a dead short inside the tv someware good luck
regards
shaun
Jul 29, 2010 | Sony KP-53S65 53" Rear Projection...
How to replace fuse on sanyo tv DS 24424
Actually, when a fuse blows, most of the time there is something that went bad and is causing the fuse to blow. Some TVs don't use the typical glass fuses. Instead the might use a surface mount soldered component. These components are usually labeled with the letter F for fuse. Example would be F1 or F2. They are usually found near the power cord or near the power supply. Hope this helps...
Feb 01, 2009 | Sanyo DS24424 24" TV
MY SCREEN IS DARK OR BLANK EVERYTHING ELSE WORKS GOOD JUST NO PIC
Hello fixedopsmike,
There is a fuse in the TV set, if you would like to check and see if it has blown, here is a way you can do it:
1) Unplug the TV's power cord from the wall
2) Take the back off of the TV by removing the screws and slowly removing the back panel.
3) Look for a component that looks like a glass tube with metallic caps on each of the ends, this will be the fuse.
4) Visually inspect the fuse to see if it shows signs of being open (Blown) These signs are burn marks inside of the glass tube, an open conductor (wire) inside of the glass tube, or no visible wire inside of the tube.
5) using a multimeter set to resistance (R x 1) test the fuse for continuity (remove and change the fuse if found to be defective)
6) If the fuse is not bad, reinstall the fuse if removed, put the rear cover back on.
Now at this point we have determined if the problem is a fuse being blown or not, if you replace the fuse and the TV works great the problem is solved, if you replace the fuse and it blows again, or if the fuse was ok to begin with, then you have a problem that will require some knowledge of electronics pass the basics to continue on. At this point I would suggest that you call a qualified TV repair technician to troubleshoot and repair the TV in question.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Nov 22, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Power surge I think
If you do not get any clicking or sound when trying to turn on the TV set, most likely the main fuse went out. This is almost always due to something else blowing out along or making the fuse to blow out. DO NOT SIMPLY REPLCE THE BLOWN FUSE! If there is other shorts inside the set, and you replace the blown fuse, you can cause more damage to the TV set. The best way to test this set if the fuse is blown would be to hook up a 100 to 150 watt light bulb across the blown fuse, and if there is a short in the TV set the light bulb will glow bright and stay bright. If the bulb lights up and goes dim maybe just maybe you got luck so replace the fuse and see what happens. If the light bulkb stays bright, there is a short in the set somewhere and if you do not have a service manual and a good multimeter and a knowledge of how the TV power supply works, you really should call in a pro to assist you in the repair of this TV. there is just too much High Voltage inside these TV sets to be experieenting around inside of it. Good Luck.
Mar 14, 2007 | Toshiba 36A43 36" TV
Toshiba 42HPX95 42 in. Plasma Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
