Question about Troy Bilt 5.5hp Self Propelled Mower
Tecumseh 5.5 coil 2005 - Troy Bilt 5.5hp Self Propelled Mower
    Sergeant:
    Champion:
  • 320 Answers
TecumsehThis company went out of business a long time ago. Chances are you wont find it at any parts store but you may find it on line thru ebay or craigslist.
George
Posted on Oct 25, 2013
How do you set the gap between the coil and the flywheel
Usually you loosen the coil and it'll move in or out a little bit. Use feeler gauge on both sides of the coil. Afterwards slowly turn engine over to ensure nothing is hitting
Feb 18, 2016 | Tecumseh Snowblower Snow Blower Starter...
Can you replace the whole spark plug wire on the coil on 8hp Tecumseh without changing the coil
Not unless you cut the wire and splice a new piece on, which I would not recommend. A new coil should cost you less than $20 and is not hard to replace. See the attached YouTube video on how to do it. https://www.youtube.com/watch?v=v6bQrNr4lv0
Feb 26, 2015 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Toro snowthrower coil condensor points
If you have changed sparkplug and coil and cleaned flywheel, you probably have a kill wire problem. Disconnect kill wire from coil and try again.
Apr 04, 2014 | Tecumseh Enduro Horizontal Engine 5 HP...
8HP Tecumseh with no spark
Check the gap between the coil and the flywheel. You can fold a dollar bill over a few times (3 or 4 layers thick) , place it against the flywheel , **** the coil up to it , and then tighten down the coil. This will give you a good clearance between the coil and flywheel and promote good spark.
Essentially I am suggesting you use the folded dollar bill to set the coil to flywheel distance/gap.
If it still doesn't work, I am at a loss. Is this a multi cylinder engine ? If so , does it have points or electronic ignition ?
Aug 08, 2012 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
No spark on my murry riding lawn mower it has a tecumseh ohv135 replaced the spark plug
clean the flywheel, and the contact area on the coil. if this doesn't fix it then you need a new coil.
Nov 03, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Tecumseh engine has no spark. spark plug has been replaced
iF IT IS EQUIPPED WITH A CDI (CAPACITOR DISCHARGE IGNITION) IT IS PROBABLY BURNT OUT AND MUST BE REPLACED. IF IT HAS A COIL, TRY CLEANING THE MAGNITO AND COIL WITH EMERY CLOTH THEN REGAP IT.
Feb 09, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
No spark
Hi
You need a special tester to test a coil off of the engine. If you take iit to a small engine shop they can test it for you. You can test it on the engine. First clean the surface of the coil where it mounts to the engine. Reinstall the coil. Do not install the kill wire to the coil. Install a inline spark tester and crank engine if you still don't have any spark the coil is bad.
Sam
Jan 11, 2010 | Yard Machines Tecumseh 148cc Front Tine...
My tecumseh 5 hp engine will start but then after
Hello:
Operate the Engine Unitl it Quits and then Check for Fire to the Plug.
If No Fire, then the Ign Coil/Module Requires Replacing.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Troy Bilt 5.5hp Self Propelled Mower Logo
29 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
