Question about KitchenAid Coffee Makers & Espresso Machines
I have a brand new Kitchenaid Artisan, which works perfectly apart from one thing; it doesn't appear to output hot water probably. It does output steam and a lot of it, which eventually will turn into water, but is it true, that I have to put it on max steam and press the button to get a decent amount of hot water for my tea? Thank you!
  • KitchenAid Master
  • 1,305 Answers
If it is a 5KES100 model then yes that's how you do it, you get your hot water from the steam boiler so the steam needs to be released before the water can come through. Turn the tap wide open and press and hold the steamer pump button. The rush of steam on full open is short lived.
Posted on Oct 18, 2013
SOURCE: Kitchenaid Espresso maker no longer dispenses hot water from frother
by frother you mean it puts out steam ? if yes then I need to know how long you hold down the button and have you checked the hose in back to see if it has cracks or is kinked?
Posted on May 28, 2008
SOURCE: trying to ventilate and hot water not flushing through on button 26
Before you press water button to vent you need to restore to factory settings.
First press menu (far right button) then toggle to restore factory settings (using far left button), press menu button then far right again until yes comes up, then press menu button. Press esc button (3rd from left), machine should now be back to normal. Then press water button (3rd from right) and turn steam knob to vent until free water is coming through.
This is the only way I could get mine to work!
Posted on Oct 23, 2008
  • 3 Answers
SOURCE: Francis!Francis!3X overheating
Your thermostat has failed. The middle button is the pump. The bottom button is for the steam mode. If you are getting steam instead of hot water when using the pump, then the boiler is way too hot. Either adjust the thermostat or try descaling the boiler.
Posted on May 09, 2009
  • 143 Answers
SOURCE: When the hot water switch is pressed, no water is pumped.
group head is blocked. remove centre screw from the group head remove spring and valve, clean and re assemble.
Posted on Sep 20, 2009
Testimonial: "Many thanks. Problem fixed!"
  • 906 Answers
SOURCE: kitchenaid artisan coffee machine - steam wand
good day,
hope this link below will solve your problem..
kitchen
Posted on Aug 04, 2010
I have a brand new kitchenaid artisan mixer that i have only used once. I cannot move the speed control lever at all.
Take it back, no point voiding your warranty pulling it apart. You do know you need to put a bit of downwards pressure on that knob when moving it forward and back ??
Dec 15, 2016 | KitchenAid Food Mixers
Kitchenaid artisan mixer
The most likely answer is that you need a new speed control switch and there is a possibility that you may need a new worm gear. Can you give a more detailed explanation? What happened last time you used the machine?, what was happening when the problem occurred? What caused you to open the back cover? what else did you inspect or take apart or open up? Please send more info.
Jan 03, 2013 | KitchenAid KSM150PS Artisan Series Stand...
Accessory Gear Stuck on KitchenAid Artisan
The fix for that is a new gear and replacement housing (the whole painted top part) The bush is unfortunately not available as a spare part.
Dec 31, 2012 | KitchenAid KSM150PS Artisan Series Stand...
I have a Kitchenaid Artisan stand mixer and the head is loose. When in the down, locked position, I can move it up and down by probably an inch. I've been into shops and tried to do the same with
If you have also tightened up the screw that you can see from the front in the middle where the hinge pivots when head us up then that's where your problem is. That is the head height adjustment and is to set the flat paddle to just clear the bowl when the head is down.
Aug 01, 2017 | KitchenAid Artisan Series Tilt-Head Stand...
KitchenAid Artisan: A bang, and now no water coming through.
Call Importer Peter McInnes - based in sydney, they'll put you on to someone!
Pete
May 21, 2010 | KitchenAid Artisan
Brand New Kitchenaid Artisan Mixer - Mixer head is stuck
Unplug the mixer, turn the whisk the opposite of normal rotation in a quick motion, the remove a per normal.
Feb 19, 2010 | KitchenAid KSM150PS Artisan Series Stand...
The beater shaft seems jammed. I can't push it up to remove my beater.
best returned to service centre as these are very hard to get apart.
Sep 15, 2009 | KitchenAid KSM150PS Artisan Series Stand...
My kitchenaid artisan coffee machine not enough water
if you have water out brewing without handle with coffee, than you check this 3 things:
  1. how fine is grinded the coffe, is it too fine for your machine?
  2. does pump make enough pressure to brew your coffee(you can measure if you attach an gauge to handle or steam pipe.
  3. by any chance your boiler security valve opens too soon and dont let pump to get the needed pressure. (perfect pressure is from 7 to 9 bar)
Mar 31, 2009 | KitchenAid Artisan
Coffee Makers & Espresso Machines Logo
85 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
